ebinmaine 79,595 #226 Posted December 4, 2020 Got it running and took it for a night time drive around the backyard. Something's not right in the linkage. I can't engage the park brake. Carb needs a rebuild which isn't a huge surprise. I don't think I've done that one yet. Here's a short video. 6 1 Share this post Link to post Share on other sites
Stepney 2,356 #227 Posted December 4, 2020 Good to see the old derelict move again! 1 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #228 Posted December 4, 2020 23 minutes ago, Stepney said: Good to see the old derelict move again! Man!!! I can't believe you called him that! 4 Share this post Link to post Share on other sites
ZXT 2,402 #229 Posted December 4, 2020 28 minutes ago, ebinmaine said: Got it running and took it for a night time drive around the backyard. Something's not right in the linkage. I can't engage the park brake. Carb needs a rebuild which isn't a huge surprise. I don't think I've done that one yet. Here's a short video. Looks good! What are you doing to engage the parking brake? Only disengaging the hydro with the lever will engage the parking brake. Pressing the pedal just pulls it into neutral. 3 Share this post Link to post Share on other sites
ebinmaine 79,595 #230 Posted December 4, 2020 16 minutes ago, AMC RULES said: Man!!! I can't believe you called him that! You've met me Craig. It is pretty accurate. Share this post Link to post Share on other sites
ebinmaine 79,595 #231 Posted December 4, 2020 12 minutes ago, ZXT said: Looks good! What are you doing to engage the parking brake? Only disengaging the hydro with the lever will engage the parking brake. Pressing the pedal just pulls it into neutral. Oh yeah I know. It was working before I put the belt guard on. I'll tear into it sometime and see what's not happy. 1 Share this post Link to post Share on other sites
rjg854 13,169 #232 Posted December 4, 2020 8 hours ago, Stepney said: Good to see the old derelict move again! 1 Share this post Link to post Share on other sites
ebinmaine 79,595 #233 Posted December 24, 2020 (edited) The issue with the parking brake turned out to be a set screw that I didn't realize was in the path of rotation on the little adapter that I cobbed on to take up space of a bunch of worn parts. Carburetor is surging up and down and I was reminded to check the set of the governor so I'll take a look at that. I'll be measuring up and ordering some hoses from a local company. Edited January 3, 2021 by ebinmaine 4 Share this post Link to post Share on other sites
charging10 261 #234 Posted December 24, 2020 I bought a abused 72 charger10 years ago , the engine blew up the same year, I replaced it with the same 10hp engine from a member on redsquare , this tractor has done everything , snowplow , moldboard plowing etc , the hydro has never let me down. 2 1 Share this post Link to post Share on other sites
ebinmaine 79,595 #235 Posted January 3, 2021 (edited) Been messing with the idler linkage and I need to disassemble it a little to install a bushing or 2. I ha removed the voltage regulator to experiment with the location of the plow up/down control. Today I put that back on and made a changeto the wiring harness. I had used a wire that was a tad too short. Couldn't leave it there. Removed all the zip ties and reset the harness. It's no @JCM Jim plumbing job but it'll do. Edited January 3, 2021 by ebinmaine 1 Share this post Link to post Share on other sites
JCM 11,253 #236 Posted January 3, 2021 Wiring is not my specialty for sure, looks tidy from here Eric. Glad to see you have had a little extra time to make some headway with that hydro. You will not be disappointed once you figure out what to do with your extra foot. 1 Share this post Link to post Share on other sites
ebinmaine 79,595 #237 Posted January 3, 2021 54 minutes ago, JCM said: Wiring is not my specialty for sure, looks tidy from here Eric. Glad to see you have had a little extra time to make some headway with that hydro. You will not be disappointed once you figure out what to do with your extra foot. Got Trina's 867 out of the basement workshop and back to work. Still needs some lights installed and more weight but it's a LOT better. Now I can put some time in to this one. Hoping to see the new hoses within the week. I forget who but someone suggested to adjust the governor. Did that. It was a little off. Maybe that'll help... I also took out the belt idler shaft and took some measurements. Need to find some bushings. Share this post Link to post Share on other sites
Ed Kennell 46,520 #238 Posted January 3, 2021 1 hour ago, JCM said: You will not be disappointed once you figure out what to do with your extra foot. Easy peasy foot control. 1 Share this post Link to post Share on other sites
