jediblender 1 #1 Posted October 28, 2019 I have a 1996 416-8. I found a Haban Sickle Mower for sale. Would it fit my mower? If not any sickle attachments out there that will? Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #2 Posted October 28, 2019 3 hours ago, jediblender said: I have a 1996 416-8. I found a Haban Sickle Mower for sale. Would it fit my mower? If not any sickle attachments out there that will? Haban made sickle bars for several different brands including WH... You would need the model and serial numbers then I'm sure @gwest_ca could tell you for sure. 1 Share this post Link to post Share on other sites
953 nut 68,522 #3 Posted October 28, 2019 The Haban mower could be made to work on a but won't be a direct bolt up unless it has been on a Wheel Horse before. This manual will show you how they are attached. Got any pictures of the sickle bar? 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #4 Posted October 28, 2019 @953 nut, Richard the newer C,3,400 series sickle bars we're made by Haban. Share this post Link to post Share on other sites
953 nut 68,522 #5 Posted October 29, 2019 6 minutes ago, WVHillbilly520H said: @953 nut, Richard the newer C,3,400 series sickle bars we're made by Haban. Chances are Haban made the side mount sickle bar mowers under license from Wheel Horse all along. Not enough demand to justify tooling up a line to make them in-house. The interface hardware to make them work on a was probably the only thing made by Wheel Horse. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #6 Posted October 29, 2019 The Sears Suburban had a similar PTO/mule drive set-up as WH and I see a lot of those with sickle bars. Not too many CC or JD. 1 Share this post Link to post Share on other sites
