hodge 6 #1 Posted May 5, 2009 I have my gifts, just like every single person does. And, I am not gifted at everything, like everybody else. Electrical stuff is where I fall short. So, I appeal to the experience and wisdom of those here who know more about electrical things. I have a 99 Honda TRX 300 4x4 atv, and I have had a winch on it for about 3 years. The winch that I had was a 2300 lb superwinch. It broke (pulling out my stuck 312-8, no less), so I replaced it. I bought a 3000 lb Champion winch from Tractor Supply. I removed the positive and negative wires from the old winch, and installed the new winch. I changed nothing. I literally took the positive and negative off the old winch, and attached them to the new winch. Now, if I don't run the atv every couple of days, the battery is draining down. It is a new battery, and this started after replacing the winch. I have to assume that something is different with this winch. It did not come with a contactor, and I didn't figure that I needed to change it. Any ideas? Because it did not come with a contactor, I assume that it is built different than the previous winch. At this point, if I don't come up with a solution, I think I will wire a switch into the positive wire, so that when not in use, I can cut the power to the contactor. It is wierd, because the winch works well, and is strong. The battery will be weak/almost dead, and after running the 4 wheeler for a little bit, it will charge right back up. If I wasn't having this drain problem, I would say the winch works exactly like the previous one. Any ideas or similiar experience? Blessings to all of you! Share this post Link to post Share on other sites
oldandred 15 #2 Posted May 5, 2009 I have no idea but if you take the new winch lose from the connections and see if the battery runs down in the same amount of time Share this post Link to post Share on other sites
