Pullstart 68,777 #351 Posted February 17, 2020 I put together a table top out of some scrap OSB and a 12’ skid cut down to 8’ or so. Hopefully the next time this machine moves off the lift, it’s under it’s own power. The front of the frame was cleaned up and the hood mount is tacked on. 3 Share this post Link to post Share on other sites
ebinmaine 77,079 #352 Posted February 17, 2020 5 minutes ago, pullstart said: rods excuse my bad memory if you've already said this but what's going to be on those rods? Some sort of steps I assume? Share this post Link to post Share on other sites
Pullstart 68,777 #353 Posted February 17, 2020 9 minutes ago, ebinmaine said: excuse my bad memory if you've already said this but what's going to be on those rods? Some sort of steps I assume? I haven’t decided. Steps / fenders / mud flaps / curb feelers? 4 Share this post Link to post Share on other sites
ebinmaine 77,079 #354 Posted February 17, 2020 Just now, pullstart said: I haven’t decided. Steps / fenders / mud flaps / curb feelers? E. All of the above. Share this post Link to post Share on other sites
Stormin 9,987 #355 Posted February 17, 2020 (edited) 15 hours ago, pullstart said: I can't help thinking that a couple of gusset plates, under the joints would add some strength. Belt and braces. Suspenders to you. Edited February 17, 2020 by Stormin 1 2 Share this post Link to post Share on other sites
Pullstart 68,777 #356 Posted February 17, 2020 @Stormin I’ll surely be beefing up the chassis and plating this area will be part of it all. 2 1 Share this post Link to post Share on other sites
Pullstart 68,777 #357 Posted February 17, 2020 I dug this 2” x 3/16” angle iron out of my scrap/spares pile. It’ll be great for stiffening this project up. 3 Share this post Link to post Share on other sites
Pullstart 68,777 #358 Posted February 17, 2020 Calling all bridge builders, engineers and backyard wrenches, not necessarily in that order! I plan to use this angle iron to rigid up this machine. It’ll be upside down, as to resemble C channel from the inside. The front will double up the 45 degree section. It’ll be notched so that the two horizontal pieces will meet to be welded. Blue pill or red pill? Does it not matter for this caliber build? If the bottom piece was parallel to the top, I have some 3” wide flat stock that I could fill the whole length, actually creating that C channel. 1 Share this post Link to post Share on other sites
ebinmaine 77,079 #359 Posted February 17, 2020 Overkill is in the eye of the beholder. Or something like that.... I'd lean towards red pill if that has an extra cross member. 1 1 1 Share this post Link to post Share on other sites
Stormin 9,987 #360 Posted February 17, 2020 Another vote for RED from me. 1 1 Share this post Link to post Share on other sites
Pullstart 68,777 #361 Posted February 17, 2020 25 minutes ago, ebinmaine said: Overkill is in the eye of the beholder. Or something like that.... I'd lean towards red pill if that has an extra cross member. I could just as easily add another crossmember in the blue sketch, I just figured they were touching at the front bend... no real need to add one. I have a bunch of this 3/16” angle... Share this post Link to post Share on other sites
ebinmaine 77,079 #362 Posted February 17, 2020 1 minute ago, pullstart said: I could just as easily add another crossmember in the blue sketch, I just figured they were touching at the front bend... no real need to add one. I have a bunch of this 3/16” angle... okay so that being the case, what would be the difference between the red and the blue? Just the angle? Share this post Link to post Share on other sites
Pullstart 68,777 #363 Posted February 17, 2020 7 minutes ago, ebinmaine said: okay so that being the case, what would be the difference between the red and the blue? Just the angle? Yep. Triangulation or not... Share this post Link to post Share on other sites
ebinmaine 77,079 #364 Posted February 17, 2020 I'm still voting for red but I'm changing my reasons a little bit. in consideration of the fact that you can add a cross brace to either one of the designs I don't know which one, if either, would be stronger. For the sake of aesthetics and future modification possibilities I would stick with a parallel frame rail system. Since you have flatstock to add to it I would vote for that as well. Changing that whole arrangement to a large c channel wood eliminate 99% of the possibilities of Dynamic Loading even being so much as a concern. 2 1 Share this post Link to post Share on other sites
