Dan87
Please help identify this blower, Found this blower for free
Dan87
Hey everyone!
Long time forum reader, first time poster! I just picked this blower attachment up last night for free! Thought it may fit one of my Wheel Horse tractors but once i got it home i was not so sure.
I have a 1986-87 - 212-6 and a 1970's C-100. Both have all the parts needed to attach a mower deck.
I have no idea how this one would attach to either, it may be missing parts? It does not have any model/serial numbers on it so i was having a hard time finding the manual that goes with it.
I also do not know if it was modified at any point, the man i got it from did not know what it came off and my best guess is it came with the house he said he moved into 1 year ago.
Thanks for the help!
oliver2-44
:text-welcomeconfetti:
The snow experts will be along shortly.
For a good reason I don't have any blower knowledge. don't need it living in central Texas.
Maybe I could use one as a big fan.
  • Haha 3
Stepney
Believe that belongs to a late 70's B series vertical shaft?
peter lena
DAN87 , the blower is essentially  a 36 x 42  single stage unit,  the difference being is that it was set up for a vertical engine , the main horizontal  SHORT  drive shaft and hook up will not work with the pto drive , found a picture , that shows the proper right hand pulley drive set up for your pto. not really a difficult change over , longer drive shaft , bearing mount swap ,and correct pulleys and belt tension frame , will get you going. you can probably search out parts on this site , from used units, let us know what you think , pete
Dan87
The brackets to attach to front are to wide for the c-100 and will not work.
My only hope is if it would then fit my Wheel horse 212-6 as i believe that one has a vertical shaft not the horizontal PTO drive?
this looks like the one i have from what you can see in image:
this is same model as one of my WH but blower not exactly the same but very similar.
Edited by Dan87
R. L. Addison
I have a D series that is very similar.
  • Similar Content
    • FarmallFarmer09
      By FarmallFarmer09
      I recently purchased my first wheel horse with a number of new attachments, And included in that bundle was a Wheel Horse snow blower. I would love to use it, But as it seems, Its missing a few key components to use it. Its missing the 2 side caster wheels, Along with the lift rod. does anyone know where i could potentially pick up either of these things?
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
