giddyap 1,574 #1 Posted August 20, 2020 Again I used a Ross Steering unit from a Cub on my second WH custom. Built for wheel stands, gripping the wheel could be a matter of life or death. The tower and steering components had to be capable of holding a man as if he were hanging over a cliff. Since I don't weld I bolted on a section of frame for the tower that had the transmission plate. I had to cut down the steering column so I could use a deep quick release steering wheel. A mule pulley housing mated the column to the tower as strong as if I had welded it all together. To soften the landings I cut to size porch swing springs to replace the sections of axle I cut off. A 4" pulley on the engine and 3" on the trans makes a perfect all around 2nd gear. Third bogs down and first is too slow for me. 8 6 2 4 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #2 Posted August 20, 2020 (edited) Yeee. Haaaa !! High-O- Silver!! Edited August 20, 2020 by The Tuul Crib Share this post Link to post Share on other sites
Redneckdavis 308 #3 Posted August 20, 2020 (edited) Well that's cool. Can you post some pics of the homegrown suspension? And what engine is that? Edited August 20, 2020 by Redneckdavis 1 1 Share this post Link to post Share on other sites
953 nut 68,853 #4 Posted August 20, 2020 51 minutes ago, giddyap said: To soften the landings I cut to size porch swing springs to replace the sections of axle I cut off I would love to see some detail of this. 2 Share this post Link to post Share on other sites
Pullstart 71,163 #5 Posted August 20, 2020 Love it! 1 Share this post Link to post Share on other sites
Achto 32,528 #6 Posted August 20, 2020 Awesome!!!! That looks like a super fun ride!! 1 1 Share this post Link to post Share on other sites
bottjernat1 2,197 #7 Posted August 20, 2020 Sweet!! Share this post Link to post Share on other sites
bottjernat1 2,197 #9 Posted August 20, 2020 Do you have some photos of your modifications so folks can see? Share this post Link to post Share on other sites
Herder 2,356 #10 Posted August 20, 2020 WOW, that's awesome. Love it!!! 1 Share this post Link to post Share on other sites
JoeM 10,200 #11 Posted August 20, 2020 3 hours ago, giddyap said: Built for wheel stands and my wife tells me I need adult supervision! Good job, looks like a lot of fun! 1 8 Share this post Link to post Share on other sites
giddyap 1,574 #12 Posted August 20, 2020 3 hours ago, Redneckdavis said: Well that's cool. Can you post some pics of the homegrown suspension? And what engine is that? Pictures later, I can agree with Harbor Freight that a black Predator on their water pump would discourage sales. Used for any other application a Blue Predator often raises the question "what engine is that?" 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #13 Posted August 20, 2020 Seems a fun rider at it‘s best. Great looking Tractor seems a Big Boy‘s Toy for a lot‘s of Fun. 1 Share this post Link to post Share on other sites
tunahead72 2,660 #14 Posted August 20, 2020 I can't get this song out of my head for some reason... 1 2 Share this post Link to post Share on other sites
wallfish 20,553 #15 Posted August 20, 2020 Ha, I see you're at it again. That still pic for the video is great! Just another crazy old man and his lawnmower! LoL 2 1 2 Share this post Link to post Share on other sites
giddyap 1,574 #16 Posted August 21, 2020 16 hours ago, 953 nut said: I would love to see some detail of this. Nothing fancy, I just cut the springs somewhat close to the size I needed. The porch swing springs (2 per package for $10) are wider and thicker than need be thus restrict travel distance for a hard cushion. The compession spring size I wanted I could only find in piano wire and could not hold the weight. The right ones would create a soft landing 4 1 Share this post Link to post Share on other sites
giddyap 1,574 #17 Posted August 21, 2020 16 hours ago, Achto said: Awesome!!!! That looks like a super fun ride!! This rat rod was my inspiration 4 3 Share this post Link to post Share on other sites
giddyap 1,574 #18 Posted August 21, 2020 16 hours ago, bottjernat1 said: Do you have some photos of your modifications so folks can see? This is the mule pulley guard which I referred to as the pulley house 2 1 1 Share this post Link to post Share on other sites
giddyap 1,574 #19 Posted August 21, 2020 The tower is the section of frame with the transmission plate. Also the Cub steering column 1 1 1 Share this post Link to post Share on other sites
giddyap 1,574 #20 Posted August 21, 2020 (edited) I cut and folded the fender seat pan, later removed the middle for a wider look. The rusted piece on the tower is a partial transmission plate to mount the pulley guard on. The original 6" trans pulley is on the engine. I used a 4" pulley. Cubs use the yellow triangle plate to hang foot rest rods. I use them everwhere and cub foot rests Edited August 21, 2020 by giddyap additional info 1 1 1 Share this post Link to post Share on other sites
giddyap 1,574 #21 Posted August 21, 2020 Will consider offers with or without the engine. See classified ads for my Super Sized Suburban 1 Share this post Link to post Share on other sites
giddyap 1,574 #22 Posted August 21, 2020 Two events worth mentioning. I exhanged the original wheelie wheels for nicer but smaller ones. The next ride it goes vertical and my butt hits the driveway, immedialey i realize I did not adjust the wheelie bar stop. The other event I get stuck perfectly balanced in the vertical 00094.MTS Share this post Link to post Share on other sites
Greentored 3,221 #23 Posted August 21, 2020 'Wheel'n Horse' approves PS- hopped up 11hp clone. Adjustable wheelie bar beats broken noggin. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,465 #24 Posted August 21, 2020 @giddyap Quite a machine!!! 1 Share this post Link to post Share on other sites
Pullstart 71,163 #25 Posted August 21, 2020 On 8/20/2020 at 5:50 AM, giddyap said: Again I used a Ross Steering unit from a Cub on my second WH custom. Built for wheel stands, gripping the wheel could be a matter of life or death. The tower and steering components had to be capable of holding a man as if he were hanging over a cliff. Since I don't weld I bolted on a section of frame for the tower that had the transmission plate. I had to cut down the steering column so I could use a deep quick release steering wheel. A mule pulley housing mated the column to the tower as strong as if I had welded it all together. To soften the landings I cut to size porch swing springs to replace the sections of axle I cut off. A 4" pulley on the engine and 3" on the trans makes a perfect all around 2nd gear. Third bogs down and first is too slow for me. Just showed this to Mrs. P... “It’s just you... it’s just you in a few more years, that’s all..”. I think that’s a compliment... or a challenge to build a similar project! 1 3 Share this post Link to post Share on other sites
