Blue Chips 834 #10001 Posted September 5 I'm converting the oiling system in my M37's 230 engine to full-flow filtration. Here's what I've done so far: Drilled holes into the output passage from the pump for the IN and OUT ports, and tapped them for 1/4" NPT: Tapped the supply passage from the pump, straight thread 9/16-18. Used three taps, ending with a bottoming tap to form a nice 'shelf' to tighten the plug against: Installed the plug between the IN and OUT ports. It came out perfectly placed between the port threads, so it won't interfere with the flow at all. Secured with Loctite 592. Possible plumbing setup shown below (final setup to be decided after I determine where the remote oil filter will be mounted). I have plenty of clearance everywhere. The closest point will be about 3/8" from the edge of the valve compartment cover after all the fittings are tightened. These fittings are shown loose; they will drop down further when tightened, and I'll be shortening the taller stainless pipe by about 1/8 inch. I was originally going to use 1/4" NPT to AN-6 fittings in the threaded IN and OUT ports, but the NPT to AN-6 fittings I've seen had a smaller inside diameter than 1/4" NPT pipe, so I went with 1/4" stainless pipe going to AN-8 fittings instead of AN-6, so I should have a full 3/8" inside diameter all the way from the block to the filter and back. Here are the plumbing parts for the full-flow setup. I shopped around quite a bit and cobbled these together from multiple sources: 4 Share this post Link to post Share on other sites
adsm08 5,035 #10002 Posted September 5 This morning I started putting my radio in the new Explorer. Mounting bracket doesn't fit right, so that's on hold. About that time the wife got home and we have been working on the new shed ever since. 1 Share this post Link to post Share on other sites
953 nut 68,661 #10003 Posted September 5 49 minutes ago, adsm08 said: wife got home and we have been working on the new shed ever since. Share this post Link to post Share on other sites
adsm08 5,035 #10004 Posted September 5 1 hour ago, 953 nut said: More like 3 Share this post Link to post Share on other sites
ebinmaine 80,426 #10005 Posted September 5 2 hours ago, Blue Chips said: oiling system ****** full-flow filtration I've had one many years ago on a Chevy 350. Of late I've been looking at doing so on my truck. The info I'm finding online shows that it isn't the best idea for a 300 inline six. Apparently the oil system is extremely strong and known to crack & blow out filters when clogged. 1 Share this post Link to post Share on other sites
Blue Chips 834 #10006 Posted September 5 (edited) 46 minutes ago, ebinmaine said: I've had one many years ago on a Chevy 350. Of late I've been looking at doing so on my truck. The info I'm finding online shows that it isn't the best idea for a 300 inline six. Apparently the oil system is extremely strong and known to crack & blow out filters when clogged. Yeah, if an oil pressure relief valve sticks closed, most lubrication systems can build up enough pressure to pop an oil filter cartridge. It happened to me once on a 360 cid Ford. A piece of debris, such as heavy dirt that got through a torn filter, or a bit of metal from a broken pressure relief valve spring, are some examples of a possible cause for a stuck valve. Even exceptionally heavy sludge can cause a valve to stick in some instances. Some motor oil additives for dissolving sludge can dislodge a lot of gunk in the passages that could make its way to the relief valve and cause it to stick. This will be a very clean engine, with a new spring on the pressure relief valve, and all passages thoroughly cleaned, so it shouldn't be any more likely to stick closed than a brand new engine. Edited September 5 by Blue Chips 1 Share this post Link to post Share on other sites
ebinmaine 80,426 #10007 Posted September 6 Trina and her momma moved and rebuilt the fire pit. 🔥 We're testing it out now. This also gives the benefit of making the back patio much larger. 1 1 Share this post Link to post Share on other sites
adsm08 5,035 #10008 Posted September 6 On 9/5/2026 at 5:33 PM, ebinmaine said: I've had one many years ago on a Chevy 350. Of late I've been looking at doing so on my truck. The info I'm finding online shows that it isn't the best idea for a 300 inline six. Apparently the oil system is extremely strong and known to crack & blow out filters when clogged. I understand the appeal to full-flow, but bypass is safer. 1 Share this post Link to post Share on other sites
8ntruck 9,239 #10009 Posted September 7 I've been spending several hours per day over the last few days to work on the 'remodel' of our new A Liner camper. The plumbing and refrigerator are now gone and the cabinet where they were is a couple three hours away from becoming a dog crate. Part of the 'remodel' was to remake the front cabinet panel and giving the inside of the cabinet a better dog safe finish. Today's progress finished when I had to wait for paint to dry. Lots of fiddling to fit paneling around a wheel well and a couple of other obstacles. Hopefully, i can get it completely back together tomorrow. Pictures to follow. My wife's cousin owns one of the lakefront cottages across the street from us. He is considering moving full time to the lake. To do that, he has to shed some of the shop equipment that he has amassed over the years. He was wondering if I might be interested in a Grizzly bench top mill. Shure, I says. How much? He came back with a price I could not say no to. I guess I've just acquired a bench top mill. Delivery and payment arrangements are TBD. 3 1 Share this post Link to post Share on other sites
