TDF5G 2,074 #26 Posted February 16, 2022 (edited) Here's a follow up report on the fuel starvation saga. The primer bulb solved the hard start problem, but it caused the engine to starve for fuel. When mowing, we'd have to keep squeezing the bulb to keep her going. So I installed a Facet electric fuel pump late last summer. I was amazed that it bolted right to the frame without having to drill holes. I used the elbow fittings from the original pump and my brother fabricated a block off plate for where the original pump mounted on the engine. I picked up an ATC fuse add-on at Auto Zone to wire into the ignition circuit. So far so good. It starts right up every time no matter how long it sets and runs great! Thanks for everyone's help and advice. RS is awesome! Edited February 16, 2022 by TDF5G 3 4 Share this post Link to post Share on other sites
squonk 47,890 #27 Posted February 16, 2022 Can't go wrong with a Facet pump! 1 1 Share this post Link to post Share on other sites
TDF5G 2,074 #28 Posted February 16, 2022 26 minutes ago, squonk said: Can't go wrong with a Facet pump! It works great! 1 Share this post Link to post Share on other sites
Bill D 3,101 #29 Posted February 17, 2022 8 hours ago, TDF5G said: It works great! Where did you buy that pump and what model is it? It's time for a new pump on my Onan. 1 Share this post Link to post Share on other sites
TDF5G 2,074 #30 Posted February 17, 2022 9 hours ago, Bill D said: Where did you buy that pump and what model is it? It's time for a new pump on my Onan. https://www.amazon.com/Facet-FEP04SV-Posi-Flo-Electric-Fittings/dp/B071HHCLB3/ref=sr_1_12?crid=2OEMSBQB07EXX&keywords=facet+fuel+pump&qid=1645108901&sprefix=facet+fu%2Caps%2C778&sr=8-12 1 Share this post Link to post Share on other sites
ebinmaine 80,307 #31 Posted February 17, 2022 @TDF5G Thanks for that. Been thinking about what to do on my big wheel tractor build. Ordered one up. 1 Share this post Link to post Share on other sites