ebinmaine 79,595 #239 Posted January 3, 2021 13 minutes ago, Ed Kennell said: foot control That could be up for future discussion. Share this post Link to post Share on other sites
pfrederi 20,837 #240 Posted January 5, 2021 I know Ed has a heated cab (this is a guy who sits out in the cold to shoot Bambi.) but I plowed for over an hour today no cab no foot control no power angle. (If you aren't trying to change angle with blade on the ground very little effort.) Plowed at almost 7mph forward vs 2.5and 3.5 backing up vs 2.1mph. Really not hard to figure out the controls. Foot control power angle..2 more things to fail in the cold and the snow. KISS!!! 2 Share this post Link to post Share on other sites
ebinmaine 79,595 #241 Posted January 5, 2021 1 minute ago, pfrederi said: I know Ed has a heated cab (this is a guy who sits out in the cold to shoot Bambi.) but I plowed for over an hour today no cab no foot control no power angle. (If you aren't trying to change angle with blade on the ground very little effort.) Plowed at almost 7mph forward vs 2.5and 3.5 backing up vs 2.1mph. Really not hard to figure out the controls. Foot control power angle..2 more things to fail in the cold and the snow. KISS!!! I'd LIKE the faster backing speed. I really can't go much more than (2nd gear at 3/4 throttle) going forward. Our yard is just way too rough. Share this post Link to post Share on other sites
tom2p 2,394 #242 Posted January 5, 2021 (edited) 38 minutes ago, pfrederi said: I know Ed has a heated cab (this is a guy who sits out in the cold to shoot Bambi.) but I plowed for over an hour today no cab no foot control no power angle. (If you aren't trying to change angle with blade on the ground very little effort.) Plowed at almost 7mph forward vs 2.5and 3.5 backing up vs 2.1mph. Really not hard to figure out the controls. Foot control power angle..2 more things to fail in the cold and the snow. KISS!!! been a while since I've plowed with a Wheel Horse - but I was so impressed with how well it plowed I did not mind clutch / gear shift / lever to lift blade / lever to change blade angle ... but then again - when I was a kid (back in mid / late 60's) I would accompany my dad when he snow plowed ... I was the 'auto hubs' and 'power angle' : I would get out of the truck (we actually had a Jeep and later an IH Scout at the time) and manually lock the front hubs ... and I would also get out and manually change the snow blade angle Edited January 5, 2021 by tom2p 3 1 Share this post Link to post Share on other sites
ebinmaine 79,595 #244 Posted January 7, 2021 @Oldskool 1 Share this post Link to post Share on other sites
Lee1977 7,701 #245 Posted January 7, 2021 On 7/9/2020 at 5:47 AM, ebinmaine said: Yeah these are.....ummmm..... A little loose. I'm hoping to slow down the wear process a little bit by using hubs with two set screws. That won't work. Loss hubs just get looser unless you fix them right. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #246 Posted January 7, 2021 Nice looking tractor. I think it will serve you well. After reading thru your post.....now I want another tractor. Dang it all...... 1 1 Share this post Link to post Share on other sites
ebinmaine 79,595 #247 Posted January 7, 2021 1 hour ago, Lee1977 said: That won't work. Loss hubs just get looser unless you fix them right. Go back in the thread... They were replaced when I split the transmission. All good! 1 Share this post Link to post Share on other sites
ebinmaine 79,595 #248 Posted January 7, 2021 58 minutes ago, Oldskool said: Nice looking tractor. I think it will serve you well. After reading thru your post.....now I want another tractor. Dang it all...... HAHAHAHAHA Mister I keep telling you to hop on down here and you'll leave with a niiiice prize package!! 1 Share this post Link to post Share on other sites
ebinmaine 79,595 #249 Posted January 7, 2021 I popped a couple bushings in around the idler support shaft. Made a huge difference. They'll get held in better later. JB Weld? Also took the park brake handle off and stuck some appropriate sized washers on the pivot pin. MUCH better. Pics are at a tough angle but maybe you can zoom in. Also took a few minutes and mocked up the hose setting. I'll adjust the position of the valve/handle then bolt it to the seat pan. Got the hoses and adapters from a great place in Gorham Maine. He deals with folks all over and if he needs pics or info I can be a middle man if needed. crsmaine.com Component Repair and Supply.. 1 3 Share this post Link to post Share on other sites
Oldskool 6,678 #250 Posted January 7, 2021 8 minutes ago, ebinmaine said: HAHAHAHAHA Mister I keep telling you to hop on down here and you'll leave with a niiiice prize package!! I know I know. Now that snow is here I'm guessing Spring would be best. 1 Share this post Link to post Share on other sites
