John h zackowski 0 #1 Posted December 23, 2020 Will a rod and flag from a snow blower on a b80 fit a 520h tracror? Share this post Link to post Share on other sites
Pollack Pete 2,273 #2 Posted December 23, 2020 Not sure.I believe the rod and flag are made for the snow blower attachment,not the tractor.I DO know that the flag and rod are completely different for a single stage versus a 2 stage blower. Share this post Link to post Share on other sites
Ed Kennell 42,168 #3 Posted December 23, 2020 Where's Garry? @gwest_ca It should fit if the B-80 is a long frame. 1 Share this post Link to post Share on other sites
AHS 1,550 #4 Posted December 23, 2020 2 hours ago, John h zackowski said: Will a rod and flag from a snow blower on a b80 fit a 520h tracror? Yes, I believe. About 99%. @ebinmaine do you have any knowledge about this? Share this post Link to post Share on other sites
ebinmaine 72,987 #5 Posted December 23, 2020 35 minutes ago, Ed Kennell said: Where's Garry? @gwest_ca It should fit if the B-80 is a long frame. 28 minutes ago, AHS said: Yes, I believe. About 99%. @ebinmaine do you have any knowledge about this? B80 is a mid frame in 74 and 5 and a long frame in 76 and 7 Do we know what year it came off of? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,521 #6 Posted December 23, 2020 Should work. If too long cut a bit off the tube. Too short and will not lift high enough add 3/4" SAE flat washers to the flag before it is inserted into the tube. When this lift system was introduced they would not lift high enough. A service bulletin said to add the 3/4" SAE flat washers and each 1/8" washer would change the height 1/2". That should hold true for all of them. Garry 2 2 1 Share this post Link to post Share on other sites
