Vurge
Starter generator regulator question
Vurge
If connected directly to the battery instead of the solenoid, does the regulator draw power when the engine is off?
gwest_ca
Are the two choices not at each end of the same battery cable?
I would say no if the regulator is functioning properly.
Garry
Vurge
Garry
Maybe that's the problem.  The way I have it set up, the regulator only power when keyswitch on "S".  After starting I assumed the S/G would provide power the regulator.  I'm going to connect the regulator to the battery directly this morning and see what happens.   Thanks for the info @gwest_ca.
gwest_ca
This manual has a good section on the starter/generator
Garry
953 nut
Here are a couple of diagrams that show wiring of a S/G charging/starting system. The first is with a solenoid and 103-990 switch, the second is typical of the wiring found on early model  :wh: but is not for a specific model.
5b202ef98cc34_wiring-starter-generatorwithbatteryignition.jpg.24ab0ca0cab6d9b8f7d7ffb2a7a42fbc.jpg
Vurge
Thanks guys.  I now suspect my voltage regulator (VR) is bad. I moved the VR connection over the battery side and left my DVM connected. Right after startup and for a minute after I see 13-14v volts... Then it drops to almost nothing (0.7v) and won't kick on again even when I put a load on the battery.  Grounding the DF terminal immediately ups charge voltage to 15+ volts.  I'll get a replacement on the way and update this post. 👍
Vurge
@gwest_ca   @953 nut
What a way for Amazon make a guy doubt his abilities.  First time messing with a starter generator and I got TWO defective voltage regulators in a row!  Third one works.  Thanks for the info on how to run the wires so I could verify I did it correctly.  That gave me the confidence to order that third regulator.   I was just about to throw in the towel.
Edited by Vurge
Clarify
alwaysbusy
I am hoping the first diagram is suitable for my C-175 as now I am stuck not knowing where it all goes.
Thanks.
pfrederi
C-175 is not what the diagrams are about you do not have a starter generator set up.  Let me look for a correct diagram.
pfrederi
Vurge
I've got an update on this project.  The 3rd solid state voltage regulator failed and I decided to install an old school mechanical model.  I think it's a copy of the vintage 4 terminal Delco design.  Took about a million trial and error adjustments to get the voltage set properly but it's working great now.  I sprayed for about 3 x 35 gallon tanks this morning and battery is still fully charged.  ☺
Not the prettiest, but it's 100% hard working!
