ebinmaine 76,596 #1176 Posted April 17, 2021 8 minutes ago, OldWorkHorse said: Seems like a pretty good idea! Looks good man! Yessir it sure was. Ya done good. Next time I'll measure the proposed needed length and slice off the other side with my new toy bandsaw. Another great idea from you. 👍👍👍 I'm thinking I'll use a grinder or angle chop saw to narrow down the ends a little. 1 1 Share this post Link to post Share on other sites
Gregor 4,847 #1177 Posted April 17, 2021 18 minutes ago, ebinmaine said: Now I need to figure out how to clamp round material. If anyone has suggestions I'm all ears. I can't tell from the pics of your drill press, but if it's like most drill presses, mount your vice loosely, tilt your table 90 degrees so it's straight up and down with your chuck. Clamp your piece. Make take a little set up time, but it's one way to do it. 4 1 Share this post Link to post Share on other sites
OldWorkHorse 3,130 #1178 Posted April 17, 2021 4 minutes ago, ebinmaine said: Yessir it sure was. Ya done good. Next time I'll measure the proposed needed length and slice off the other side with my new toy bandsaw. Another great idea from you. 👍👍👍 I'm thinking I'll use a grinder or angle chop saw to narrow down the ends a little. Like taper them in? That be a cool look! Need a way to spin them on a belt sander. 1 Share this post Link to post Share on other sites
ebinmaine 76,596 #1179 Posted April 17, 2021 1 minute ago, Gregor said: I can't tell from the pics of your drill press, but if it's like most drill presses, mount your vice loosely, tilt your table 90 degrees so it's straight up and down with your chuck. Clamp your piece. Make take a little set up time, but it's one way to do it. I'll try it. I have 3 different vises I can use. Share this post Link to post Share on other sites
ebinmaine 76,596 #1180 Posted April 17, 2021 1 minute ago, OldWorkHorse said: Like taper them in? That be a cool look! Need a way to spin them on a belt sander. Yes exactly. I'd have to do it manually somehow. 1 Share this post Link to post Share on other sites
OldWorkHorse 3,130 #1181 Posted April 18, 2021 22 minutes ago, ebinmaine said: Yes exactly. I'd have to do it manually somehow. Duct tape a weed Wacker and a file I think I've seen that done on the Red Green show b4 so it has to work! Find a socket that fits it and a drill addapter and all done. Might only work for the outside tho. 2 Share this post Link to post Share on other sites
ebinmaine 76,596 #1182 Posted April 18, 2021 6 minutes ago, OldWorkHorse said: socket that fits it and a drill addapter Fairly sure I don't have a socket that big. Share this post Link to post Share on other sites
OldWorkHorse 3,130 #1183 Posted April 18, 2021 2 minutes ago, ebinmaine said: Fairly sure I don't have a socket that big. What size is it again? I probly do lol. Share this post Link to post Share on other sites
ebinmaine 76,596 #1184 Posted April 18, 2021 1 minute ago, OldWorkHorse said: What size is it again? I probly do lol. 1-1/8. Share this post Link to post Share on other sites
OldWorkHorse 3,130 #1185 Posted April 18, 2021 Oh yeah i def do I'll set 1 aside and bring it by next time pop in got them tire tubes in so have more reason then just the socket. At least it's 1 option. Sure there are more lol 1 Share this post Link to post Share on other sites
Oldskool 6,666 #1186 Posted April 18, 2021 56 minutes ago, ebinmaine said: Yes exactly. I'd have to do it manually somehow. How bout cut the head off of 2 bolts that screw into the tie rod. Screw them into the tierod. Then place one in the drill press chuck and the other in a hole drilled into a wood block clamped in your vise. A vertical metal lathe if you will. Use a grinder with a flap disc while the tierod is spinning in the drillpress. 4 Share this post Link to post Share on other sites
ebinmaine 76,596 #1187 Posted April 18, 2021 34 minutes ago, Oldskool said: How bout cut the head off of 2 bolts that screw into the tie rod. Screw them into the tierod. Then place one in the drill press chuck and the other in a hole drilled into a wood block clamped in your vise. A vertical metal lathe if you will. Use a grinder with a flap disc while the tierod is spinning in the drillpress. Ideas like that are why we keep you around Mike. Simple. Effective. Sounds reasonable. 2 Share this post Link to post Share on other sites
Oldskool 6,666 #1188 Posted April 18, 2021 Glad to hear that @ebinmaine and all this time I thought it was for my good looks. 🤣🤣🤣🤣 3 Share this post Link to post Share on other sites