Pullstart 68,777 #365 Posted February 17, 2020 I’m there with you on the aesthetics idea EB. It’s not like I’ll have a lot of ground clearance issue with the front being so high! 1 1 Share this post Link to post Share on other sites
Tractorhead 9,216 #366 Posted February 17, 2020 I‘m more on the blue pill... why? Now, it looks for me more as a Dragsterframe or a Pullerframe, than a simply Dump truck. i simply and really like that Shape. And some memories come in mind - goood memories i had and i like to remember..👍 but how eric meant it‘s in the eye of the beholder. The stiffness shall be imho a little bit more in blue shape, but thats secondary in that design, except you plan an V6 as Engine... maybe .... once upon a time😎 1 Share this post Link to post Share on other sites
Pullstart 68,777 #367 Posted February 17, 2020 31 minutes ago, Tractorhead said: I‘m more on the blue pill... why? Now, it looks for me more as a Dragsterframe or a Pullerframe, than a simply Dump truck. i simply and really like that Shape. And some memories come in mind - goood memories i had and i like to remember..👍 but how eric meant it‘s in the eye of the beholder. The stiffness shall be imho a little bit more in blue shape, but thats secondary in that design, except you plan an V6 as Engine... maybe .... once upon a time😎 No V6 power here Stefan, this big guy will only have 6.5 horse powers. I like the look of the triangulated frame, but it’s so long and narrow I’m afraid the 3” separation or 7” overall height at the transmission plate aren’t enough to make a difference. Share this post Link to post Share on other sites
Pullstart 68,777 #368 Posted February 17, 2020 Thinking out loud, and sometimes talking out loud to myself... the parallel beam would be much easier to fabricate. I already know the kick up is a 45 degree angle. I have proven that I can cut the angle iron to bend that way. Anything I build will be stronger than what is there currently. I think I’ll stick with what I know on this portion. 1 1 Share this post Link to post Share on other sites
ebinmaine 77,079 #369 Posted February 17, 2020 5 minutes ago, pullstart said: Anything I build will be stronger than what is there currently. I think I’ll stick with what I know on this portion Share this post Link to post Share on other sites
Tractorhead 9,216 #370 Posted February 17, 2020 (edited) 7 hours ago, pullstart said: Wow. I tossed the WH steering together for grins and giggles. I’m not sure if I can do much better than what we’ve got here already! Before I proceed too much further, I’ll use a long skid to build a new lift table top. I refer to that pict. Remembers me a bit on that... 😎 ok, let me tell it so - i have a dream..... 😂😂😂 Edited February 17, 2020 by Tractorhead 1 2 Share this post Link to post Share on other sites
SylvanLakeWH 30,483 #371 Posted February 17, 2020 Blue lookin good! Share this post Link to post Share on other sites
wallfish 19,068 #372 Posted February 18, 2020 4 hours ago, pullstart said: the parallel beam would be much easier to fabricate. What's your plans for your feet? If going 2 seater the bottom bracing and the floor board support can be the same thing. Share this post Link to post Share on other sites
Pullstart 68,777 #373 Posted February 18, 2020 20 hours ago, wallfish said: What's your plans for your feet? If going 2 seater the bottom bracing and the floor board support can be the same thing. I haven’t yet thought that far ahead... but I have that tube bender, I could fab something out of round stuff if needed. I cut the first parallel piece and have some height trimming to do before I cut it to length. 3 1 Share this post Link to post Share on other sites
953 nut 63,975 #374 Posted February 19, 2020 On 2/17/2020 at 10:44 AM, pullstart said: On 2/17/2020 at 12:08 PM, pullstart said: I have some 3” wide flat stock that I could fill the whole length, actually creating that C channel Boxed channel gets my vote. curb feelers? You have curbs at your place? 2 Share this post Link to post Share on other sites
8ntruck 8,575 #375 Posted February 19, 2020 I'm thinking you need a couple of cross members. Those, along with the additional stringers you are adding will help increase the torsional rigidity - better cornering performance, ya know. 2 Share this post Link to post Share on other sites
