DarrellF 33 #1 Posted March 17, 2020 What the best way to attempt this if possible? Share this post Link to post Share on other sites
pfrederi 18,640 #2 Posted March 17, 2020 (edited) First find out what type fluid is in there. tan color is motor oil 10w-30 or 10w-40 if it is red it is DEXMERC ATF Really isn't a flush you drain it and refill it. If the existing fluid is nasty looking e.g. cloudy or milky may have to do it more than once. Change filter each time. Wix 51410 takes about 5 qts Edited March 17, 2020 by pfrederi 2 1 Share this post Link to post Share on other sites
DarrellF 33 #3 Posted March 17, 2020 Its motor oil so drain it and add new then should I run it at all or just keep draining it again? Share this post Link to post Share on other sites
DarrellF 33 #4 Posted March 17, 2020 (edited) What I'm doing is a got 2 tractors from Todd and the one was missing the transmission tube so I'm sure water got in it I'm going to pull the rear and the pump out of the tractor that's missing the oil fill and really try and clean it out. My D200 has a bad axle but it's a good hydro and I was going to put the rear end under my tractor till I can repair the bad axle, I know my system is clean and strong I don't want to contaminate my system, So I'm going to be sure it's clean. Edited March 17, 2020 by DarrellF Share this post Link to post Share on other sites
pfrederi 18,640 #5 Posted March 17, 2020 Yes run it If the oil is really bad don't run it long, just enough to circulate the new oil to the lift cylinders. The drain it again... 1 Share this post Link to post Share on other sites
DarrellF 33 #6 Posted March 17, 2020 Ok ty pefrederi I know you the man to talk to you are they expert to me Share this post Link to post Share on other sites
pfrederi 18,640 #7 Posted March 17, 2020 Good luck. If you need Orings I can mail you some... 1 Share this post Link to post Share on other sites
DarrellF 33 #8 Posted March 17, 2020 1 hour ago, pfrederi said: Good luck. If you need Orings I can mail you some... I'll need them what they cost I'll get paid Share this post Link to post Share on other sites
DarrellF 33 #9 Posted March 17, 2020 3 minutes ago, DarrellF said: I'll need them what they cost I'll get you paid Share this post Link to post Share on other sites
pfrederi 18,640 #10 Posted March 17, 2020 1 minute ago, DarrellF said: I'll need them what they cost I'll get paid No charge just PM me your address. Do you need them for both ends of the manifold or just the rear... 1 Share this post Link to post Share on other sites
DarrellF 33 #11 Posted March 17, 2020 Both ends and I want to pay ya something gee Share this post Link to post Share on other sites
Pullstart 66,680 #12 Posted March 18, 2020 5 hours ago, DarrellF said: Both ends and I want to pay ya something gee It’s no hope, he won’t accept. He’s a good dude, sent me some o-rings for “Frank” my wife’s Sunstrand equipped round hood. 1 Share this post Link to post Share on other sites
DarrellF 33 #13 Posted March 18, 2020 Ya he's a great guy but I had to try right 1 Share this post Link to post Share on other sites
Pullstart 66,680 #14 Posted March 18, 2020 9 hours ago, DarrellF said: Ya he's a great guy but I had to try right He accepted a hand shake and a thank you at the big show... that was about it but I think it was enough to make his day. @pfrederi thanks again for stopping Frank’s leaks! 1 Share this post Link to post Share on other sites
pfrederi 18,640 #15 Posted March 18, 2020 the rings are in the mail. if you are going to work on the pump end of the manifold i would highly recommend you get on of these. save a lot of frustration,smacked knuckles and cursing and swearing.... 1 1 1 Share this post Link to post Share on other sites
DarrellF 33 #16 Posted March 20, 2020 Fred your a really good man thanks again Share this post Link to post Share on other sites
