troutbum70 858 #1 Posted January 31, 2020 I have an issue with throttle on my electro 12, when I pull the throttle out when running it does not stay. As Soon as I let go of it it goes right back to an idle. And it is very touchy, does not take much pull to make a big difference and then it will be really cranked up. Only way to keep throttle out when running is to keep a small pair of vice grips on it. Everything seems to be in place, all linkages return springs and so on look to be correct. Any thoughts of what I am over looking. 2 Share this post Link to post Share on other sites
Roger R 471 #2 Posted January 31, 2020 I assume you are twisting the knob slightly to the right once in position? 1 Share this post Link to post Share on other sites
67 WH 877 62 #3 Posted January 31, 2020 I have the same issue with my horse...but I purchased the cheap ones till I find the locking WH ones that belong on it. Vibration causes mine to idle down. Share this post Link to post Share on other sites
ebinmaine 77,335 #4 Posted January 31, 2020 I believe it was @pfrederi Paul that uses a clothespin or two to hold it's position? If you are doing Twist left. Pull or push. Twist right (to lock)... And it's not working.... You may need a new cable. Others could tell you how to find good replacements. @Achto or @squonk. ? I think it's pzep.biz. ???? But I'm not sure how to find them. 2 Share this post Link to post Share on other sites
Achto 31,000 #5 Posted January 31, 2020 2 minutes ago, ebinmaine said: I think it's pzep.biz. ???? I've had good luck with the cables from here. http://www.psep.biz/store/toro_mower_cables.htm If you don't want to buy cables, I use clothes pins on a couple of my tractors. One for low/mid speed, two for high speed. 1 1 Share this post Link to post Share on other sites
wallfish 19,303 #6 Posted January 31, 2020 47 minutes ago, troutbum63 said: Any thoughts of what I am over looking. Post a good pic. for the quick responding throttle, the cable might be connected to close to a pivot point which takes less cable movement to move it from idle to WO. Same for ant linkages too. Share this post Link to post Share on other sites
troutbum70 858 #7 Posted January 31, 2020 That's is all I could blame it on as well vibration. I honestly never thought about it locking, I will check that out. Not use to pull throttle my others have levers. Well clothes pins is better than vice grips if they work. But mine may actually lock I will have to try it. 1 Share this post Link to post Share on other sites
troutbum70 858 #8 Posted January 31, 2020 No sharp bends in cable it is run with nice smooth even curves around the engine. 1 Share this post Link to post Share on other sites
troutbum70 858 #9 Posted January 31, 2020 Update on throttle while out with dog for the night I went into shop and checked, it does have a locking throttle. The white is off the letters so pretty hard to see the writing, turn right to lock. This is one of those times a dumb question brings up a simple answer. TNX 1 Share this post Link to post Share on other sites
ebinmaine 77,335 #10 Posted January 31, 2020 6 hours ago, troutbum63 said: dumb question I heard a looonnng time ago... There's only one "stupid/dumb" question. The one you DIDN'T ask... Share this post Link to post Share on other sites
troutbum70 858 #11 Posted January 31, 2020 Yea I know Eb but this one was a no brainer, and it never crossed my mind. But tnx to you fellas my mystery solved. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,450 #12 Posted January 31, 2020 (edited) troutbum63 I always found that all models have a learning curve. They all have there own little twist. Enjoy the tractor. Edited January 31, 2020 by Retierd Wrencher Share this post Link to post Share on other sites
troutbum70 858 #13 Posted January 31, 2020 They all have their little twist, like a quarter twist to lock the throttle control. I read your caption at the bottom of your page, less GOD less peace. Share this post Link to post Share on other sites
