Mickwhitt
What did you do today?
953 nut
13 hours ago, 8ntruck said:
I was reading about hybred heat pump water heaters.
I have seen segments on them on "ask This Old House" and they seem quite interesting. They would be good in a damp basement because they also tend to act as a dehumidifier.
11 hours ago, lynnmor said:
I have been using a GE hybrid water heater for 15 years, the only issue was a factory fault that was fixed for free.  Installation is the same as a standard water heater but clearance around it is necessary so it can move air and a provision for the condensate water is needed.
Glad to hear from someone who actually has had experience with one.
OldWorkHorse
Well its finally cold and snow covered in maine. So unless im shoveling or snowblowing, I find myself indoors a lot this time of year. So being in my shop past few days I have realized I have acquired a bit of stuff. So I decided me and my little shop helper were going to organize a bit. Went to my local shopping center and noticed 27 gallon totes on clearance match the others I already have so I bought a few went home and packed some stuff inside of them. Nice shop looked a bit better and I wasnt tripping over wheel horse parts. But now the totes are everywhere. So we get back in the truck and head back into town to the lumber store and get some supplies. The shop helper and I decided to build a new work bench / wife's craft bench and under it make some totes storage. Came out pretty good and the organization is great. So much more room for activities!
  • Excellent 5
  • Heart 1
SylvanLakeWH
And she actually used a tape measure!!??!!?? :scared-eek:
:clap:
  • Haha 1
  • Heart 2
OldWorkHorse
:clap:
She's learning to use my power tools... waiting to get on my horse and it fall apart backing out the shop one afternoon 😂
  • Haha 2
  • Heart 1
Streetrodchev
This jolly ol’ feller and his bride needed a fire engine ride to go see all the littles at the hall.
  • Like 8
Ed Kennell
7 minutes ago, ebinmaine said:
1.4 miles each way and about half of that was through 8+ inches of snow.
Whew, I took a 1 hour walk around the farm with no snow and I'm ready for a nap.
  • Haha 3
ebinmaine
Me too.
Handy Don
1 hour ago, ebinmaine said:
Quite a good workout to get there. 1.4 miles each way and about half of that was through 8+ inches of snow.
With the snow, maybe not, but can you get a tractor in there via the old cart road?
ebinmaine
 Territory scoping was actually the very reason we walked in the way we did.
Following the old cart road in blue can't be done with machines but can be walked.  There are trees down blocking the path.
Following the green trail we went up.. yes. Part of it is a current snowmobile trail.
Our thought is too get better cutting tools in there and possibly harvest the wood.  It's all public access reserve land now.
Ed Kennell
A 1 hour walk, a 30 minute nap, then made the Swedish(venison) Meatballs for  the Christmas Eve gang. They'll be in the freezer till Christmas Eve morning, then go in the crock pot with the grape jelly, ketchup, mustard, and Worcestershire sauce.
  • Like 4
  • Excellent 2
lynnmor
Took the wife to her mammogram appointment only to find that PennDot wants my car to get cancer.  The road was sprayed with a liquid that has a 100% chance of causing cancer in vehicles, they even went into the medical center and sprayed. 🤬🖕🏿 Weather is to be clear for two days.
  • Sad 3
Handy Don
In the past, after exposure to this road treatment and when the outside temp got back above freezing, I’ve used a garden sprayer to liberally dose the undersides with a house cleaning detergent, allow time for penetration, and then rinse with low pressure hose.
Yes, a pain in the neck and I can’t prove it actually helped, but I traded that car in after 20 years with no rust.
lynnmor
I too try to rinse the crap out, not fun in freezing weather.  In past years the salt trucks made stripes on the road the current thing is to spray a mist that floats everywhere.  🥶
Handy Don
When my dad designed (and had me as labor to build) the new garage addition to the house of my teen years, he included a big French drain in the middle of the floor and a spigot with both cold and hot water feeds. Until the temps got really low, we were able to do a weekly car wash in the garage after a good warming pre-rinse without it freezing up. The condensation on the outside windows from the humidity generated did often freeze, though. I shudder to think about the energy cost of that today.
Beap52
When we were up in you're all's neck of the woods on vacation, I was amazed and appalled how rust done it's dirty deeds on vehicles. I've never seen rust like you all up north deal with.  A buddy and I were talking today that auto makers have produced vehicles long enough that they know where the rust prone locations are.  Of course they are in the business of selling us new vehicles.
