TJ5208 1,841 #1 Posted November 11, 2020 I had a question about a receiver hitch on my 8 horse wheel horse 800 special and if Jim can sell me some exhaust stack pipes Share this post Link to post Share on other sites
ebinmaine 79,059 #2 Posted November 11, 2020 Jim's handle is @jimkemp. He'll be along at some point. Great stuff. The hitch I'd recommend is sold by Wheelhorsepartsandmore.com. One of our own fine vendors. 1 1 Share this post Link to post Share on other sites
jimkemp 528 #3 Posted November 12, 2020 Im here , i sent him a message Share this post Link to post Share on other sites
Pullstart 70,039 #4 Posted November 13, 2020 I spoke with TJ one the phone yesterday, great enthusiastic young man right there! He reminded me that the 800 Special has a peerless (1400?) transmission, not a unidrive. He does have access to other tractors, it sounded like some are for parts. Would a Unidrive swap easily in place of the Peerless? It is a horizontal shaft Briggs powered tractor. Share this post Link to post Share on other sites
ebinmaine 79,059 #5 Posted November 13, 2020 I can't say as I have ever messed with one of those vertical shaft horses. One concern I have is the obvious of converting vertical to horizontal belt drive... So let's back this up a little bit and ask why we want a receiver hitch? Is there a hitch already on the tractor like a flat tab? If we're only going to be towing something very light duty that's all well and good. Maybe some pictures of exactly what we're dealing with? Share this post Link to post Share on other sites
Pullstart 70,039 #6 Posted November 13, 2020 8 minutes ago, ebinmaine said: I can't say as I have ever messed with one of those vertical shaft horses. One concern I have is the obvious of converting vertical to horizontal belt drive... So let's back this up a little bit and ask why we want a receiver hitch? Is there a hitch already on the tractor like a flat tab? If we're only going to be towing something very light duty that's all well and good. Maybe some pictures of exactly what we're dealing with? The 800 special is a horizontal shaft, just less superior parts than some other horizontal shaft tractors built... 1 Share this post Link to post Share on other sites
Pullstart 70,039 #7 Posted November 13, 2020 @ebinmaine here’s TJ’s tractor, from another post... 1 Share this post Link to post Share on other sites
ebinmaine 79,059 #8 Posted November 13, 2020 1 minute ago, pullstart said: The 800 special is a horizontal shaft, just less superior parts than some other horizontal shaft tractors built... Perhaps I should start paying better attention Best thing I could tell you would me to put the donor tractor side by each with that one and take some measurements. Looks like the sheet metal and steps and everything like that are all very familiar and maybe identical. 1 Share this post Link to post Share on other sites
Pullstart 70,039 #9 Posted November 13, 2020 TJ make sure when ever you pick a tractor up from the ground, support the machine well with jack stands, even testing the sturdiness before going under. I have had tractors fall, luckily I was not underneath. There are plenty more stories of mishaps in the shop, please consider your safety and well-being first and foremost 1 Share this post Link to post Share on other sites
ebinmaine 79,059 #10 Posted November 13, 2020 24 minutes ago, pullstart said: TJ make sure when ever you pick a tractor up from the ground, support the machine well with jack stands, even testing the sturdiness before going under. I have had tractors fall, luckily I was not underneath. There are plenty more stories of mishaps in the shop, please consider your safety and well-being first and foremost I'll second that. It's important to remember that one of the big reasons why we all like these old tractors is because they are very heavy duty, also, very heavy! Even the lightest of these ways in the neighborhood of 400 lb and I would not want to catch that on my arm. Take it easy and slow and undo one thing at a time and make sure you understand where you're at before you keep moving on... 1 Share this post Link to post Share on other sites
Pullstart 70,039 #11 Posted November 13, 2020 It appears these use completely different frames, as well as transmission mounting points. We need to keep in mind, there is nothing wrong with TJ’s tractor, just that he is looking for a hitch. Share this post Link to post Share on other sites
Pullstart 70,039 #12 Posted November 13, 2020 In the Illustrated parts list, it shows these two hitches. I imagine one is the front attachamatic, the other bolts to the back of the transmission. TJ, the hitch 7-20-B appears to be a bent piece of metal. I large section of angle iron just might do the trick if you have access to any. Drill a couple holes as needed and you have yourself a hitch. Share this post Link to post Share on other sites
ebinmaine 79,059 #13 Posted November 13, 2020 35 minutes ago, pullstart said: large section of angle iron Agreed Share this post Link to post Share on other sites
