Tgalo 128 #1 Posted May 2, 2020 Pick up a 418 with a 42" snow blower last weekend. Farley low hours and very well kept. The guy said he didn't like the way it mowed, well I found out why when I looked under the deck... See pic 4 5 2 1 Share this post Link to post Share on other sites
lynnmor 8,902 #2 Posted May 2, 2020 (edited) I bought a low hour machine from a guy that didn't like the way it cut as well. After I mounted the deck correctly, leveled it, set the transport height and put the belt in the right groove, it mowed just fine. That's the way to buy them, many owners don't know how to treat horses. Edited May 2, 2020 by lynnmor 2 3 Share this post Link to post Share on other sites
c-series don 12,130 #3 Posted May 2, 2020 That’s a nice 418 ! I bought my commando 8 from a guy that said he didn’t like the way it cut. I got it home jacked it up and quickly realized that the blades were on backwards. It has two counter rotating blades so I switched them and it cut beautifully ! 2 1 Share this post Link to post Share on other sites
peter lena 9,943 #4 Posted May 2, 2020 bought a like new 42 " rd deck a few years ago , owner said , it was a poor cutter , he had the wrong pto drive belt on it , cuts like a champ , pete 2 Share this post Link to post Share on other sites
Sam Pasch 450 #5 Posted May 2, 2020 1 hour ago, Tgalo said: Pick up a 418 with a 42" snow blower last weekend. Farley low hours and very well kept. The guy said he didn't like the way it mowed, well I found out why when I looked under the deck... See pic Hmmm. The blades definitely aren't on upside down. Wonder why it didn't work.😂 Share this post Link to post Share on other sites
Irv 115 #6 Posted May 2, 2020 Blades upside down! I bought a 518 like that a few years back. 1 Share this post Link to post Share on other sites
Tgalo 128 #7 Posted May 3, 2020 Question on this tractor. The steering seems kind of hard. I jacked it up and everything is free as could be. It has a tiny steering wheel on it. Would a bigger wheel help? Im thinking about the 520 steering maybe Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #8 Posted May 3, 2020 2 hours ago, Tgalo said: Question on this tractor. The steering seems kind of hard. I jacked it up and everything is free as could be. It has a tiny steering wheel on it. Would a bigger wheel help? Im thinking about the 520 steering maybe Unfortunately most don't steer as easy as a gear reduction steering set up like on a 520... Share this post Link to post Share on other sites
Tgalo 128 #9 Posted May 3, 2020 Yeah this just seems harder then my 85 312. Reduction steering would be nice for sure... Share this post Link to post Share on other sites
tom2p 2,394 #10 Posted May 3, 2020 (edited) could add some air to the front tires also - some tires will 'steer easier' than other tires ... I believe ribbed tires will reduce steering effort ... tires with reduced width should steer easier ... some turf tires with a more rounded profile / shoulders should steer easier (due to reduced contact patch) make sure all steering linkage etc is not binding and is properly greased Edited May 3, 2020 by tom2p 1 Share this post Link to post Share on other sites
ronhatch 410 #11 Posted May 3, 2020 Some guys should have their "MAN CARD" revoked! Yes a bigger steering wheel will help a little. Also remove the spindles and clean out all the old grease, add PMPS and re-grease with fresh grease. Finally, pump in about 20 lbs of air in tires. Share this post Link to post Share on other sites
RandyLittrell 3,944 #12 Posted May 3, 2020 My 310-8 had its blades upside down when I bought it too! Randy 1 Share this post Link to post Share on other sites
Pullstart 70,712 #13 Posted May 5, 2020 I bet they looked right side up when he installed them... when the deck was upside down 4 Share this post Link to post Share on other sites
953 nut 67,418 #14 Posted May 5, 2020 On 5/3/2020 at 9:45 AM, Tgalo said: Question on this tractor. The steering seems kind of hard. I jacked it up and everything is free as could be. It has a tiny steering wheel on it. Would a bigger wheel help? Im thinking about the 520 steering maybe My 418-C was hard to turn when I got it. Like @ronhatch said, I lubricated everything well and it made a big difference. Not sure it had been lubricated for a decade or so. Nice looking find, love my 418 and the hydraulic lift is a wonderful thing to have when plowing snow. Share this post Link to post Share on other sites
