oldoutboard 2 #1 Posted October 9, 2019 Does anyone here run a Kohler K161 7 hp on a Wheel Horse 702 without using a fuel pump and are there fuel pump repair kits still available for OEM fuel pumps? My fuel pump leaks gas around the diaphragm Thanks in advance. Share this post Link to post Share on other sites
rjg854 12,639 #2 Posted October 9, 2019 @buckrancher I believe still sells the diaphragms if you need one. 1 Share this post Link to post Share on other sites
Racinbob 12,433 #3 Posted October 9, 2019 http://www.then-now-auto.com/kohler-fuel-pumps-2/ As long as your fuel tank is higher than the carb you'd be fine. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted October 9, 2019 19 minutes ago, Racinbob said: http://www.then-now-auto.com/kohler-fuel-pumps-2/ As long as your fuel tank is higher than the carb you'd be fine. 1 Share this post Link to post Share on other sites
Pullstart 68,535 #5 Posted October 9, 2019 to @oldoutboard! I run a K-181T on my 502 with no fuel pump. I have a glass bowl under the tank and it is connected by a 1/8” x close pipe nipple. It is higher than the carburetor just enough to make it work. Here is a link to my 502 build, where it shows how I routed the fuel line for slope too.. though it’s probably unnecessary. 1 Share this post Link to post Share on other sites
oldoutboard 2 #6 Posted October 9, 2019 Thanks for all the information, I am going to try to run without the fuel pump and see if it works, the bottom of the tank is a little higher than the carb inlet. Share this post Link to post Share on other sites
