Ed Kennell 47,942 #9326 Posted March 11 10 minutes ago, c-series don said: directions to my house, Just drop it off at the Big Show. I'll get it to the right place. 7 Share this post Link to post Share on other sites
c-series don 12,751 #9327 Posted March 11 It’s okay @Ed Kennell you’ve already done enough to help me. You don’t have to bring that wood from the show to my house. I’m sure Jim won’t mind continuing another 6 hours past the show grounds to get to my place. However if you want to jump in the truck with him I’d love to have both of you guys over to show you my collection. And yes, I’ll buy you dinner too! 1 1 5 Share this post Link to post Share on other sites
ebinmaine 81,278 #9328 Posted March 11 The generosity around here.... 6 Share this post Link to post Share on other sites
ebinmaine 81,278 #9329 Posted March 11 I've been changing my nutritional habits over the last couple weeks to a low carb ketogenic type. Under 100 carb allndays. Under 50 on a few. Down 10 lbs this morning. 5 more and I'll be back at my lowest from last year (and many years). 247.4 Aiming for 220 (???) 1 4 Share this post Link to post Share on other sites
WHX?? 58,387 #9330 Posted March 11 Had seven of those totes on so might have been a little overloaded... tires squatting pretty good. Only a 7k trailer. All really nice clear oak too... 6 Share this post Link to post Share on other sites
MainelyWheelhorse 3,208 #9331 Posted March 12 First, I cursed at Mother Nature for the rain and 30 degree temperature drop from yesterday. I also attempted to repair a garden trailer ATV tire that the valve stem was horizontally split in half. While I got the valve stem in it, fixing one problem created two more. It now leaks more due to old stiff rubber, and my previous failed attempts before succeeding to unseat the tire from the rusted rim. However, the tires on the trailer were 10+ years old, so I’ll either foam both tires or look at reasonable similar new replacements. 4 Share this post Link to post Share on other sites
Bar Nuthin 3,642 #9332 Posted March 12 Got the hydraulic lift put together on Ol' Johnny. Now I'm wondering if the electric PTO will hold up to the Mighty Mac - or if maybe I should make this my dedicated Mowing/Leaf vac machine. 5 Share this post Link to post Share on other sites
ebinmaine 81,278 #9333 Posted March 12 6 hours ago, MainelyWheelhorse said: foam. tires What's the foam? Share this post Link to post Share on other sites
MainelyWheelhorse 3,208 #9334 Posted March 12 1 hour ago, ebinmaine said: What's the foam? I don’t know yet, I’ve got to look it up more. I did see back years ago at a tradesman show there is a foam to put in tires if you do logging etc I just don’t remember what it was. Share this post Link to post Share on other sites
ebinmaine 81,278 #9335 Posted March 12 1 hour ago, MainelyWheelhorse said: I don’t know yet, I’ve got to look it up more. I did see back years ago at a tradesman show there is a foam to put in tires if you do logging etc I just don’t remember what it was. Please keep me posted on that. I am currently under the impression that the only foam that can go in a tire and be successful is a commercial grade issue which is very expensive. Share this post Link to post Share on other sites
WHX?? 58,387 #9336 Posted March 12 On 3/11/2026 at 3:45 AM, ebinmaine said: The generosity around here.... You shoulda seen the splitter I got to run. Youda been in splitter heaven EB. Log lift & adjustable up/down hydraulic fourway. Dual ram speeds. 12 HP Honda. Really the cat's meow but yah $$$... about 8500 in today's money. The neighbor I was helping his only source of heat so for him worth the investment. 1 2 Share this post Link to post Share on other sites
Beap52 2,536 #9337 Posted March 12 10 hours ago, ebinmaine said: Please keep me posted on that. I am currently under the impression that the only foam that can go in a tire and be successful is a commercial grade issue which is very expensive. That will be interesting if foam works. My uncle used just regular homeowner foam in a couple of tires and it didn't cure inside and just made a mess. 1 Share this post Link to post Share on other sites
ranger 1,871 #9338 Posted March 12 58 minutes ago, Beap52 said: That will be interesting if foam works. My uncle used just regular homeowner foam in a couple of tires and it didn't cure inside and just made a mess. I believe the expanding foam requires moisture from the air for it to cure. Sealing it inside a tyre would, I imagine, have the same effect as leaving it in the can🤔. Suppose you were to insert an amount of water, (as a catalyst) into the tyre before injecting the foam, would that work? I seem to remember reading the instructions recommending wetting the areas to facilitate adhesion and curing🤔 3 Share this post Link to post Share on other sites
ebinmaine 81,278 #9339 Posted March 12 1 hour ago, Beap52 said: That will be interesting if foam works. My uncle used just regular homeowner foam in a couple of tires and it didn't cure inside and just made a mess. 3 minutes ago, ranger said: I believe the expanding foam requires moisture from the air for it to cure. Sealing it inside a tyre would, I imagine, have the same effect as leaving it in the can🤔. Suppose you were to insert an amount of water, (as a catalyst) into the tyre before injecting the foam, would that work? I seem to remember reading the instructions recommending wetting the areas to facilitate adhesion and curing🤔 I've read piles of forums and spoken to zillions (give or take) of people. I've never heard of a non commercially installed foam that works right and stays in its correct form. It'd be neat if there was one. 3 Share this post Link to post Share on other sites
