Countdown To Christmas!
Oldskool
GT-14 A diamond in the rough
ebinmaine
Great to have a local network of friends!!
Oldskool
Sure is. They find all kinds of stuff.
Oldskool
20200526_201702.jpg.2b016ce0d988da372ffefcd6911a86f9.jpg20200526_201804.jpg.53ed376cc140e0d1bb54b3424445f42f.jpgWell come H E  double hockey sticks or high water. The GT is getting those tires on. So this is what happens when 14" Chevy ralley wheels meet up with 15in GT wheels. A 1/2" less back space and 2" wider
Oldskool
Tire test fit. Looks like it's going go work
  • Excellent 2
Oldskool
 It's been to long getting this far, but it has been a busy year. Surprisingly enough. So 18x9.50x8 on front and 27x11x14 radials on the rear. Now it's a roller. YAY lol.! Now to scrounge up an engine
  • Excellent 3
  • Heart 3
RandyLittrell
Tires and wheels look great!!
Randy
Oldskool
Randy
Thanks. I'm tickled pink that it rolls now
19richie66
Looks fantastic.:handgestures-thumbupright:
Oldskool
Thanks.   One step closer to putting the FEL on
Oldskool
I'm in need of some help here. What is the best way to get these off without destroying something?
ebinmaine
@953 nut
@pfrederi
I remember one of you posting a particular tool or tools.....
Oldskool
I was wondering if a bearing puller with a 3 jaw puller would work. Not sure how the electric clutch comes off either
  • Confused 1
ebinmaine
No sir.
Something to do with a correct sized bolt and push/pull against the crankshaft.
Pullers do NOT work on some or most electric clutches.
Oldskool
No sir.
Ah, so kinda like a power steering pulley removal/installation tool?
953 nut
The inside of the electric clutch is threaded, mine on a '70 GT-14 was a 1"-8 NC bolt thread. Run the bolt in against the end of the crank shaft and it will push the clutch off.
You cab borrow one from ACE, buy it and then bring it back telling them it was not the correct size.
  • Thanks 2
  • Haha 1
Oldskool
Mine seems to be the same thread as my puller bolt. I believe that would be Acme thread?
RandyLittrell
https://getyarn.io/yarn-clip/905c1847-7123-4f5c-b0d7-488bfeb080d5
:happy-jumpeveryone:
Randy
Edited by RandyLittrell
  • Haha 3
Oldskool
Both clutches are off. The pulleys and set screws are soaking over night in WD-40. Hope to get them off tomorrow after work. Any tips and tricks for those? I assume they are cast iron and really dont want to mess them up
Oldskool
Well dang. I thought I was making some headway on the GT.  Then the old engine hit the floor and broke the pulley. Kinda needed it lol. Now on the hunt for one of those
  • Sad 3
ebinmaine
AAAAGGGGGHHHHHH
Oldskool
2 minutes ago, ebinmaine said:
AAAAGGGGGHHHHHH
You can say that again
ebinmaine
AAAAGGGGGHHHHHH
I had to.
You know I had to....
  • Haha 2
Oldskool
I would have. LOL
Oldskool
I'm thinking of sell some parts from my old blown engine for some funds for the project. Any idea what a 1971 breakerless ignition would go for?
ebinmaine
If you can check the parts with a dvom to verify operation they certainly have a healthy value.
Poke around on eBay and that'll give you a decent idea.
