BMW1
D series motion control linkage adjustment
BMW1
Is there a procedure for adjusting the motion control linkage on a 1974 D-180 - model#  1-0611 9 ?
The tractor barely moves in reverse and the motion control arm is not traveling the full length of the slot for reverse.  The picture below shows how far back it goes.  The motion control arm travels all the way forward to the end of the slot when going forward.
I never drove this tractor before I bought so I have no idea what it did before.  The only thing I have done to it is replace a couple of bearings in the differential and replace the axles, splines were bad on one and other axle was bent.
Thanks.
gwest_ca
 Suspect what you need is in this service manual
Keep us posted on your progress.
Garry
BMW1
Thank You.  I do have that manual and have looked through it.  It seems like the only that can be adjusted is the friction and neutral position.
Maybe I'm missing something in the manual - is there a specific place in that manual that addresses the travel range of the motion control lever?
Thanks.
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
