ebinmaine 79,063 #151 Posted December 30, 2019 3 minutes ago, MikMacMike said: welded brace Absolutely would help, yes. 1 Share this post Link to post Share on other sites
ZXT 2,402 #152 Posted December 30, 2019 (edited) On 12/28/2019 at 8:37 AM, pullstart said: Jonah.... testing testing! @Mr Magoo congrats on your success! That’s what a feels good donut tastes like right there! Got an email but no notification on here. Edit: I changed my settings but didn't hit save when I changed it. Silly me. Should be good now. 1 hour ago, Mr Magoo said: What are you using to mount them? I looked at the HF model, but a kid I know at the store showed me 5 of them that had been returned all bent up from folks trying to get them to work. I would go for their full size tool if it will fit an 8" rim. If nothing else, if you have a high-lift jack and a truck with a heavy bumper, you can use that to break the beads as well. Edited December 30, 2019 by ZXT Share this post Link to post Share on other sites
tom2p 2,394 #153 Posted December 30, 2019 (edited) 1 hour ago, pfrederi said: Cargo straps work to help seat tubeless tires I use a cargo strap or tie down the cargo strap (or tie down etc) will perform similar to the the 'item' a tire store or service station will use when mounting a tire on a wide wheel ( especially for relatively narrow tires on very wide wheels ) the 'item' - for lack of better term - is inflatable ... similar to a heavy duty inner tube mount the item around the tire (outside ; middle of tread) and then inflate to the item to move/press the tire bead toward the wheel we used these back in the day when I worked at a service station Edited December 30, 2019 by tom2p 3 Share this post Link to post Share on other sites
ebinmaine 79,063 #154 Posted December 30, 2019 25 minutes ago, ZXT said: go for their full size tool if it will fit an 8" rim. Small rims don't fit on the full size changer. What I do is break the bead with the full size changer then use the spoons to change the tire on/off the rim. I have a 3/4" x (10"?) bolt that can be mounted in my big vise to use for stability holding small rims but I've never used it. 1 Share this post Link to post Share on other sites
ZXT 2,402 #155 Posted December 30, 2019 3 minutes ago, ebinmaine said: Small rims don't fit on the full size changer. What I do is break the bead with the full size changer then use the spoons to change the tire on/off the rim. I have a 3/4" x (10"?) bolt that can be mounted in my big vise to use for stability holding small rims but I've never used it. Gotcha. I didn't know that the HF tool did anything more than break the bead. I always just use tire spoons. Off topic, but I plan on shipping the coil tomorrow if you still need it. Sorry about the wait. 1 Share this post Link to post Share on other sites
ebinmaine 79,063 #156 Posted December 30, 2019 3 minutes ago, ZXT said: Gotcha. I didn't know that the HF tool did anything more than break the bead. I always just use tire spoons. Off topic, but I plan on shipping the coil tomorrow if you still need it. Sorry about the wait. Excellent. Definitely still needed... THANKS!!!! 2 Share this post Link to post Share on other sites
Mr Magoo 226 #157 Posted December 30, 2019 I have new front wheel bearings coming in today for the C-120. After those are in I believe all I will need are a couple of front tires and it will be ready for service. I have a few odds and ends that I would like to get, but nothing that prevents it from running. I did pick up a no contact handheld digital laser photo tachometer to check the RPM's with. Eager to try that out. I am working on a low budget at the moment and found these Deestone D265 16/6.50-8 64A3 tires for only $15.88 a piece at Wally World. That is almost too good to pass up unless they are complete garbage. They seem to get good reviews all around. I actually found nothing negative about them. Anyone have any experience with the Deestone tires? 1 Share this post Link to post Share on other sites
Mr Magoo 226 #158 Posted December 30, 2019 Heck, they even have the rear 23X8.5-12's for $32.63. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #159 Posted December 30, 2019 Deestones tend to run just a tad bit smaller. I put 10.50 s on my 71/2 rims with no problem 1 Share this post Link to post Share on other sites
Mr Magoo 226 #160 Posted December 30, 2019 5 minutes ago, The Tool Crib said: Deestones tend to run just a tad bit smaller. I put 10.50 s on my 71/2 rims with no problem So I'm assuming you mean smaller the width way or all around? I have 8.5" on it now, but do have 10.5" on my other C-120. Share this post Link to post Share on other sites
ebinmaine 79,063 #161 Posted December 30, 2019 49 minutes ago, Mr Magoo said: So I'm assuming you mean smaller the width way or all around? I have 8.5" on it now, but do have 10.5" on my other C-120. I don't have any deestone tires in my collection but they tend to run an inch or so smaller in diameter and at least an inch narrower then what they are advertised at. As to quality I obviously can't speak from experience but I haven't seen any complaints about them that I can remember. 1 Share this post Link to post Share on other sites
