8ntruck 7,939 #8801 Posted Sunday at 02:30 AM Thursday, I got out my 25 year old Craftsman 18" chain saw and cut a sizeable limb that has been laying behind the tractor shed for 3 or 4 years. It is in the way and time came for it to go. This spring, when I last used this saw, I noted that the dome in the primer pump had a small split in it. Not enough to leak, but enough so i did not trust taking the saw into the woods for serious work. Worked fine to cut that limb into firewood sized pieces, though. I bought a new dome, but discovered that this primer pump is not rebuildable. New pump is on order. The bottom of the saw case was covered in bar oil. Guess I forgot to empty the bar oil tank before I put it away last time. I suppose I'd ought to chase that leak down someday. Then again, draining the oil tank after use is easier..... Today, I split the wood. I put Pack Rat, the Allis Chalmers B110, to work hauling the resulting cart load of split firewood down to the lake house wood pile. Treated Pack Rat to a new air filter element, too. 5 Share this post Link to post Share on other sites
ebinmaine 73,237 #8802 Posted Sunday at 12:00 PM 9 hours ago, 8ntruck said: The bottom of the saw case was covered in bar oil. Guess I forgot to empty the bar oil tank before I put it away last time. I suppose I'd ought to chase that leak down someday. Then again, draining the oil tank after use is easier..... I have 3 gas powered saws and Trina has a battery powered one. ALL of them leak bar oil over time. Some have a much shorter leakdown period than others. For her battery saw and at least one of my gas saws, laying them on their right side - fill cap UP - prevents or dramatically slows the leakage. I find that counterintuitive considering the now down-facing side is the actual side the oil should come from ... but it works. 🤔 3 Share this post Link to post Share on other sites
lynnmor 7,890 #8803 Posted Sunday at 02:15 PM My chainsaws, all 7 of them, leak very little or no chain oil and I never drain them. Of course there is always some residual oil slowly draining from any chainsaw so I keep bed pads under them. 2 Share this post Link to post Share on other sites
19richie66 17,684 #8804 Posted Sunday at 04:01 PM Got all my rafters painted and ready for metal. Hopefully in the next couple weeks it will finally be covered. 7 4 Share this post Link to post Share on other sites
Sparky-(Admin) 23,394 #8805 Posted Tuesday at 08:41 PM Pedaled about 60 miles this weekend, including the 22 miles I did with my 81 year old mom today. And No… we aren’t on E-bikes. Pure people power 1 2 5 Share this post Link to post Share on other sites
ebinmaine 73,237 #8806 Posted Tuesday at 08:45 PM @Sparky VERY IMPRESSIVE Share this post Link to post Share on other sites
WHX?? 52,059 #8807 Posted Tuesday at 08:56 PM Your a real hero Sparky I wouldn't make out of the driveway. Well now if I had some captains n coke in that there bottle I might make it 1/2 mile to the end of the road. Then have to turn around back home for a refill... Got my bell rung... Picked it for free off a scrap pile. Who would throw stuff like that out Sylvia? 1 1 3 1 Share this post Link to post Share on other sites
wallfish 18,317 #8808 Posted Tuesday at 10:22 PM 1 hour ago, Sparky said: Pure people power That's awesome she can still do that il_600x600.1796234518_jyek.webp il_600x600.1796234518_jyek.webp 6 Share this post Link to post Share on other sites
SylvanLakeWH 28,780 #8809 Posted Tuesday at 11:20 PM 2 hours ago, WHX?? said: Picked it for free off a scrap pile. Who would throw stuff like that out Sylvia? Always gets my blood going... That would be a perfect "Gottanother Wheel Horse" bell!!! Kinda like tip bells in bars... Ya know, let Cindaaaaaay prepare for a new or three... 4 3 Share this post Link to post Share on other sites
adsm08 3,402 #8810 Posted yesterday at 01:47 AM Getting closer with the Escape: I did a little more fitting and trimming after this was taken. I still probably need to trim the edges a bit, and then I'll start welding it in. I drilled the top flange for rosettes, and then once I get the top welded in place I'll have to stick a jack under the bottom and push it into place because the bend isn't quite the same angle as the original piece. This one is a tad taller overall. 1 Share this post Link to post Share on other sites
