SylvanLakeWH 29,324 #1 Posted May 2, 2020 So I take the C105 out for a ride to warm her up for spring oil change and it starts bogging / surging... Get back to garage and gas is dripping from air cleaner and it’s surging as in the video... Ran perfectly all winter. No issues with about 8 plows, 3 driveways each time... so about 8 hours of run time since train pulling duties all last summer with no issues warm weather either... Not an engine guy...Seeking wisdom from the experts - What am I looking at here? At least I got the oil change was accomplished! 55BAE6F4-5EA8-48D0-BCF2-2C639A50219C.MOV 1 Share this post Link to post Share on other sites
squonk 44,615 #2 Posted May 2, 2020 Junk in the (trunk) bowl. Or just it's time for a new needle and seat and a good carb cleaning. 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,324 #3 Posted May 2, 2020 Thanks for the feedback! I appreciate it! 1 Share this post Link to post Share on other sites
lynnmor 8,077 #4 Posted May 2, 2020 Yep, clean the carburetor. Do you have a quality fuel filter and are the fuel lines fresh? Share this post Link to post Share on other sites
953 nut 62,156 #5 Posted May 2, 2020 5 hours ago, SylvanLakeWH said: warm her up for spring oil change 5 hours ago, SylvanLakeWH said: and gas is dripping from air cleaner You did a good job of confirming that your fuel pump is working fine! Oil change is the first step in your maintenance plan. Next you need to replace the fuel line, fuel and air filters and replace the needle and seat in the carburetor. 1 Share this post Link to post Share on other sites
wallfish 18,625 #6 Posted May 3, 2020 Fuel flowing out of the front of the carb is a clear indication of flooding. The float needle valve is not sealing. Besides checking and cleaning that as advised, also check the float itself. Brass floats can develop a hole and partially fill with fuel. Shake it right away after removing it and you'll know if it does. The flooding is why your engine was running rough so once you cure the carb problem you should be all set. 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,324 #7 Posted May 3, 2020 Thank you @953 nut and @wallfish!!! Appreciate the help! Will check this out soon! 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,324 #8 Posted May 3, 2020 (edited) Thank you @953 nut, @wallfish And @squonk!!! As usual you guys were spot on!!! Purrs like a horse...! Appreciate your help! 6DA35E93-6055-49D8-B585-5E5B7352CBBD.MOV Edited May 3, 2020 by SylvanLakeWH 1 1 Share this post Link to post Share on other sites
tom2p 2,394 #9 Posted May 4, 2020 little wonder you have fuel problems you're driving with the front end straight up in the air sigh 1 Share this post Link to post Share on other sites
