Blue Chips 834 #10001 Posted September 5 I'm converting the oiling system in my M37's 230 engine to full-flow filtration. Here's what I've done so far: Drilled holes into the output passage from the pump for the IN and OUT ports, and tapped them for 1/4" NPT: Tapped the supply passage from the pump, straight thread 9/16-18. Used three taps, ending with a bottoming tap to form a nice 'shelf' to tighten the plug against: Installed the plug between the IN and OUT ports. It came out perfectly placed between the port threads, so it won't interfere with the flow at all. Secured with Loctite 592. Possible plumbing setup shown below (final setup to be decided after I determine where the remote oil filter will be mounted). I have plenty of clearance everywhere. The closest point will be about 3/8" from the edge of the valve compartment cover after all the fittings are tightened. These fittings are shown loose; they will drop down further when tightened, and I'll be shortening the taller stainless pipe by about 1/8 inch. I was originally going to use 1/4" NPT to AN-6 fittings in the threaded IN and OUT ports, but the NPT to AN-6 fittings I've seen had a smaller inside diameter than 1/4" NPT pipe, so I went with 1/4" stainless pipe going to AN-8 fittings instead of AN-6, so I should have a full 3/8" inside diameter all the way from the block to the filter and back. Here are the plumbing parts for the full-flow setup. I shopped around quite a bit and cobbled these together from multiple sources: 4 Share this post Link to post Share on other sites
adsm08 5,006 #10002 Posted September 5 This morning I started putting my radio in the new Explorer. Mounting bracket doesn't fit right, so that's on hold. About that time the wife got home and we have been working on the new shed ever since. 1 Share this post Link to post Share on other sites
953 nut 68,501 #10003 Posted September 5 49 minutes ago, adsm08 said: wife got home and we have been working on the new shed ever since. Share this post Link to post Share on other sites
adsm08 5,006 #10004 Posted Saturday at 08:39 PM 1 hour ago, 953 nut said: More like 3 Share this post Link to post Share on other sites
ebinmaine 80,279 #10005 Posted Saturday at 09:33 PM 2 hours ago, Blue Chips said: oiling system ****** full-flow filtration I've had one many years ago on a Chevy 350. Of late I've been looking at doing so on my truck. The info I'm finding online shows that it isn't the best idea for a 300 inline six. Apparently the oil system is extremely strong and known to crack & blow out filters when clogged. 1 Share this post Link to post Share on other sites
Blue Chips 834 #10006 Posted Saturday at 10:18 PM (edited) 46 minutes ago, ebinmaine said: I've had one many years ago on a Chevy 350. Of late I've been looking at doing so on my truck. The info I'm finding online shows that it isn't the best idea for a 300 inline six. Apparently the oil system is extremely strong and known to crack & blow out filters when clogged. Yeah, if an oil pressure relief valve sticks closed, most lubrication systems can build up enough pressure to pop an oil filter cartridge. It happened to me once on a 360 cid Ford. A piece of debris, such as heavy dirt that got through a torn filter, or a bit of metal from a broken pressure relief valve spring, are some examples of a possible cause for a stuck valve. Even exceptionally heavy sludge can cause a valve to stick in some instances. Some motor oil additives for dissolving sludge can dislodge a lot of gunk in the passages that could make its way to the relief valve and cause it to stick. This will be a very clean engine, with a new spring on the pressure relief valve, and all passages thoroughly cleaned, so it shouldn't be any more likely to stick closed than a brand new engine. Edited Saturday at 10:19 PM by Blue Chips 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #10007 Posted Sunday at 10:20 PM Trina and her momma moved and rebuilt the fire pit. 🔥 We're testing it out now. This also gives the benefit of making the back patio much larger. 1 1 Share this post Link to post Share on other sites