8ntruck 7,939 #8811 Posted 8 hours ago As @Pullstart pointed out in his pool project thread, it rained in this neck of the woods today. Probably my fault. I slopped a coat of Thompsons Water Seal on the deck of my utility trailer yesterday afternoon. Today's rain sure beaded up nicely on the trailer. I've got a 10" Black & Decker chainsaw that is handy for taking care of 3 or 4 inch limbs the wind brings down from time to time. I've come to recognize that it is the wrong tool to try to do the work of a gas saw even for a job of 4 or 5 cuts. The kind of small job where it is not worth getting the gas saw out and messing fuel and chain oil. Yesterday, I noticed a display of Milwaukee M18 chain saws at the local hardware store. These things will go head to head with a gas saw. The light came on - I NEED ONE! The Milwaukee saws are attractive me because I already have tools on the same battery system. They are using Oregon bars and chains on these, so a replacement or length change won't be a hassle. Now, which one? The 8" one hander they call the Hatchet, a 12" or 14" top handle saw, or a 14" or 16" back handle saw? For some reason, the top handle saws are $70 more expensive. Right now, i'm leaning towards the back handle saws. 2 Share this post Link to post Share on other sites
adsm08 3,402 #8812 Posted 8 hours ago I still need to clean up and inspect the front bead, and probably go over the top one once more, but I'm sitting right on the floor, cross-legged, in a space about the width of a creeper, and I'd been at it an hour and a half already. 1 Share this post Link to post Share on other sites
Wayne0 1,269 #8813 Posted 8 hours ago (edited) 23 minutes ago, 8ntruck said: As @Pullstart pointed out in his pool project thread, it rained in this neck of the woods today. Probably my fault. I slopped a coat of Thompsons Water Seal on the deck of my utility trailer yesterday afternoon. Today's rain sure beaded up nicely on the trailer. I've got a 10" Black & Decker chainsaw that is handy for taking care of 3 or 4 inch limbs the wind brings down from time to time. I've come to recognize that it is the wrong tool to try to do the work of a gas saw even for a job of 4 or 5 cuts. The kind of small job where it is not worth getting the gas saw out and messing fuel and chain oil. Yesterday, I noticed a display of Milwaukee M18 chain saws at the local hardware store. These things will go head to head with a gas saw. The light came on - I NEED ONE! The Milwaukee saws are attractive me because I already have tools on the same battery system. They are using Oregon bars and chains on these, so a replacement or length change won't be a hassle. Now, which one? The 8" one hander they call the Hatchet, a 12" or 14" top handle saw, or a 14" or 16" back handle saw? For some reason, the top handle saws are $70 more expensive. Right now, i'm leaning towards the back handle saws. I picked up a cheap China 40 volt 16" saw on the jungle. $100 on sale. I just wanted something I could cut a branch or something. For what I paid, it's awesome. It won't replace my Stile, but for little jobs, it works. Edited 8 hours ago by Wayne0 2 Share this post Link to post Share on other sites
ebinmaine 73,237 #8814 Posted 7 hours ago 23 minutes ago, 8ntruck said: Now, which one? The 8" one hander they call the Hatchet, a 12" or 14" top handle saw, or a 14" or 16" back handle saw? For some reason, the top handle saws are $70 more expensive. Right now, i'm leaning towards the back handle saws 1 minute ago, Wayne0 said: I picked up a cheap China 16" saw on the jungle. $100 on sale. I just wanted something I could cut a branch or something. For what I paid, it's awesome. It won't replace my Stile, but for little jobs, it's great. Trina has a Kobalt battery powered saw with a 14" bar. It'll run one battery charge to a tank of gas in my Echo 33cc or Stihl MS180C. You're limited to the battery discharge/ recharge time. Multiple batteries would be handy. Power is good. Chain cut is good. 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,780 #8815 Posted 7 hours ago I have the 20v dewalt saw and pole saw. Outstanding performance. 1 Share this post Link to post Share on other sites
