gcole 36 #1 Posted September 25, 2019 Hey guys, I know I’m gonna catch trouble for not working on a wheel horse but a co worker has a Allis 310 with a kohler engine with no spark. Here’s the troubling part. It’s not a points system. It has a system I’ve never seen in any small engines. Here’s a picture of the coil and the wiring diagram. On the wire coming from the flywheel I have a trigger wire coming out that pulses ground and the other wire from the key switch had the power it’s supposed to. The wiring diagram shows those 2 together but there’s no spark. Any help is greatly appreciated! Thanks guys Share this post Link to post Share on other sites
prondzy 3,889 #2 Posted September 25, 2019 Thats called a CDI system, sorry to say either the black box or the trigger is dead. now its time to change it to a points style system. 1 Share this post Link to post Share on other sites
gcole 36 #3 Posted September 25, 2019 Just now, prondzy said: Thats called a CDI system, sorry to say either the black box or the trigger is dead. now its time to change it to a points style system. I looked at that but the block isn’t tapped to add the points in. There’s the start of the hole for the plunger but no mounting bracket holes Share this post Link to post Share on other sites
953 nut 64,664 #4 Posted September 25, 2019 @Aldon has documented the steps you need to take. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,071 #5 Posted September 25, 2019 The wiring diagram you posted appears to have some serious mistakes in it. The ignition switch terminal locations can't be correct or I'm loosing my marbles. A -M and S-B should be switched. That may be what cooked the ignition. Garry 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,071 #7 Posted September 25, 2019 An attempt to correct it. Comments? Share this post Link to post Share on other sites
953 nut 64,664 #8 Posted September 26, 2019 23 hours ago, gcole said: Allis 310 23 hours ago, gcole said: wiring diagram I presume this is an Allis Chalmers drawing. They may have their own ignition switches. Share this post Link to post Share on other sites