adsm08 5,006 #10008 Posted Sunday at 10:45 PM On 9/5/2026 at 5:33 PM, ebinmaine said: I've had one many years ago on a Chevy 350. Of late I've been looking at doing so on my truck. The info I'm finding online shows that it isn't the best idea for a 300 inline six. Apparently the oil system is extremely strong and known to crack & blow out filters when clogged. I understand the appeal to full-flow, but bypass is safer. 1 Share this post Link to post Share on other sites
8ntruck 9,216 #10009 Posted Monday at 12:52 AM I've been spending several hours per day over the last few days to work on the 'remodel' of our new A Liner camper. The plumbing and refrigerator are now gone and the cabinet where they were is a couple three hours away from becoming a dog crate. Part of the 'remodel' was to remake the front cabinet panel and giving the inside of the cabinet a better dog safe finish. Today's progress finished when I had to wait for paint to dry. Lots of fiddling to fit paneling around a wheel well and a couple of other obstacles. Hopefully, i can get it completely back together tomorrow. Pictures to follow. My wife's cousin owns one of the lakefront cottages across the street from us. He is considering moving full time to the lake. To do that, he has to shed some of the shop equipment that he has amassed over the years. He was wondering if I might be interested in a Grizzly bench top mill. Shure, I says. How much? He came back with a price I could not say no to. I guess I've just acquired a bench top mill. Delivery and payment arrangements are TBD. 3 1 Share this post Link to post Share on other sites
Ed Kennell 46,982 #10010 Posted Tuesday at 01:13 AM Had a great Labor Day family picnic. We picked the blue claws, then burgers, corn, potato salad, baked beans, and apple pie. Then played Bocce Ball, corn hole and tractor rides with my favorite Grand Nephew. 5 5 Share this post Link to post Share on other sites
ML3 2,479 #10011 Posted yesterday at 02:43 PM On 9/5/2026 at 3:35 PM, 953 nut said: When we moved a few years ago & significantly downsized. Had a 4 bedroom 3700sq/ft ranch w/full basement. Now in a 1000sq/ft ranch on a slab- no regrets! I promised her since we really dont have room for her hobbies/crafts etc that I'd have a she shed built. Great decision. Ran electric & is insulated w/heat so she can use it all year. 4 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #10012 Posted 20 hours ago I'm SOOOOO glad my S/O is such a not girly girl. 1 Share this post Link to post Share on other sites
953 nut 68,501 #10013 Posted 19 hours ago 12 minutes ago, ebinmaine said: I'm SOOOOO glad my S/O is such a not girly girl. You gave her a log splitter, what more could a girl ask for. 1 1 2 Share this post Link to post Share on other sites
ebinmaine 80,279 #10014 Posted 19 hours ago 3 minutes ago, 953 nut said: You gave her a log splitter, what more could a girl ask for. Logs..... I guess ???? 2 1 Share this post Link to post Share on other sites
953 nut 68,501 #10015 Posted 19 hours ago 1 minute ago, ebinmaine said: Logs..... I guess ???? As I understood it BBT loaded the trailer and you took the pictures. 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #10016 Posted 19 hours ago 20 minutes ago, 953 nut said: As I understood it BBT loaded the trailer and you took the pictures. You're close. 5 tractors. I loaded one. That's it. And she took the pics too. 28 minutes ago, 953 nut said: You gave her a log splitter I should also probably clarify... SHE bought the log splitter too. 1 Share this post Link to post Share on other sites
rjg854 13,310 #10017 Posted 6 hours ago 13 hours ago, ebinmaine said: You're close. 5 tractors. I loaded one. That's it. And she took the pics too. I should also probably clarify... SHE bought the log splitter too. she probably got tired of splitting all that wood by hand 1 Share this post Link to post Share on other sites
ebinmaine 80,279 #10018 Posted 1 hour ago 4 hours ago, rjg854 said: she probably got tired of splitting all that wood by hand That was years ago. Back about 7 or 8 years maybe?? She bought the one we had been using. It was a beast as well. 80s vintage commercial splitter that was modified by a local logger for splitting the butt ends of lower stumps. Trina's daughter will get that now that Trina has moved up to the dual action splitter. Share this post Link to post Share on other sites