ebinmaine 76,596 #1189 Posted April 18, 2021 1 minute ago, Oldskool said: Glad to hear that @ebinmaine and all this time I thought it was for my good looks. 🤣🤣🤣🤣 Well of course there's that too!!!!!!! 3 Share this post Link to post Share on other sites
ranger 1,838 #1190 Posted April 18, 2021 If you need to clamp round bar and don’t have any “V” blocks, cut some angle iron the round bar will sit in, position one piece with the “V” upwards weld another piece on either side with one leg of the angle sitting flat and facing outwards. Drill holes in the ‘feet’ to suit ‘U’ bolt clamps, etc. You then have an improvised “Keats” block which can securely hold round bar, tube, for drilling/welding, etc. 5 1 Share this post Link to post Share on other sites
Lee1977 7,508 #1191 Posted April 18, 2021 14 hours ago, Oldskool said: How bout cut the head off of 2 bolts that screw into the tie rod. Screw them into the tierod. Then place one in the drill press chuck and the other in a hole drilled into a wood block clamped in your vise. A vertical metal lathe if you will. Use a grinder with a flap disc while the tierod is spinning in the drillpress. You created a monster, Eric will have designer spindles painted up in three different colors. 6 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #1192 Posted April 18, 2021 Or use the @pullstart method , wrap your finger around the round stock and let your finger slip down a little as you tighten the vice quickly . Nice red color on the round stock and a flat finger to boot. 5 Share this post Link to post Share on other sites
Pullstart 68,663 #1193 Posted April 18, 2021 9 minutes ago, elcamino/wheelhorse said: Or use the @pullstart method , wrap your finger around the round stock and let your finger slip down a little as you tighten the vice quickly . Nice red color on the round stock and a flat finger to boot. Whatever it takes to get the job done! 3 Share this post Link to post Share on other sites
Pullstart 68,663 #1194 Posted April 18, 2021 I say just have BBT hold it. Odds are, she’s got a tougher grip than the vice! 1 1 Share this post Link to post Share on other sites
ebinmaine 76,596 #1195 Posted April 18, 2021 12 minutes ago, Lee1977 said: You created a monster, Eric will have designer spindles painted up in three different colors. Oh The Paint Department has waaay more than 3 colors just on the downstairs bench. Share this post Link to post Share on other sites
ranger 1,838 #1196 Posted April 18, 2021 16 hours ago, ebinmaine said: Yessir it sure was. Ya done good. Next time I'll measure the proposed needed length and slice off the other side with my new toy bandsaw. Another great idea from you. 👍👍👍 I'm thinking I'll use a grinder or angle chop saw to narrow down the ends a little. Mark out a smaller hex on the ends of the bar, to the size of the lock nut, grind/sand/file down to the mark, keeping the surfaces flat, as you work your way around the bar, you’ll have a hex bar with ends that taper down in diameter, + hex flats to match. 1 1 Share this post Link to post Share on other sites
ebinmaine 76,596 #1197 Posted April 18, 2021 4 hours ago, ranger said: Mark out a smaller hex on the ends of the bar, to the size of the lock nut, grind/sand/file down to the mark, keeping the surfaces flat, as you work your way around the bar, you’ll have a hex bar with ends that taper down in diameter, + hex flats to match. Another neat idea. 1 Share this post Link to post Share on other sites
ebinmaine 76,596 #1198 Posted April 20, 2021 Ok first of all. New DeWalt bandsaw. UTTER. BEAST. What an incredible piece of equipment. Everyone who ever reads this should tell everyone they know and 2 dozen they don't know that Eric me Bear 🐻 says this is THE BEES KNEES. Well the reason I got that at all is for the new found interest in heat sticking metal together. I tried it tonight to cut that 1-1/8" mild steel hex rod. Just. Butter. I sliced up one of the tie rods to size. Drilled and tapped it. Tried it out. Seems to be a usable length with good adjustment. Oh yes and a bonus pic. This is a young barred owl that was hanging out in the road this morning. I backed up past it to check welfare. It flew about 5 feet to the edge of the road so it was likely ok. For scale it was around 10 or 11 inches as standing. 7 Share this post Link to post Share on other sites
Gregor 4,847 #1199 Posted April 20, 2021 (edited) Someone stole your tie rod hole! How do you steal a hole? And how do you know when you have? Edited April 20, 2021 by Gregor 3 Share this post Link to post Share on other sites
ebinmaine 76,596 #1200 Posted April 20, 2021 1 minute ago, Gregor said: Someone stole your tie rod hole! I'm hoping I can fix that. Share this post Link to post Share on other sites
