AHS 1,701 #1 Posted June 27, 2020 I just added a choke cable. What’s a wheelhorse supposed to idle at and high rpm? It runs and starts great.... but the issue is.. when I bring it from idle to high rpm really quick...there is a hiccup in the motor, almost stalls... it’s sorta like it’s leaning out. At high rpm, it’s mows fine. At low rpm it lugs around, like a kohler. Oh ya, I got the tractor and the mower for $300!!😁 3 Share this post Link to post Share on other sites
pfrederi 21,189 #2 Posted June 27, 2020 (edited) Idle speed is about 1250 High end 3600 Edited June 27, 2020 by pfrederi 3 Share this post Link to post Share on other sites
ebinmaine 80,772 #3 Posted June 27, 2020 34 minutes ago, AHS said: there is a hiccup You should start with cleaning the carb. Might help. 2 Share this post Link to post Share on other sites
PeacemakerJack 11,061 #4 Posted June 27, 2020 I can’t overemphasize the importance of pulling the float bowl and making sure that is clean. Often these tractors sit for long periods with ethanol fuel and it crystallizes and gels in the bowl. It can cause problems intermittently or continuously if not removed. I always keep a surplus of carb gaskets because it is the number one problem to many of the old Kohler’s I’ve encountered in not running. I can’t tell you the number of tractors that I’ve purchased that didn’t run and all it took was cleaning the fuel system and they ran great! Fresh, properly gapped spark plug is also a low cost insurance too. 7 Share this post Link to post Share on other sites
oldlineman 1,810 #5 Posted June 28, 2020 and keep the corn gas out of them corn is for eating! 3 Share this post Link to post Share on other sites
953 nut 69,571 #6 Posted June 28, 2020 https://www.pure-gas.org/ 1 Share this post Link to post Share on other sites
RandyLittrell 3,946 #7 Posted June 28, 2020 Not only clean the carb, but flush the tank and replace lines. It only takes one little speck to reduce the fuel flow. I have cleaned a carb in hurry and put it back, just to find it clogged again within minutes! Randy 4 Share this post Link to post Share on other sites
AHS 1,701 #8 Posted June 28, 2020 21 hours ago, oldlineman said: and keep the corn gas out of them corn is for eating! Oh yes, I run non ethanol!! 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #9 Posted June 29, 2020 I recently picked up a non running 414-8 (and got it running) but a bit like you if I move the throttle fast from idle to WOT it will also "hiccup" but if I move it slowly upward to WOT it goes flawlessly each time... Maybe it's a Magnum thing. 2 1 Share this post Link to post Share on other sites
AHS 1,701 #10 Posted June 29, 2020 8 hours ago, WVHillbilly520H said: I recently picked up a non running 414-8 (and got it running) but a bit like you if I move the throttle fast from idle to WOT it will also "hiccup" but if I move it slowly upward to WOT it goes flawlessly each time... Maybe it's a Magnum thing. Yours looks a lot cleaner than mine!! Mine is mowing the dust bowl Maine’s got right now! No rain for approx 2-3 weeks.... everybody’s lawn is dead!! I’m trying to get ready for snowblowing, this is my first year on this tractor, so I’m trying to work all the kinks out of it!!! I know I’ve got to change my fuel line!! 1 Share this post Link to post Share on other sites
ebinmaine 80,772 #11 Posted June 29, 2020 No more dust bowl in southern Maine. Been raining all night. You'll see it soon. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #12 Posted June 29, 2020 (edited) On 6/29/2020 at 5:34 AM, AHS said: Yours looks a lot cleaner than mine!! Mine is mowing the dust bowl Maine’s got right now! No rain for approx 2-3 weeks.... everybody’s lawn is dead!! I’m trying to get ready for snowblowing, this is my first year on this tractor, so I’m trying to work all the kinks out of it!!! I know I’ve got to change my fuel line!! That's the after pics... Original owner got the point of not caring and it was rather filthy... And I replaced ALL the fuel lines and filter and cleaned the engine and carb. Edited June 30, 2020 by WVHillbilly520H Share this post Link to post Share on other sites
