JoeM 9,646 #1 Posted September 17, 2019 Seen this plow mount on a CL Ad, never seen one mounted like this, homemade or factory? Your thoughts, pros or cons. 2 2 Share this post Link to post Share on other sites
AMC RULES 37,254 #2 Posted September 17, 2019 Definitely not factory... and, whatever works for you. Share this post Link to post Share on other sites
ebinmaine 77,535 #3 Posted September 17, 2019 Seems like it would work fine if built right. Wouldn't work for me because I have oversized front tires. Moving the blade back would decrease the turning/pivot space. Share this post Link to post Share on other sites
rjg854 12,862 #4 Posted September 17, 2019 Got any pictures of the rest of the plow? May be someone re-engineered the rest of that plow frame to make it work like that. Share this post Link to post Share on other sites
oldlineman 1,654 #5 Posted September 17, 2019 I would think being mounted to a narrower point would let the plow and frame twist more might be enough to break that mounting point. Would also depend how hard you are working the tractor and what kind of terrian you are on. Share this post Link to post Share on other sites
JoeM 9,646 #6 Posted September 17, 2019 5 hours ago, rjg854 said: Got any pictures of the rest of the plow? May be someone re-engineered the rest of that plow frame to make it work like that. Went back and looked at the ad, can't really see any other mods. I was intrigued with this cause it seems like it would be easier to install. A handle of sorts could be fitted to lift it in place and use a pin and keeper in place of the snap rings. I agree there needs to be an additional device on the front to prevent sway. Share this post Link to post Share on other sites
ebinmaine 77,535 #7 Posted September 17, 2019 13 minutes ago, OILUJ52 said: additional device on the front to prevent sway. @WVHillbilly520H Can help out with that 1 Share this post Link to post Share on other sites
953 nut 64,318 #8 Posted September 17, 2019 32 minutes ago, OILUJ52 said: it seems like it would be easier to install. Once that snow blade hits a few stumps/curbs/snow banks/whatever that unsupported piece of 3/4" steel rod through the hitch point would be bent and would have to be cut out. Not a good way to mount a plow. 1 Share this post Link to post Share on other sites
