WHX?? 51,722 #1 Posted September 16, 2020 (edited) At a tractor show last weekend I was unable to get the 1055 out of third gear, a 5049 three speed. No neutral no reverse no nothing but third. Real pain as the only way to stop and dismount was to kill the engine. I didn't want to force it due to possibly making things worse so just ran it as is till it could get in the shop. Got it in the shop and pulled the shifter and easily found the H neutral with a big screwdriver. Reinstalled the shifter and all was well. I think what happened was the 1st/reverse shift rail slid over just enough to block the the 2nd/3rd rail from moving but yet was not in two gears at once. This is a really rough sounding tranny that I put back together from a real mess so the gear mesh is somewhat sloppy but she is what she is. Figured good enough for the women we go out with. I got this tractor set up for a little @Racinbob speed so makes the noise worse. Don't remember if I put the detent stop pin in the spring or not but thinking the spring is a little weak or the detent balls are worn?? It shifts almost a little too easy into gears. Sorry no pics... but these before and after cleanup. Edited September 16, 2020 by WHX24 speeling & gramma 7 Share this post Link to post Share on other sites
Pullstart 66,668 #2 Posted September 16, 2020 No way, you were driving in that shape? I imagine that came from the deep sea!? Share this post Link to post Share on other sites
WHX?? 51,722 #3 Posted September 16, 2020 (edited) 8 minutes ago, pullstart said: No way, you were driving in that shape No tranny was locked up. Sat out side for many years with this for a boot. Edited September 16, 2020 by WHX24 1 1 3 Share this post Link to post Share on other sites
Racinbob 11,919 #4 Posted September 16, 2020 That sure cleaned up nicely 2 Share this post Link to post Share on other sites
WHX?? 51,722 #5 Posted September 16, 2020 Thank you Bob. Lots of (enjoyable) work but I think my lesson learned here is tho always use new detent springs and balls. Only things new were bearings/seals and Lowell's 3rd gear. I have been having a problem finding the springs. Hardware store ones were either too stiff or too soft. 1 Share this post Link to post Share on other sites
Racinbob 11,919 #6 Posted September 16, 2020 Ya got me thinking about those springs. I found the p/n (3518) and did a bit of searching with no luck. But in the search it looks like a good bet might be a gunsmith 1 1 Share this post Link to post Share on other sites
Ed Kennell 41,831 #7 Posted September 16, 2020 3 hours ago, WHX24 said: This is a really rough sounding a real mess somewhat sloppy but she is what she is. Figured good enough for the women we go out with. Livin right on the edge there Madge. 2 Share this post Link to post Share on other sites
Tractorhead 9,209 #8 Posted September 16, 2020 Did you etank the gears? Share this post Link to post Share on other sites
WHX?? 51,722 #9 Posted September 16, 2020 13 minutes ago, Ed Kennell said: Livin right on the edge there Madge. Always Ed Always... story of my life 5 minutes ago, Tractorhead said: Did you etank the gears? No... bench top grinder with a wire wheel & by hand with a small wire brush. Cases blasted 1 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #10 Posted September 16, 2020 Great job! The blasted case Looks really good, but maybe better in Red. do you paint it or powder coat? Share this post Link to post Share on other sites
C_hasbeen 249 #12 Posted September 16, 2020 well when I took mine apart I did see about as gunkie as your interior was also, my detent steel balls were pitted and out of round so I went to Lowes and they had some, I got the 1/4 inch size I believe one in a package and not very expensive. I do not remember for sure but I think I used the original spring 1 1 Share this post Link to post Share on other sites
WHX?? 51,722 #13 Posted September 17, 2020 (edited) This is where my stupidity comes in hasbeen ... quite common for .25 ones at any hardware store. I plead the fifth on wanting to keep things original .... but who's gonna know anyway?!?! Some guy 50 years from now who takes it apart and says someones been in here before?!? No doubt it's a weak spring after tooling around on it tonite. Just havta watch the speed shifting I guess from here on out. Edited September 17, 2020 by WHX24 Share this post Link to post Share on other sites
C_hasbeen 249 #14 Posted September 17, 2020 8 minutes ago, WHX24 said: This is where my stupidity comes in hasbeen ... quite common for .25 ones at any hardware store. I plead the fifth on wanting to keep things original .... but who's gonna know anyway?!?! Some guy 50 years from now who takes it apart and says someones been in here before?!? No doubt it's a weak spring after tooling around on it tonite. Just havta watch the speed shifting I guess from here on out. I know where one of my old ones is in a drawer, if you want an original I can put it in an envelope and it is yours for free. Share this post Link to post Share on other sites
