Pullstart 66,755 #1 Posted October 28, 2020 So, @PeacemakerJack and I took a chance on these 27x7.50-12’s last weekend and they performed like monsters! I just ordered another set of them, but in the 10” wide fashion. I tubed and filled mine and haven’t weighed them, but have extreme traction. For my 7.5’s, I used a set of wheels (5” wide?) off an original 6-12 setup. I’ll likely use 7” wheels on the 10’s and fluid fill them the same. As for what to put them on? The 1054 “Joe” that I brought to plow day just needed a set of 1-1/8” hubs swapped from a 12” wheel tractor and we were in business! The best part about these tires is the price! Well other than the traction they offer, of course. I found a few deals on eBay for a little over $220 for the pair shipped. 5 6 Share this post Link to post Share on other sites
Pullstart 66,755 #2 Posted October 28, 2020 I imagine if need be, a set of 12” weights can also be added. I’m not sure how necessary they are, but more weight is always better! These also seem to stick out more with the 5 lug hubs and the 12” wheels, I am considering a 6 speed swap with shorter axles to bring them inboard a tickle. 7 2 Share this post Link to post Share on other sites
Pullstart 66,755 #3 Posted October 28, 2020 For anyone unsure of the Interco name, think mud trucks. These are designed by side by side UTV’s, but I imagine the quality in the name is just the same. 1 Share this post Link to post Share on other sites
slim67 2,809 #4 Posted October 28, 2020 5 minutes ago, pullstart said: For anyone unsure of the Interco name, think mud trucks. These are designed by side by side UTV’s, but I imagine the quality in the name is just the same. They are definitely known for their mud truck tires. 1 1 Share this post Link to post Share on other sites
slim67 2,809 #5 Posted October 28, 2020 8 minutes ago, pullstart said: For anyone unsure of the Interco name, think mud trucks. These are designed by side by side UTV’s, but I imagine the quality in the name is just the same. It's funny that after all these different tread patterns the tire manufacturers have come up with, the simple ag design still reigns supreme in the mud. Only drawback is they are not D.O.T compliant or at least they never used to be. 2 Share this post Link to post Share on other sites
Pullstart 66,755 #6 Posted October 28, 2020 4 minutes ago, slim67 said: It's funny that after all these different tread patterns the tire manufacturers have come up with, the simple ag design still reigns supreme in the mud. Only drawback is they are not D.O.T compliant or at least they never used to be. I believe the Bogger is the most supreme DOT rated mud tire, because of their paddle / bar like tread. 1 Share this post Link to post Share on other sites
ebinmaine 72,675 #7 Posted October 28, 2020 10 minutes ago, slim67 said: It's funny that after all these different tread patterns the tire manufacturers have come up with, the simple ag design still reigns supreme in the mud. Only drawback is they are not D.O.T compliant or at least they never used to be. Been many moons since I've processed the thought but I think it's something to do with the percentage of rubber touching the road when they're on a hard surface. Note the fact that their road tires have what effectively amounts to an extra set of bars in between the ones that were on a standard AG tire. If or when that rule changes or relaxes you'll see AGS on the street. Share this post Link to post Share on other sites
slim67 2,809 #8 Posted October 28, 2020 15 minutes ago, pullstart said: I believe the Bogger is the most supreme DOT rated mud tire, because of their paddle / bar like tread. I would agree. Back in the day it was monster mudders and ground hawgs and 40s were the biggest. Now it's 54s. 11 minutes ago, ebinmaine said: Been many moons since I've processed the thought but I think it's something to do with the percentage of rubber touching the road when they're on a hard surface. Note the fact that their road tires have what effectively amounts to an extra set of bars in between the ones that were on a standard AG tire. If or when that rule changes or relaxes you'll see AGS on the street. Yes I agree and maybe sidewall flex? I take my ags out on the street but with a tractor 😝 2 Share this post Link to post Share on other sites
Pullstart 66,755 #9 Posted October 28, 2020 Found it, April 7 I mentioned these! 1 Share this post Link to post Share on other sites