Ed Kennell 47,054 #10010 Posted September 8 Had a great Labor Day family picnic. We picked the blue claws, then burgers, corn, potato salad, baked beans, and apple pie. Then played Bocce Ball, corn hole and tractor rides with my favorite Grand Nephew. 5 5 Share this post Link to post Share on other sites
ML3 2,485 #10011 Posted September 10 On 9/5/2026 at 3:35 PM, 953 nut said: When we moved a few years ago & significantly downsized. Had a 4 bedroom 3700sq/ft ranch w/full basement. Now in a 1000sq/ft ranch on a slab- no regrets! I promised her since we really dont have room for her hobbies/crafts etc that I'd have a she shed built. Great decision. Ran electric & is insulated w/heat so she can use it all year. 5 1 Share this post Link to post Share on other sites
ebinmaine 80,426 #10012 Posted September 10 I'm SOOOOO glad my S/O is such a not girly girl. 2 Share this post Link to post Share on other sites
953 nut 68,661 #10013 Posted September 10 12 minutes ago, ebinmaine said: I'm SOOOOO glad my S/O is such a not girly girl. You gave her a log splitter, what more could a girl ask for. 1 1 3 Share this post Link to post Share on other sites
ebinmaine 80,426 #10014 Posted September 10 3 minutes ago, 953 nut said: You gave her a log splitter, what more could a girl ask for. Logs..... I guess ???? 3 1 Share this post Link to post Share on other sites
953 nut 68,661 #10015 Posted September 10 1 minute ago, ebinmaine said: Logs..... I guess ???? As I understood it BBT loaded the trailer and you took the pictures. 1 Share this post Link to post Share on other sites
ebinmaine 80,426 #10016 Posted September 11 20 minutes ago, 953 nut said: As I understood it BBT loaded the trailer and you took the pictures. You're close. 5 tractors. I loaded one. That's it. And she took the pics too. 28 minutes ago, 953 nut said: You gave her a log splitter I should also probably clarify... SHE bought the log splitter too. 2 Share this post Link to post Share on other sites
rjg854 13,327 #10017 Posted September 11 13 hours ago, ebinmaine said: You're close. 5 tractors. I loaded one. That's it. And she took the pics too. I should also probably clarify... SHE bought the log splitter too. she probably got tired of splitting all that wood by hand 2 Share this post Link to post Share on other sites
ebinmaine 80,426 #10018 Posted September 11 4 hours ago, rjg854 said: she probably got tired of splitting all that wood by hand That was years ago. Back about 7 or 8 years maybe?? She bought the one we had been using. It was a beast as well. 80s vintage commercial splitter that was modified by a local logger for splitting the butt ends of lower stumps. Trina's daughter will get that now that Trina has moved up to the dual action splitter. 1 Share this post Link to post Share on other sites
8ntruck 9,239 #10019 Posted September 12 (edited) Finally got around to getting pictures of the A Liner camper 'remodel '. Here is where we ended up: Here is where we started: The addition is a crate for our dog's sleeping quarters. The refrigerator, sink and associated plumbing is gone. The refrigerator will be installed in our small Coleman travel trailer, and the sink will become an outdoor camp sink on our property in Ky. Took a cross state jaunt yesterday to pick up a few parts for EJ, the 8n from Steiner Tractor Parts. Got a couple of odds and ends for a couple of neighbor's tractors - a Massey Harris 40 and a Ferguson TO-35. Edited September 12 by 8ntruck 3 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,233 #10020 Posted September 12 Had today off so hit a tractor museum in Perth Australia, about an hour north of where I’m at. Almost all farm tractors but they did have one that was “WH size” called Howard. Had my Lawn/Garden tractor mag with me, perfect for a picture! And yes, I wore one of my WHCC shirts 3 5 2 Share this post Link to post Share on other sites
ebinmaine 80,426 #10021 Posted September 12 @Sparky Niiiiice Share this post Link to post Share on other sites
Ed Kennell 47,054 #10022 Posted September 12 His USA cousin. 6 Share this post Link to post Share on other sites
8ntruck 9,239 #10023 Posted Sunday at 08:20 PM We finally got the side yard at the lake house seeded where the mess was made when the neighbor drilled a new well. Some rain started just as we were finishing spreading straw over the seed. Pretty good timing. 4 Share this post Link to post Share on other sites
MainelyWheelhorse 3,057 #10024 Posted Sunday at 09:24 PM (edited) After work, I started to clean up and look over the hydraulics and the other parts I got from @ebinmaine. they’re in pretty good shape, so I shouldn’t have to do much to get them working. Edited Sunday at 09:28 PM by MainelyWheelhorse 3 Share this post Link to post Share on other sites
ohiofarmer 3,472 #10025 Posted 3 hours ago (edited) We started a charity job for a cancer family today . Tear out a tub and replace it with a shower . As you can see it was in tough shape but the treatments and all that goes with it took priority. First it was me and my brother taking down tikes and wet drywall,but as the job progressed we started learning just how much the multi tool could do without destroying too much at once. Two of the sons started trying out the tool and when it came time to break up the cast iron tub, they made it their own . They gave each other the business like brothers do and it was a good day. I just learned to advise them when to be careful and why The last picture is an installation I did on my rental house and the shower is a Sterling brand shower which is a Kohler company. Once the base is set the walls are pretty easy. My brother and I are bone tired and both are proud of the grandsons. Edited 3 hours ago by ohiofarmer 2 Share this post Link to post Share on other sites
