mrc 1,093 #1 Posted July 24, 2020 i know the earlier wh tractors came equipped with sunstrand hydro's hydrogear vs. piston to piston. how are they different? can both be rebuilt? i also know the later wh tractors had the eaton auto's. eaton 700 and 1100. you want the 1100 because it's more robust and has a filter. the eaton's can be rebuilt correct? thank you mike in mass. 1 Share this post Link to post Share on other sites
stevasaurus 23,739 #2 Posted July 24, 2020 Mike the main answer to your question is " yes" all of them can be rebuilt. The only thing that can change that is not having the part you need. So far, that is not an issue, but if they are not making the parts anymore...you need to find used ones and hope that the good part(s) are in there. Right now, if you can take it apart, you can fix it. One other point I should make...when you say Sundstrand, you are talking about the pump...the transaxle is Wheel Horse. Parts and bearings and seals are readily available for the transaxles. A lot of members do not make that distinction. 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #3 Posted July 24, 2020 I've never worked on an Eaton so I have no insight to the viability of rebuild...either the 700 or 1100. As to the difference between Sundstrand piston-piston and Hydro gear... like asking the diff between a Chevy & Ford, although the overhaul procedure is quite similar. IMHO... the Hydro gear is more robust and has fewer 'wear-out' parts than does the Piston-Piston. 1 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #4 Posted July 24, 2020 Yes the Hydro gear is very workable and rebuildable . But there is a lot of elbow grease that goes with it. All the surfaces that need to be re-leveled and re-ground is a little bit of extra work but it's well worth the effort. I'm new to the automatic and the Sunstrand so I can't wait to sit my fat behind on it and go for the first ride around the property. yeeee haaa! @daveoman1966 I still need some advice on a few things! 1 Share this post Link to post Share on other sites
ebinmaine 79,571 #5 Posted July 25, 2020 15 hours ago, daveoman1966 said: . IMHO... the Hydro gear is more robust and has fewer 'wear-out' parts than does the Piston-Piston Roughly what years were each one used? Share this post Link to post Share on other sites
daveoman1966 3,884 #6 Posted July 25, 2020 2 hours ago, ebinmaine said: Roughly what years were each one used? from 1968 to a few were made in 1973. Pistonb-piston began in 1974.. 2 Share this post Link to post Share on other sites
mrc 1,093 #7 Posted July 27, 2020 thank you steveasaurus, daveoman and tuul crib. steve, i did not know just the pump was sunstrand. i always learn at this site! 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #8 Posted July 27, 2020 Here is a Hyd Pump ID plate from the side of a 90-2046. The 90-2062 model has the same ID Plate. 2 Share this post Link to post Share on other sites