We finished putting my pickup back together today.  Started out replacing front differential's oil seal on the driver's side of my 1992 GMC K2500.  We ended up dropping the differential because it simply wasn't possible to pull the axle s
o we replaced all three seals.  While front differential was down, it was excellent time to replace oil pan that was leaving drips in the garage. Then saw anti freeze drops on the lower radiator hose that was the result of my five year old water pump leaking.  Pulled the water pump and decided it was a good time to check timing chain after 235,000 miles which required dropping the oil pan again. The timing chain,  by the way, was in great shape.  (I'm from the age of when timing chains seldom lasted 100,000 miles and wanted to see the status of the chain.)  Before we put it back together, we flushed the oil cooler lines and cooler--which didn't contain much more than a big water glass full of oil.  I was relieved to see how clean the engine was inside.  There was probably less than a cup full of sludge in the oil pan.
I'm hoping the rear engine seal isn't  leaking because that requires pulling the transmission and transfer case.  I unscrewed the fill plug of the transfer case and fluid came gushing out which may indicate the rear transmission seal is leaking into the transfer case.  I'll keep an eye on the  fluid level of the  transfer case.  If the transmission rear seal is leaking then I'll take a look at the rear engine seal at some future date.
Ed Kennell
Made one of my faves that I learned to like while in Austria.  My pork schnitzel with sour cream gravy.
105_1723.JPG.30c26e1035a429dbfd152f8c2b78932f.JPG105_1724.JPG.bbb4401d333d5960a09c21a335a4aad4.JPG105_1725.JPG.26005ef486123386acc82bdc2ab92874.JPG
  • Excellent 6
ML3
3 day snow event here finally over.
Went to my mom's today to clean up driveway after her plow guy. Used dad's Troy Bilt GTX 20 w/Bervac. He bought it new in the 90s back when Troy Bilt was owned by Garden Way. Don't remember exactly what he paid but I know it was alot for tractor,  48" mower deck, 2stage Bervac, & plow blade. Really nice tractor. 20hp Vanguard, hi/lo rear axle, hydro, power steering, cruise, electric pto w/all implements shaft driven. Wish he would have got the available front loader. So at least this winter I get to use a one, just not mine yet ☹️
Sorry @Ed Kennell its not your old Bervac.....
  • Excellent 4
SylvanLakeWH
You can call me anything you want, just don't call me late for dinner...! :angry-tappingfoot:
Man that looks good!!! One of my favorites!
  • Haha 2
ebinmaine
I've had a Gardenway Troy Bilt snowblower. Very good to us.
That machine sounds quite rugged.
8ntruck
I dove into the medical system today to have a cataract in my left eye removed.  Outpatient surgery.  A very quick procedure accompanied by an interesting light show.
Immediate results.  I saw am immediate improvement in the recovery room.  It has been steadily improving as the day goes on.  My world is now in much better focus and the 'dirty glasses lens' feeling in my left eye is gone.
I'm on a 20 pound lifting restriction for a week.  That means I can't shovel the pile of snow that slid off of the roof into the driveway - oh darn!
  • Haha 1
rjg854
Sounds like some seat time then, if you're not restricted from that too.  :thumbs2:
Ed Kennell
Cataract removal ...another modern medical miracle.      When they removed my patched eye and I left the office, I could not find my wife's gray dodge mini van.  Finally I heard a horn blow and saw my wife in a tan van that we had been driving for over ten years.
I just got home from a 4 day vacation in the York Wellspan Hospital where I experienced another medical miracle.
Seems an artery in my upper sigmoid colon ruptured on Monday causing immediate massive blood loss.  Got me in the tube for a CT scan that was able to locate the exact artery.    Then got me stable enough to go in with the endoscope, find and cauterize  the leak with the laser.
Enjoy every day guys.  Ya never know when a hydraulic line may rupture.
  • Excellent 3
  • Heart 6
Handy Don
You continue to be an inspiration on this score, Ed.
Merry Christmas to you & Mrs K.
  • Heart 1
8ntruck
The plow is not on the 14-8, and won't fit the C-195. :(
Edited by 8ntruck
