rmaynard 16,166 #8251 Posted May 31 2 hours ago, ebinmaine said: Neat containers but any oil will settle. The Additive Package will be in a sludge at the bottom... I'm going to pour it into a glass measure before using. I will report any sludge problems. I would imagine that if I just poured it into the engine it would mix pretty rapidly anyway. 5 Share this post Link to post Share on other sites
MainelyWheelhorse 1,331 #8252 Posted June 1 (edited) Today on this gray rainy day, I took some tractor parts to my parents to be welded/machined. I also started drilling out a granite house number post to mount the plate next to it. . it’s going to take a while…. Edited June 1 by MainelyWheelhorse 3 Share this post Link to post Share on other sites
ebinmaine 71,748 #8253 Posted June 1 30 minutes ago, rmaynard said: I'm going to pour it into a glass measure before using. I will report any sludge problems. I would imagine that if I just poured it into the engine it would mix pretty rapidly anyway. Take pictures if you remember I'd be curious to see it. 2 Share this post Link to post Share on other sites
HyperPete 787 #8254 Posted June 1 (edited) 4 hours ago, ebinmaine said: We spent several hours in the barn building. Organizing. Swapping positions of items. Removing things from totes. Putting things in totes. Moving from upstairs to downstairs. Moving from downstairs to upstairs. Even swapped some things building to building. Also did some construction. Trina and her momma built in another place for storage upstairs. I started assembly on the new exercise rack. I get tired just reading all you do. ----- Today I flushed & refilled the coolant in the Mahindra & greased all fittings. Cleaned it pretty well, and ordered all 5 filters, a fuel filter float bowl, & manual. Need to buy 6 gallons of universal hydraulic fluid & 5 quarts diesel oil (Rotella 15W40). Adjusting brakes & replacing the WP/Alternator belt is on the list, too. Previous owner wasn't good with maintenance. 🥺 See "coolant", below. Edited June 1 by HyperPete 3 1 1 1 Share this post Link to post Share on other sites
ebinmaine 71,748 #8255 Posted June 1 36 minutes ago, HyperPete said: I get tired just reading all you do. Me too buddy. Me too. And today's work was all in a 3 hour span. We took the morning "off". This evening we met some friends for a good meal out. 2 1 Share this post Link to post Share on other sites
Razorback 1,091 #8256 Posted June 1 (edited) We mowed the yard yesterday evening (our lot is almost an acre, mostly back yard). Today, I got the Wheel Horse out and aerated the yard first, then installed the cultivators and took care of the garden. I made myself a promise that I would make a point of keeping up with the garden this year, to NOT EVER have to MOW IT this year! So far, so good. Picked a bucket full of leaf lettuce, the first of the season, and enjoyed the heck out of that this evening. Edited June 1 by Razorback 6 1 Share this post Link to post Share on other sites
8ntruck 7,610 #8257 Posted June 2 I woke EJ the 8N up from his winter hibernation. Did a little brush hogging, and moved some limestone blocks around with a strong arm. Had a bit of an oopsie, though. Found myself rolling backwards down a hill in neutral with marginal brakes. Took an unexpected ride into the puckerbrush before I ended up against a tree. Got lucky - nothing damaged, no injuries. I've really got to at least get the brakes cleaned - pretty sure the axle seals are kaput. 1 1 2 Share this post Link to post Share on other sites
Pullstart 65,658 #8258 Posted June 3 @8ntruck I’ll see you in the bumps and bruises pal! I went through the 13 pages of buy sell trade and made a list of what I committed to. Forgot about most of it! 5 Share this post Link to post Share on other sites
8ntruck 7,610 #8259 Posted June 4 More work out in the woods. I did some work with my brush saw clearing the undergrowth in the next 100 yards of future driveway. Next step is to do chainsaw work on the many trees too big for the brush saw. Temperature here near 90 - thats OK, the humidity is low. But enough was enough. Ran the string trimmer up and down the 200' of roadside ditch and trimmed along the driveway I have roughed in - again, enough is enough in that heat. While I was trimming on the ditch and driveway, I suddenly realized that a 3 or 4 foot sickle bar on a Wheel Horse would make that task considerably easier. Always thought that they were neat, but really didn't have need for one. Guess I just thought of a use. With the heat kind of messing up my physical labor work plans, I went to one of the local tractor dealers and treated EJ the 8N to a Bad Boy 6' box blade. Got it back to the property and played with it while moving it to its storage spot. Just one pass makes the driveway look much better. Once I get the blade tilt tuned in and develop my touch on the lift lever refined, I think it will do what I want. 2 1 Share this post Link to post Share on other sites