Mr Magoo 226 #162 Posted December 30, 2019 10 minutes ago, ebinmaine said: I don't have any deestone tires in my collection but they tend to run an inch or so smaller in diameter and at least an inch narrower then what they are advertised at. As to quality I obviously can't speak from experience but I haven't seen any complaints about them that I can remember. Thanks @ebinmaine. They also have Deestone D265 23/9.50-12 88A3 for $34.50. I could go with those to make up a bit for the narrower width. I may take a chance and pull the trigger. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #163 Posted December 30, 2019 Width wise . The Height would be the same. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #164 Posted December 30, 2019 Here's a pic of my 414 with the stones on it. These are 1050s 3 1 Share this post Link to post Share on other sites
ZXT 2,402 #165 Posted December 31, 2019 11 hours ago, Mr Magoo said: I have new front wheel bearings coming in today for the C-120. After those are in I believe all I will need are a couple of front tires and it will be ready for service. I have a few odds and ends that I would like to get, but nothing that prevents it from running. I did pick up a no contact handheld digital laser photo tachometer to check the RPM's with. Eager to try that out. I am working on a low budget at the moment and found these Deestone D265 16/6.50-8 64A3 tires for only $15.88 a piece at Wally World. That is almost too good to pass up unless they are complete garbage. They seem to get good reviews all around. I actually found nothing negative about them. Anyone have any experience with the Deestone tires? 10 hours ago, Mr Magoo said: Heck, they even have the rear 23X8.5-12's for $32.63. That is CHEAP! You could have a complete set of tires for under $100 minus shipping. That's not bad at all. I know numerous people run Deestones. I have not once seen a complaint. Share this post Link to post Share on other sites
Mr Magoo 226 #166 Posted December 31, 2019 (edited) 39 minutes ago, ZXT said: That is CHEAP! You could have a complete set of tires for under $100 minus shipping. Shipping is FREE on orders over $35.00! Edited December 31, 2019 by Mr Magoo 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #167 Posted December 31, 2019 Do you have a link for that tire. I looked and cant find it. Maybe a part number? 1 Share this post Link to post Share on other sites
ZXT 2,402 #168 Posted December 31, 2019 1 hour ago, The Tool Crib said: Do you have a link for that tire. I looked and cant find it. Maybe a part number? I'd buy a set for that. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #169 Posted December 31, 2019 I went to the Walmart site and typed in deestone tractor tires . Had to scroll awhile and found them . Not a bad price.They are the turf tires. I did see one ag tire for 46 bucks. Free pickup at the store. Two day turn around is hard to beat! Share this post Link to post Share on other sites
tom2p 2,394 #170 Posted December 31, 2019 (edited) ordered front tires from Walmart this past summer Hi-Run 6 ply - $20 per tire ($19.89) price significantly lower than just about anywhere else free shipping and arrived quickly and the tires were in good form / shape ; not overly compressed or smashed or twisted that would complicate mounting or inflating tires mounted on 312-8 shown in foreground ( appearance / tread very similar to the Titan tires mounted on rear ) Edited December 31, 2019 by tom2p Share this post Link to post Share on other sites
Mr Magoo 226 #171 Posted December 31, 2019 4 hours ago, The Tool Crib said: Do you have a link for that tire. I looked and cant find it. Maybe a part number? Not allowed to post a link on this forum right? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #172 Posted December 31, 2019 Right. But part number is ok sorry. I did find tho. Thanx 1 Share this post Link to post Share on other sites
Mr Magoo 226 #173 Posted December 31, 2019 3 hours ago, The Tool Crib said: Right. But part number is ok sorry. I did find tho. Thanx Awesome. Hoping I can order some in the next few weeks when I get back to getting a regular pay check. Maybe some of you will have some before that with pictures to share. Share this post Link to post Share on other sites
Pullstart 70,040 #174 Posted January 1, 2020 Magoo. I’ve had a couple sets of Deestones as well. I run the ag tires from them and front tri-ribs. I tubed them and loaded them with used antifreeze (found a bunch for free on CL) and have zero regrets! My first set of 23/8.5 were small, but the traction is great with a narrower contact patch. The 10.5’s are most appealing to the eye and haven’t yet let us down. 1 1 1 Share this post Link to post Share on other sites
Mr Magoo 226 #175 Posted January 3, 2020 So I piddled around on my “good” C-120 today. Took the front wheels off to put new bearings in and figured out that I only ordered half as many bearings as I need. One question I have concerning that is that my front wheels are held on to the spindle by a cotter pin. I thought that it would have a bolt threaded into the end of the spindle. The other great thing I found today is that my mule drive may be trashed. The bearing in the flat pulley was destroyed and seriously messed up the shaft. I pulled the mule drive off of my other C-120 and it seems to be okay other than the fact that the belt has eaten into the cover pretty good for some reason. Unfortunately due to the issues that both of the drives have, neither one of the belts are as good as I had hoped and I will need to find a new one. I still need to figure out the correct length. I measured it kind of quickly and got around 103.75”. That was around the flat side of the belt. 1 Share this post Link to post Share on other sites
