The Tuul Crib 7,354 #1 Posted September 4, 2020 Gotta clean this gas tank to put on my charger.Any cleaner this thing with something anybody have an idea what the best cleaner would be on this plastic abrasives scotch bright pads anything? Share this post Link to post Share on other sites
71_Bronco 1,072 #2 Posted September 4, 2020 (edited) simple green and some of those thick shop "paper" towels would be how I attack it. EDIT: I mix my simple green with a higher concentrate to water ratio. I get less out of the gallon "concentrate", but it cleans better. Edited September 4, 2020 by 71_Bronco 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #3 Posted September 4, 2020 Well Randy what you've got on that tank is clearly a combination of muck and schmootz. One thing that I would be very prone to doing in this particular situation is to soak that tank. Maybe overnight. In the hottest water you can start out with mixed in with some sort of oh, perhaps dish soap? I'd be a little leery about putting nasty chemicals on the plastic. Share this post Link to post Share on other sites
Stormin 9,988 #4 Posted September 4, 2020 You could also try paint thinners/white spirit. Won't harm the plastic. Scotch Bright pads will be ok if your gentle. 1 1 Share this post Link to post Share on other sites
Skwerl58 831 #5 Posted September 4, 2020 I have been known to clean plastic with that type of crud on it by using a cloth with some non ethanol gasoline. The fuel will flash dry but it does break down fuel based crud. A light coat of oil will also make it look great after you clean it. Just don't smoke while doing it! Share this post Link to post Share on other sites
The Tuul Crib 7,354 #6 Posted September 4, 2020 These are some good ideas but I thought I was the only one @ebinmaine eric that used the word Schmutz!! Got to make it match the new paint so it Has to be clean! 1 2 Share this post Link to post Share on other sites
953 nut 67,501 #7 Posted September 4, 2020 2 hours ago, ebinmaine said: muck and schmootz. Love it when people use Highly Technical Terms around here! 5 1 Share this post Link to post Share on other sites
johnnymag3 2,647 #8 Posted September 4, 2020 2 hours ago, Stormin said: You could also try paint thinners/white spirit. Won't harm the plastic. Scotch Bright pads will be ok if your gentle. The pads will leave ALOT of scratches Share this post Link to post Share on other sites
johnnymag3 2,647 #9 Posted September 4, 2020 elbow grease Share this post Link to post Share on other sites
lynnmor 8,915 #10 Posted September 4, 2020 Around here we have road apples and schmutz, plenty of both in PA Dutch country. 3 Share this post Link to post Share on other sites
WHNJ701 4,173 #11 Posted September 4, 2020 Purple power Share this post Link to post Share on other sites
ebinmaine 79,740 #12 Posted September 5, 2020 21 minutes ago, lynnmor said: road apples Like @roadapples....? 1 Share this post Link to post Share on other sites
Lee1977 7,710 #13 Posted September 5, 2020 3 hours ago, johnnymag3 said: The pads will leave ALOT of scratches There are a lot of different grades of Scotch Bright Pads. 2 Share this post Link to post Share on other sites
Darb1964 1,169 #14 Posted September 5, 2020 I'd try steel wool with dish detergent and warm water. Use as much force it takes to just take off the curd. 1 Share this post Link to post Share on other sites
Stormin 9,988 #15 Posted September 5, 2020 7 hours ago, johnnymag3 said: The pads will leave ALOT of scratches Not if your gentle. Don't rub. Just gently wipe. Share this post Link to post Share on other sites
AMC RULES 37,259 #16 Posted September 5, 2020 What's in this can? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #17 Posted September 5, 2020 Lacquer! I really dont want to use it all though it cuts grease really good!! Share this post Link to post Share on other sites
oldredrider 2,553 #18 Posted September 5, 2020 Krud Kutter works wonders and doesn't damage surfaces. Available at Lowes. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #19 Posted September 5, 2020 So I'm sitting here at the bench and it's just killing me not to use this lacquer but I tried to the bottom of the tank with lacquer in it cleaned it well. Im going to try and buff it out after the outside is cleaned. 3 Share this post Link to post Share on other sites
AMC RULES 37,259 #20 Posted September 5, 2020 Less is more, just paint it after it's clean. 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #21 Posted September 5, 2020 Purple power Share this post Link to post Share on other sites
RandyLittrell 3,944 #22 Posted September 6, 2020 I have some purple power and it really cleans well! You would also be surprised how well scrubs-in-a-bucket will clean something like that. https://www.homedepot.com/p/SCRUBS-12-25-in-x-10-50-in-Hand-Cleaner-Towels-72-Canister-ITW42272EA/205705206 Randy 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #23 Posted September 6, 2020 So true Randy, those things are badass! 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #24 Posted September 6, 2020 8 minutes ago, AMC RULES said: So true Randy, those things are badass! Which Randy! Share this post Link to post Share on other sites
RandyLittrell 3,944 #25 Posted September 6, 2020 6 minutes ago, The Tuul Crib said: Which Randy! The Fat one from KC!! Randy 1 Share this post Link to post Share on other sites