SkyCrafter 5 #8260 Posted June 4 Wow, sounds like a seriously tough day! Not the kind of “tractor work” you had in mind, I’m sure. Glad you managed to sort out the repair—hope tomorrow’s backfilling goes a bit more smoothly! 💪🚜 1 Share this post Link to post Share on other sites
Pullstart 65,658 #8262 Posted June 4 I trimmed up a tool box to clear my fuel transfer tank, then added a short box bed cover to Norman. 2 3 Share this post Link to post Share on other sites
Handy Don 13,640 #8263 Posted June 5 On 6/3/2025 at 9:25 PM, 8ntruck said: While I was trimming on the ditch and driveway, I suddenly realized that a 3 or 4 foot sickle bar on a Wheel Horse would make that task considerably easier. Always thought that they were neat, but really didn't have need for one. Guess I just thought of a use. Sickles can be vulnerable to damage from stones, larger saplings, broken branches, etc. You might consider a flail mower instead--much less vulnerable to damage. They are not easy to find but not too difficult to adapt. Share this post Link to post Share on other sites
Beap52 1,330 #8264 Posted June 5 On 6/4/2025 at 6:49 AM, Pullstart said: I trimmed up a tool box to clear my fuel transfer tank, then added a short box bed cover to Norman. I'll bet the locals at the gas station wonder why you're filling your tool box with fuel. Actually that's a pretty neat setup your made for yourself. 1 Share this post Link to post Share on other sites
8ntruck 7,610 #8265 Posted June 6 6 hours ago, Handy Don said: Sickles can be vulnerable to damage from stones, larger saplings, broken branches, etc. You might consider a flail mower instead--much less vulnerable to damage. They are not easy to find but not too difficult to adapt. Good thought. The ditch is lined with small rip rap. A flail mower won't care so much about that. Might be a little noisy, though. Share this post Link to post Share on other sites
19richie66 17,598 #8266 Posted June 6 Woke up and planted my feet on the floor. It’s a good day. 2 5 1 2 Share this post Link to post Share on other sites
Ed Kennell 41,289 #8267 Posted June 6 8 minutes ago, 19richie66 said: Woke up and planted my feet on the floor. It’s a good day. Yep, always good to wake up on the green side. 3 3 Share this post Link to post Share on other sites
ebinmaine 71,748 #8268 Posted June 6 10 minutes ago, 19richie66 said: Woke up and planted my feet on the floor. It’s a good day. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 22,771 #8269 Posted June 6 My push mower identifies as a “motorcycle” …oil change day 5 Share this post Link to post Share on other sites
ebinmaine 71,748 #8270 Posted June 6 4 hours ago, Sparky said: My push mower identifies as a “motorcycle” …oil change day WTH is METRIC OIL ??!!??? 4 Share this post Link to post Share on other sites
SylvanLakeWH 28,070 #8271 Posted June 6 11 minutes ago, ebinmaine said: WTH is METRIC OIL ??!!??? Specifically formulated for engines with metric thread fill caps... it "reads" the thread as it enters the funnel, calibrates to the precise metric diameter of the hole necessary to fill the engine to spec, and then, like all 10mm sockets, quietly disappears into the ether... 1 7 1 Share this post Link to post Share on other sites
ebinmaine 71,748 #8272 Posted June 6 5 minutes ago, SylvanLakeWH said: Specifically formulated for engines with metric thread fill caps... it "reads" the thread as it enters the funnel, calibrates to the precise metric diameter of the hole necessary to fill the engine to spec, and then, like all 10mm sockets, quietly disappears into the ether... So @Pullstart has a hand in this??? 5 Share this post Link to post Share on other sites
SylvanLakeWH 28,070 #8273 Posted June 6 16 minutes ago, ebinmaine said: So @Pullstart has a hand in this??? Oh heck no... rumor has it he's been seen with a non- lately ... Now maybe @Achto or @WHX?? been doin' weird curd-like things up nord... who knows what goes into their 's... 3 Share this post Link to post Share on other sites
Sparky-(Admin) 22,771 #8274 Posted June 6 1 hour ago, ebinmaine said: WTH is METRIC OIL ??!!??? LOL! Leftover oil from my motorcycle days (Suzuki) 3 Share this post Link to post Share on other sites
adsm08 2,936 #8275 Posted June 7 2 hours ago, ebinmaine said: WTH is METRIC OIL ??!!??? It's bottled in liters, not quarts. 2 3 Share this post Link to post Share on other sites
