Retired Wrencher 6,450 #1 Posted December 18, 2019 This was a bad storm we had lots of ice with some snow. So The B80 8 came thru again. That plow kicks but period. With a little pressure on the handle and it digs down to the pavement. A big. 7 11 4 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2 Posted December 18, 2019 Hard to beat that k181!! It will take anything you throw at it and it looks like you did that pretty well ! 2 Share this post Link to post Share on other sites
Retired Wrencher 6,450 #3 Posted December 18, 2019 56 minutes ago, The Tool Crib said: Hard to beat that k181!! It will take anything you throw at it and it looks like you did that pretty well ! Totally sold T/Crib. My back says tanks. 1 2 Share this post Link to post Share on other sites
midpack 1,104 #4 Posted December 18, 2019 Definitely a "plow" event around here! how is the steering with those bare fronts? I have some weights off a Craftsman (the small rears fit on 8" WH fronts nicely) and #40 chain around the circumference of the tire and was still looking for steering at times. 1 Share this post Link to post Share on other sites
ebinmaine 77,335 #5 Posted December 18, 2019 Gary I knew you would be pretty impressed with that solid link. Now you can see why I wouldn't run a plow without one. Most of the time you just let the handle float along like you always did but every once in a while it's there when you need it. 13 minutes ago, midpack said: Definitely a "plow" event around here! how is the steering with those bare fronts? I have some weights off a Craftsman (the small rears fit on 8" WH fronts nicely) and #40 chain around the circumference of the tire and was still looking for steering at times. When you get a minute it would be neat to see some pictures of your setup. I have oversized tires that are fluid-filled all the way around. My front end is probably about 120 lb heavier than a stock C series. Normally it does okay. 2 Share this post Link to post Share on other sites
stevasaurus 23,617 #6 Posted December 18, 2019 The solid link rules...for sure. Dang that blade looks big. 2 1 Share this post Link to post Share on other sites
857 horse 2,588 #7 Posted December 18, 2019 (edited) IM BETTIN ITS A 48" @stevasaurus IMAGINE IF IT HAD AN 8 SPEED AND ALL THE WEIGHTS !!!!!!!! MADNESS !!!!!!!!s,,,,,,, AS YOU WERE GENTLEMEN ...... AND BEST WISHES ON OUR HOLIDAYS Edited December 18, 2019 by 857 horse 5 Share this post Link to post Share on other sites
stevasaurus 23,617 #8 Posted December 18, 2019 @857 horse Happy Holidays to you and yours Howard. Merry Christmas my friend. 1 1 Share this post Link to post Share on other sites
tom2p 2,394 #9 Posted December 18, 2019 Wheel Horse one of the few (if only ?) with a great full length plow frame that attaches to the rear and can do without tools 3 2 Share this post Link to post Share on other sites
Retired Wrencher 6,450 #10 Posted December 19, 2019 15 hours ago, midpack said: Definitely a "plow" event around here! how is the steering with those bare fronts? I have some weights off a Craftsman (the small rears fit on 8" WH fronts nicely) and #40 chain around the circumference of the tire and was still looking for steering at times. I could use some weights. Some day I will get around to that. But I am sold on this type of storm. Share this post Link to post Share on other sites
Retired Wrencher 6,450 #11 Posted December 19, 2019 15 hours ago, stevasaurus said: The solid link rules...for sure. Dang that blade looks big. Thanks Steve. I was very impressed with how it bites down. That was a lot of ice and snow. Share this post Link to post Share on other sites
Retired Wrencher 6,450 #12 Posted December 19, 2019 15 hours ago, ebinmaine said: Gary I knew you would be pretty impressed with that solid link. Now you can see why I wouldn't run a plow without one. Most of the time you just let the handle float along like you always did but every once in a while it's there when you need it. When you get a minute it would be neat to see some pictures of your setup. I have oversized tires that are fluid-filled all the way around. My front end is probably about 120 lb heavier than a stock C series. Normally it does okay. Thanks Eric I definitely see the light now on this set up. Share this post Link to post Share on other sites
Retired Wrencher 6,450 #13 Posted December 19, 2019 14 hours ago, 857 horse said: IM BETTIN ITS A 48" @stevasaurus IMAGINE IF IT HAD AN 8 SPEED AND ALL THE WEIGHTS !!!!!!!! MADNESS !!!!!!!!s,,,,,,, AS YOU WERE GENTLEMEN ...... AND BEST WISHES ON OUR HOLIDAYS Thanks Howard and the same to you and your family. 1 Share this post Link to post Share on other sites
midpack 1,104 #14 Posted December 23, 2019 On 12/18/2019 at 3:26 PM, ebinmaine said: When you get a minute it would be neat to see some pictures of your setup. here ya go. the weights stick out a little, but no further than the wings. been using this the last 2 years and it works well. 1 1 Share this post Link to post Share on other sites
