Ctlucas93
Need Info on a C-165
Ctlucas93
I just bought a used C-165 01-16KE01-17658. Its is odd because the rear says Toro but I don't think they bought them until '86, and the hood decals say C-145 but the serial points to a C-165, no identification on the engine at all. I'd like to find a service manual for the tractor itself and maybe a parts manual, I have a Kohler manual.  It has quite a few issues but going to start working on it in my spare time. It runs very well and idles smooth. Hydro pulls good  and deck lift works. I have no idea where the choke cable is supposed to mount on it. Hydro fluid is milky so i have a few filters ordered to change it a few times I just am not sure what to put in it. It also isn't charging the battery but going to Ohm out the stator per the manual, but does anyone know how to test the regulator? Also, I need to deal with the rust in the battery box area.
WVHillbilly520H
To help with the TORO on the metal fender pan is because that tractor originally came with a fiberglass fender pan that usually ended up broken and hence was replaced... Someone else will be along to help with the rest... BTW :text-welcomeconfetti: to :rs:.
oldredrider
Definitely a 16hp Kohler. Most likely a C165 if it has the Eaton transmission.
gwest_ca
Welcome to the forum.
Here is what we have on this model. Look through them all because with this type of link they are in no particular order.
https://www.wheelhorseforum.com/search/?q=01-16ke01&type=downloads_file
Each major component has a service manual supplied by the supplier. ie. engine and transmission
Few tractor service manuals were published but an older one still applies to most models because they changed very little.
Quite often service info can be found in the parts manuals.
Garry
Sparky
I’m seeing 10 head bolts on the motor so it is a 16hp. Like was mentioned above the rear fender was originally plastic and they were easily busted, someone swapped it to a metal fender.
:WRS:
SylvanLakeWH
Love the Black Hoods! :ph34r:
Rob R
With all the rust and corrosion you have on the rectifier first thing I would do is take that off clean all the mating surfaces and connections. You will NOT charge if you do not have a perfect ground to this unit.
Ctlucas93
Thanks guys for all the help. All the manuals will be a big help for sure. Sounds like I lucked out on the rear fenders being swapped. I didn't know the regulator needed a clean ground to charge, I have ordered a clean used mounting plate for it and a battery tray off ebay to swap them out. I plan on making a wiring harness per the schematic and wrapping it for a cleaner look. I love how smoothly she runs and the hydro will spin the tires. Hopefully tomorrow Ill get around to changing the fluid in it. I picked up a few extra filters to change it a few times with it being slightly milky. Only other gray area I have are the choke cable mounting provisions. The service manual doesn't say anything on it. My plans are to clean it up and maybe do a partial restore down the road.
The Tuul Crib
:text-welcomeconfetti:to the addiction. Be careful
because these tend to multiply!
:rs:and our membership
are here to help!!  :text-coolphotos:
bds1984
They will multiply quickly.  I started with my C165 twenty-five years ago  when I was ten years old and have grown to include a 520H and 315-8.  Over the years I have had a C195, 3 312-8s, C145 auto, and a 520xi come and go.  My C165 will stay with me forever.  Here is a link to my C165 refresh I did five years ago.
  • Similar Content
    • rustyedge1
      By rustyedge1
      Old Horse still gettin her done today, weekly workout.
      Photo on trailer 2014 the day I brought home.
      Old Kohler still sounds sweet under a load. Somewhere in life it picked up a 16hp motor.
      IMG_9609.mov IMG_9609.mov
    • Bert
      By Bert
      I’ve got a C-165 with 520 front end and rear rims, I’d like to put a 20 hp Onan under the hood so I can use my 60’ deck with it.
      I measured and it looks to fit but wondering if anyone has done this and if so are pics available?
      Thanks
    • bigman123
      By bigman123
      very nice tractor new ag tires almost new plow  800.00 firm they dont get much better.
      very proud of my machines.run like a top. my name is RICK   Edwards NY. phone# 315-562-2008
    • bigman123
      By bigman123
    • Frank Bupp
      By Frank Bupp
      my wheel horse is a 1980 model c-145 with a 14 hp kohler engine. it is an automatic. it runs fine on the flat areas.  when I go up a fairly steep hill the engine spits and sputters and blows black smoke out the exaust and it will shut down.  it will restart immediately. replaced fuel pump, gas lines, shut off valve, fuel filter, and spark plug.  I cannot figure this one out.  any help would be greatly helpful. thanks and  Semper-Fi.