AHS 1,701 #13 Posted June 30, 2020 On 6/29/2020 at 5:54 AM, WVHillbilly520H said: That's the after pics... Original owner got the point of not caring and it was rather filthy... And I replaced ALL the fuel and filter and cleaned the engine and carb. That’s the point mines in!! I had to replace all the fluids, the shifter boot, and a muffler, the choke cable. I need to buy a tiny tac....its sounds about right; the idle and the high RPM. And need to change the fuel lines and fuel filter.... I think there original! It looks so by the amount of dry rot!! Share this post Link to post Share on other sites
The Tuul Crib 7,354 #14 Posted June 30, 2020 On 6/28/2020 at 7:46 PM, WVHillbilly520H said: I recently picked up a non running 414-8 (and got it running) but a bit like you if I move the throttle fast from idle to WOT it will also "hiccup" but if I move it slowly upward to WOT it goes flawlessly each time... Maybe it's a Magnum thing. Mine too! 1 Share this post Link to post Share on other sites
AHS 1,701 #15 Posted June 30, 2020 On 6/29/2020 at 5:38 AM, ebinmaine said: No more dust bowl in southern Maine. Been raining all night. You'll see it soon. @ebinmaine it’s raining here now!! I was saying “we need about two day worth of rain!! Well here comes day #2! 1 Share this post Link to post Share on other sites
AHS 1,701 #16 Posted June 30, 2020 Well, the Magnum 14, is first generation without points and a coil... I was thinking that may be why? I don’t know? @The Tuul Crib @WVHillbilly520H Share this post Link to post Share on other sites
The Tuul Crib 7,354 #17 Posted June 30, 2020 29 minutes ago, AHS said: Well, the Magnum 14, is first generation without points and a coil... I was thinking that may be why? I don’t know? @The Tuul Crib @WVHillbilly520H So you're saying it's pointless!? my 414 runs flawless except for that little spot. I call it a fuel burp! Kind of like that first big swig of beer and you hick-up real quick 2 Share this post Link to post Share on other sites
PeacemakerJack 11,061 #18 Posted June 30, 2020 Honestly, if it continues or gets worse...it could be the “magneto”. I’ve had to replace several of those through the years but that seems to be a more intermittent problem which I would link to the carb/fuel system more likely as Indicated above...I’ll have to observe my daughters Case 224 with the M16 and see if it does that... Share this post Link to post Share on other sites
953 nut 69,571 #19 Posted June 30, 2020 3 minutes ago, PeacemakerJack said: I would link to the carb/fuel system more likely as Indicated above. Add some Seafoam to the gas at a rate of 5 oz/Gallon and drive the heck out of it. After that use the normal 1 oz/Gallon ratio. This has worked well for me. 2 1 Share this post Link to post Share on other sites
AHS 1,701 #20 Posted June 30, 2020 10 hours ago, 953 nut said: Add some Seafoam to the gas at a rate of 5 oz/Gallon and drive the heck out of it. After that use the normal 1 oz/Gallon ratio. This has worked well for me. Ya! Thats what my Father uses! I’m pretty sure I have some. Share this post Link to post Share on other sites
AHS 1,701 #21 Posted June 30, 2020 10 hours ago, The Tuul Crib said: So you're saying it's pointless!? my 414 runs flawless except for that little spot. I call it a fuel burp! Kind of like that first big swig of beer and you hick-up real quick Mine too!! I’ll have to try that first big swig of beer!😁😁 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #22 Posted June 30, 2020 1 hour ago, AHS said: Mine too!! I’ll have to try that first big swig of beer!😁😁 now !! 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #23 Posted July 1, 2020 12 hours ago, PeacemakerJack said: Honestly, if it continues or gets worse...it could be the “magneto”. I’ve had to replace several of those through the years but that seems to be a more intermittent problem which I would link to the carb/fuel system more likely as Indicated above...I’ll have to observe my daughters Case 224 with the M16 and see if it does that... 1 Share this post Link to post Share on other sites