953 nut 70,648 #9340 Posted March 13 12 hours ago, ebinmaine said: foam that works right and stays in its correct form. This video is the most honest one I have found. It works, BUT! I did the spray foam deal years ago on a cart that sat most of the time and the foam flat spotted from sitting too long. 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #9341 Posted March 13 1 hour ago, 953 nut said: It works, BUT! I did the spray foam deal years ago on a cart that sat most of the time and the foam flat spotted Which essentially means.... it doesn't work. 1 2 1 Share this post Link to post Share on other sites
Blue Chips 881 #9342 Posted March 13 (edited) On 3/12/2026 at 7:49 AM, ebinmaine said: I don’t know yet, I’ve got to look it up more. I did see back years ago at a tradesman show there is a foam to put in tires if you do logging etc I just don’t remember what it was. On 3/13/2026 at 8:39 AM, 953 nut said: This video is the most honest one I have found. It works, BUT! I did the spray foam deal years ago on a cart that sat most of the time and the foam flat spotted from sitting too long. On 3/12/2026 at 7:49 AM, ebinmaine said: Please keep me posted on that. I am currently under the impression that the only foam that can go in a tire and be successful is a commercial grade issue which is very expensive. I think one 'might' get decent results with a two-part, flexible/resilient polyurethane foam, although I haven't tried it myself in a tire. Smooth-On offers multi-purpose foam kits in several different levels of softness and expansion. You might give them a call and see if they have any recommendations or user feedback for use in tires. I haven't checked on price per unit volume of foam, so I don't know how expensive it would be to experiment with on tires. I have used their products successfully for other purposes. https://www.smooth-on.com/product-line/flexfoam-it/ Edited March 14 by Blue Chips 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #9343 Posted March 13 Supper was home scratch made Chicken Alfredo. The "noodle" was spiraled fresh zucchini. Fresh grated parmesian cheese. Mushrooms and tomatoes. Low carb. Keto friendly and Paleo friendly. DELICIOUS. 5 Share this post Link to post Share on other sites
TonyToro Jr. 2,560 #9344 Posted March 13 3 minutes ago, ebinmaine said: Supper was home scratch made Chicken Alfredo. The "noodle" was spiraled fresh zucchini. Fresh grated parmesian cheese. Mushrooms and tomatoes. Low carb. Keto friendly and Paleo friendly. DELICIOUS. That sounds very good! 2 1 Share this post Link to post Share on other sites
953 nut 70,648 #9345 Posted March 13 9 hours ago, ebinmaine said: . it doesn't work. It worked if the thumping of the flat spotted tire isn't a deal breaker. Not like it was a total flat spot, just not totally round. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #9346 Posted March 13 31 minutes ago, 953 nut said: It worked if the thumping of the flat spotted tire isn't a deal breaker. Not like it was a total flat spot, just not totally round. That may be workable on a lightweight machine. Share this post Link to post Share on other sites
ebinmaine 81,278 #9347 Posted March 13 34 minutes ago, TonyToro Jr. said: That sounds very good! Excellent!!! Share this post Link to post Share on other sites
Pullstart 71,561 #9348 Posted March 16 On 1/16/2023 at 8:39 AM, Pullstart said: I taught Rylee how to drive a stick shift yesterday. Whilst teaching her the fundamentals, like holeshots and donuts, I explained that she likely can’t break it. That became a challenge I guess. Once I turned her and her sisters loose, they decided jumping the rock pile was the next best idea. Kids. Upon a landing, the gas tank was ripped out and they kept driving until it ran out of gas. Where she got this kind of hillbilly mischief from, I have no idea. While they were walking home, someone called the cops on them for tearing up a field. I am thankful for neighbors or passers by for caring, but it was fun explaining that it is our field, our Jeep, our kids. Three years this thing’s been sitting with a rotten frame and a missing fuel tank. I picked up this ‘04 right hand drive Jeep tub and frame this weekend. There are a handful of brackets related to steering and track bars that need to be swapped from the green Jeep frame to the donor frame. But the frame itself is in much better shape than the other. No soft spots and no holes I can nearly stick my fist through! I do not plan on getting this project done any time soon, but it’ll be safe until then. IMG_2713.mov 8 Share this post Link to post Share on other sites
953 nut 70,648 #9349 Posted March 16 3 hours ago, Pullstart said: I do not plan on getting this project done any time soon, but it’ll be safe until then. SOOOOOO! is this project going to be ahead of or behind the dump truck project? 3 Share this post Link to post Share on other sites
Pullstart 71,561 #9350 Posted March 17 12 hours ago, 953 nut said: SOOOOOO! is this project going to be ahead of or behind the dump truck project? That’s a Colossal question! 5 1 Share this post Link to post Share on other sites
