midpack 1,147 #26 Posted June 8, 2020 34 minutes ago, ranger said: be very careful of any sparks when connecting/disconnecting leads. yeah, I make sure it's connected well before I open any tanks or cans. then it's just a toggle switch to activate the pump 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #27 Posted June 8, 2020 You can use a rubberballpump instead as sometimes on outboard engines used. 1 Share this post Link to post Share on other sites
echris 1,426 #28 Posted June 14, 2020 So many great tips here. The first time I remove the mule drive from my 310-8, it was jammed up pretty good. Previous owner had the belt on the outer pulley on the engine, so the mule was almost all the way out and jammed. I DID NOT want to break the mule knob, so I grabbed a heavy rag and my small oil filter strap wrench and she came loose, no marks, no cracks. Nice one @pullstart I'll often bend a piece of cardboard to funnel oil into the pan. My daily driver is a 2007 Accord. There's no point. Just let it run everywhere, clean it up later. They designed it that way. Hey, the car was free. 1 Share this post Link to post Share on other sites
Shynon 7,604 #29 Posted June 17, 2020 Made these bushing drivers for the 5003/5010 transmission to press in the differential bushing and axle bushings. Also made for 1" and 1 1/8" axle bearing and seal drivers, puts the bearing to correct depth with the step. Then installs the seal little recessed from the axle casr. 8 7 Share this post Link to post Share on other sites
WHX?? 57,278 #30 Posted June 18, 2020 Old news ther i got them pics saved Tom but thanks for reminding me to get a lathe! Now you need to come help me out recondoing the shop to get a machine tool in! 1 Share this post Link to post Share on other sites
Shynon 7,604 #31 Posted June 18, 2020 32 minutes ago, WHX24 said: Old news ther i got them pics saved Tom but thanks for reminding me to get a lathe! Now you need to come help me out recondoing the shop to get a machine tool in! 2 Share this post Link to post Share on other sites
WHX?? 57,278 #32 Posted June 18, 2020 Not quite as elegant as Tom's....... 2 Share this post Link to post Share on other sites
Digger 66 3,530 #33 Posted June 18, 2020 On 4/5/2020 at 6:10 PM, formariz said: Show us the tools you have made and use. Not really a "tool" but my home-brewed method for cleaning Bosch fuel injectors . (Link to my how-to post on Aurora Wheelers forum) https://www.can-amforum.com/threads/home-brewed-fuel-injector-cleaner.133400/ Share this post Link to post Share on other sites
formariz 12,379 #34 Posted June 18, 2020 It’s not always about wood here. Here is another tool I made for my other activity. Share this post Link to post Share on other sites
prondzy 3,889 #35 Posted June 19, 2020 19 hours ago, formariz said: It’s not always about wood here. Here is another tool I made for my other activity. care to elaborate? Share this post Link to post Share on other sites
formariz 12,379 #36 Posted June 20, 2020 On 6/19/2020 at 6:40 AM, prondzy said: care to elaborate? Its a "parrot" . Used while distilling for constant monitoring of alcohol proof. 2 2 5 Share this post Link to post Share on other sites
edgro 680 #37 Posted June 21, 2020 homemade welding cart / clamp & vicegrip holder 9 Share this post Link to post Share on other sites
ebinmaine 79,519 #38 Posted June 26, 2020 Tool. Noun. A device or implement used to carry out a particular function. This one maybe just a little bit loose fitting into that definition but it's there. Shop rags. Duct tape. And what you get is a forearm protector for carrying firewood. Inventor, BBT. 1 1 3 Share this post Link to post Share on other sites
Pullstart 70,447 #39 Posted September 25, 2020 Fuel Line Disconnect Tool 2 Share this post Link to post Share on other sites
squonk 47,276 #40 Posted September 27, 2020 My hub puller 1 1 Share this post Link to post Share on other sites
JPWH 6,544 #41 Posted September 27, 2020 Table saw fence. For my Walker Turner table saw. 1 4 1 Share this post Link to post Share on other sites
JPWH 6,544 #42 Posted September 27, 2020 Small hydraulic press. The bracket on the left side is for holding a Kohler engine block. I just clamp it down when I need it. 5 Share this post Link to post Share on other sites
JPWH 6,544 #43 Posted September 27, 2020 Media blast cabinet. 48" wide by 30" deep. My hobby budget is not enough to buy large tools so I have to get creative at times. 4 1 Share this post Link to post Share on other sites
ebinmaine 79,519 #44 Posted September 27, 2020 1 hour ago, JPWH said: hydraulic press That's one of my "someday" welding projects. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #45 Posted October 7, 2020 On 4/17/2020 at 11:24 PM, formariz said: Some of mine. Wow! 2 Share this post Link to post Share on other sites
Pullstart 70,447 #46 Posted November 25, 2020 This, I did not make. I did however, modify it for my needs. It is not quite OSHA any longer. It does work great for it’s purpose. It is a flush cut saw, I think. I modified it to cut on a negative angle, like 5 degrees maybe? Without the guard or fence, I can flush cut a floor out if it’s rotten, right along the edge of the room. 1 Share this post Link to post Share on other sites
prondzy 3,889 #47 Posted November 26, 2020 On 6/26/2020 at 2:21 PM, ebinmaine said: Tool. Noun. A device or implement used to carry out a particular function. This one maybe just a little bit loose fitting into that definition but it's there. Shop rags. Duct tape. And what you get is a forearm protector for carrying firewood. Inventor, BBT. Looks to me like a Man-daid i usually wrap a cut in a shop rag and wrap with electrical tape until she stops bleeding so i can keep working. 1 2 Share this post Link to post Share on other sites
ebinmaine 79,519 #48 Posted November 26, 2020 2 hours ago, prondzy said: Looks to me like a Man-daid i usually wrap a cut in a shop rag and wrap with electrical tape until she stops bleeding so i can keep working. That's technically true and something she's done for me. But that's her own forearm. So it's more of a BBT-daid. 1 Share this post Link to post Share on other sites
