Michiganman 0 #1 Posted March 2, 2020 Want to put a posi on my rj tractors, and options that will work, bolens models, etc, thanks Share this post Link to post Share on other sites
Pullstart 66,428 #2 Posted March 3, 2020 6 hours ago, Michiganman said: Want to put a posi on my rj tractors, and options that will work, bolens models, etc, thanks from not too far away! other than bearings and seals being common items, everything in a Wheel Horse transmission case is proprietary. If you figure out otherwise, please share as we’d all like to know! 1 Share this post Link to post Share on other sites
Jennifer 1,878 #3 Posted March 3, 2020 @Michiganman welcome to the group!!! Share this post Link to post Share on other sites
rjg854 12,108 #4 Posted March 3, 2020 I'd also like to say Share this post Link to post Share on other sites
The Tuul Crib 7,339 #5 Posted March 3, 2020 I would like to take this moment to yall to as always .l have not herd any one doing what your wanting to do but maybe @stevasaurus our trans expert can answer your questions! Share this post Link to post Share on other sites
953 nut 59,608 #6 Posted March 3, 2020 Theoretically a positive traction differential in an RJ sounds like a good idea, then reality sets in. The front end of an RJ very lite and with a posi rear you would only be able to go in a straight line, turning would be virtually impossible. If enhanced traction is your goal I would suggest liquid filled tires and wheel weights.. 2 Share this post Link to post Share on other sites
wallfish 17,973 #7 Posted March 3, 2020 The tractor frames will need to be modified to attach anything other than the 3 piece transmission which is on there now. Wheel Horse did make a 2 piece 10 pinion trans with limited slip. Depending upon the condition of your RJs, maybe picking something else to modify would be a better option. If you do modify the RJs, do it as a bolt on so it can be changed back to original without cutting and welding which will save it's value as a collectable tractor. Do you work these tractors? Or can you tell us why you need the limited slip? 1 Share this post Link to post Share on other sites
Michiganman 0 #10 Posted March 4, 2020 I have a slew of antique garden tractors, one of them being a rj with a built predator 212 that my daughter is using in tractor pulls. I would like to swap the rear end with a selectable posi lock..... Share this post Link to post Share on other sites
WHX?? 51,589 #11 Posted March 5, 2020 2 hours ago, Michiganman said: I have a slew of antique garden tractors, one of them being a rj with a built predator 212 that my daughter is using in tractor pulls. I would like to swap the rear end with a selectable posi lock..... did we not mention we like .... sounds like you are way beyond what 'Fish is sayin. I don't think he is looking to change it back John... he's got a BFH. You are gonna have to ditch the three piece RJ rear end for something more solid. The three piece as we know it will never hold up to pullling unless its in a kitty class. Perhaps ditching the three piece, don't scrap it please tho we need those parts, adding a reinforced late model F plate rear end to an RJ frame then bolting up a 8 pinon that is locked up?? This might have been better posted in the pullers section Michigan dude but we'll try and help out. Share this post Link to post Share on other sites
Lane Ranger 11,378 #12 Posted March 5, 2020 (edited) One thing you could do to add a different transmission to an RJ or Suburban is add a front face plate to the transmission that would mesh the two pieces to the frame. i bought two transmissions in West Virginia in January of this year and one had a plate fabricated in front to fit a two piece Wheel Horse transmission to an RJ or Suburban frame. Your clutch rod and hookup would have to be fabricated most likely to conform with the new transmission. Edited March 5, 2020 by Lane Ranger 2 Share this post Link to post Share on other sites
stevasaurus 23,254 #13 Posted March 5, 2020 Wheel Horse does not make a "Selectable Posi Lock...and I have no idea how you could in-corporate one from a regular vehicle. Wheel Horse did make a 10 pinion Limited Slip differential...Wheel Horse #5060, #5071, #5073 these are 8 speed manual transmissions. Wheel Horse also put the 10 pinion Limited Slip differential in some of their hydro tractors...Wheel Horse #5062 that may work for you. You can lock the trans by taking an 8 pinion Wheel Horse transmission and paring up the pinions in the differential. They come with an A - B...A - B...A - B...A - B arrangement...change them to an A - A..B - B...A - A...B - B arrangement. It will be hard to stir, but both wheels will turn at the same time. 1 Share this post Link to post Share on other sites