sqrlgtr 705 #10 Posted October 28, 2020 I bet that bar and a half tread will ride alot smoother on hard surface at least been my experience on larger tractors . 1 Share this post Link to post Share on other sites
Lee1977 7,208 #11 Posted October 30, 2020 On 10/28/2020 at 9:23 AM, pullstart said: I imagine if need be, a set of 12” weights can also be added. I’m not sure how necessary they are, but more weight is always better! These also seem to stick out more with the 5 lug hubs and the 12” wheels, I am considering a 6 speed swap with shorter axles to bring them inboard a tickle. Just modify you plow hitch to line up with the existing width. Share this post Link to post Share on other sites
Pullstart 66,755 #12 Posted October 30, 2020 11 hours ago, Lee1977 said: Just modify you plow hitch to line up with the existing width. I did that for the time being, but would like the rears to track closer to the fronts either way. Share this post Link to post Share on other sites
Lee1977 7,208 #13 Posted October 30, 2020 11 minutes ago, pullstart said: I did that for the time being, but would like the rears to track closer to the fronts either way. Did you try switching sides or would that put them too close. Share this post Link to post Share on other sites
Pullstart 66,755 #14 Posted November 1, 2020 The 10” tires showed up! For reference, the 7” tires have a 7” wide tread pattern while on the 4 or 5” wide rim. The 10” tires have a 9-1/4” tread width not on wheels. There is zero air pressure in the 7” set, just fluid filled and pressurized as much as my 1/4” drill pump could do and me attempting minimal loss core swapping. Share this post Link to post Share on other sites
Lee1977 7,208 #16 Posted November 2, 2020 22 hours ago, pullstart said: They also make them in 30" that would require some modification. 1 Share this post Link to post Share on other sites
Pullstart 66,755 #17 Posted November 2, 2020 Yeah, there are various sizes Lee, but for my intentions the 27’s are perfect! Share this post Link to post Share on other sites
Pullstart 66,755 #18 Posted November 6, 2020 I mounted up the 27x10-12 tires last night, they are significantly larger than the 27x7.50-12’s! I think once fluid filled, I’ll be plenty butt heavy! As far as height goes, keep in mind the skinnies have only fluid pressure from a 1/4” transfer pump inside, zero air pressure. 4 Share this post Link to post Share on other sites
ebinmaine 72,675 #19 Posted November 6, 2020 1 hour ago, pullstart said: I mounted up the 27x10-12 tires last night, they are significantly larger than the 27x7.50-12’s! I think once fluid filled, I’ll be plenty butt heavy! As far as height goes, keep in mind the skinnies have only fluid pressure from a 1/4” transfer pump inside, zero air pressure. That's somewhere in the neighborhood or rugged looking Kev 1 1 Share this post Link to post Share on other sites
Pullstart 66,755 #20 Posted November 6, 2020 Just now, ebinmaine said: That's somewhere in the neighborhood or rugged looking Kev Now we just need to give it some more power. I haven’t given the thought of that K662, it might be overkill by a tad. 1 Share this post Link to post Share on other sites
ebinmaine 72,675 #21 Posted November 6, 2020 6 minutes ago, pullstart said: Now we just need to give it some more power. I haven’t given the thought of that K662, it might be overkill by a tad. Overkill is in the eye of the beholder. Overpowered just doesn't exist. 1 Share this post Link to post Share on other sites
Pullstart 66,755 #22 Posted November 6, 2020 2 minutes ago, ebinmaine said: Overkill is in the eye of the beholder. Overpowered just doesn't exist. I still need to be able to get across the field and back at minimum to refuel! 1 Share this post Link to post Share on other sites
ebinmaine 72,675 #23 Posted November 6, 2020 2 hours ago, pullstart said: I still need to be able to get across the field and back at minimum to refuel! Bigger tank bub. 1 Share this post Link to post Share on other sites
Pullstart 66,755 #24 Posted November 6, 2020 10 minutes ago, ebinmaine said: Bigger tank bub. 55 gallons ah’ petrol strapped to the roof, I.V. Style! 1 Share this post Link to post Share on other sites
ebinmaine 72,675 #25 Posted November 6, 2020 15 minutes ago, pullstart said: 55 gallons ah’ petrol strapped to the roof, I.V. Style! Now you're gettin it 1 Share this post Link to post Share on other sites
