Jon D 82 #1 Posted September 7, 2020 Anyone use one of these? Picked it up cheap about a month ago and making some changes to it. Just welded the frame (it was bolted with pipe) and about to add a linear actuator for dump mechanism. Wonder how much fabrication it would take to attach it to the front? 9 Share this post Link to post Share on other sites
AMC RULES 37,259 #2 Posted September 7, 2020 Google "Johnny bucket" Looks like one mounted up in reverse. Neat attachment, dig it mounted on the back. Share this post Link to post Share on other sites
Jon D 82 #3 Posted September 7, 2020 28 minutes ago, AMC RULES said: Google "Johnny bucket" Looks like one mounted up in reverse. Neat attachment, dig it mounted on the back. Scoop totes predate the Johnny bucket by a long time, found pics and ads going way back 5 Share this post Link to post Share on other sites
ebinmaine 79,709 #4 Posted September 7, 2020 6 hours ago, AMC RULES said: dig it "Dig" it?? I see what ya did there Craig. I agree. Super handy implement to have in one's arsenal. 1 Share this post Link to post Share on other sites
roadapples 6,987 #5 Posted September 7, 2020 Much rather have it on the front. The old neck don't work the way it used to. Handy unit.... 2 1 Share this post Link to post Share on other sites
Jon D 82 #6 Posted September 7, 2020 47 minutes ago, roadapples said: Much rather have it on the front. The old neck don't work the way it used to. Handy unit.... I’m thinking about making a front sleeve hitch to lift it, either on attach-a-matic or build a different frame. Not sure if snowblower lift rod could get it high enough or if I’d need a second linear actuator to lift it 1 Share this post Link to post Share on other sites
squonk 47,410 #7 Posted September 7, 2020 1 hour ago, roadapples said: Much rather have it on the front. The old neck don't work the way it used to. Handy unit.... A school bus could be right behind me and I couldn't see it. 1 3 Share this post Link to post Share on other sites
1995 520H+96+97 939 #8 Posted September 7, 2020 @Ed Kennell Has a front mount rototiller. 2 Share this post Link to post Share on other sites
Ed Kennell 46,604 #9 Posted September 8, 2020 6 hours ago, 1995 520H+96+97 said: @Ed Kennell Has a front mount rototiller. I was thinking a plow frame mount also, But I'm not sure if about lifting that much weight. But if it works on a cable operated clevis hitch , maybe? 2 Share this post Link to post Share on other sites
Jon D 82 #10 Posted September 8, 2020 1 hour ago, Ed Kennell said: I was thinking a plow frame mount also, But I'm not sure if about lifting that much weight. But if it works on a cable operated clevis hitch , maybe? The scoop as it sits probably has a weight around 60 lbs and total weight with full scoop of dirt is probably around 300 lbs Share this post Link to post Share on other sites
ebinmaine 79,709 #11 Posted September 8, 2020 Anyone know the weight of the larger snowblowers? Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #12 Posted September 8, 2020 (edited) 1 hour ago, ebinmaine said: Anyone know the weight of the larger snowblowers? Approximately 250 for the deuce but it lifts and mounts differently from the singles which is how I would mount a front scoop/ Johnny Bucket. Edited September 8, 2020 by WVHillbilly520H 2 Share this post Link to post Share on other sites
