RickyMayhew 37 #1 Posted August 12, 2019 (edited) 702 with Kohler k161s what size allen wrench fits the oil drain plug. I tried everyone i have, no luck. New to Wheel Horse. Edited August 12, 2019 by RickyMayhew Share this post Link to post Share on other sites
peter lena 9,952 #2 Posted August 12, 2019 i think its either 3/8" or 1/4" , pete Share this post Link to post Share on other sites
pfrederi 20,892 #3 Posted August 12, 2019 Transmission Drain is 1/4" 3 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #4 Posted August 12, 2019 I use a plumbing tool that is at a 90% It gives great leverage! 1 Share this post Link to post Share on other sites
pacer 3,180 #5 Posted August 12, 2019 Make sure you clean out the hex recess really good to make sure the Allen seats all the way in, these things can sometimes get really stuck and you want to make sure it doesnt slip! 4 1 Share this post Link to post Share on other sites
WHX?? 57,470 #6 Posted August 12, 2019 Carefully raise the front of the tractor up there is a cup or so of oil ahead of the "hump". Let us know what comes out to see if you need to flush or not. Share this post Link to post Share on other sites
squonk 47,423 #7 Posted August 12, 2019 Guys I believe he might talking about the engine oil drain. My 701 had a hex plug in the block. I think it was still 1/4" 1 1 Share this post Link to post Share on other sites
stevasaurus 23,748 #8 Posted August 12, 2019 If that is the case Mike...he may want to put in some pipe to make it like the rest of our 702s. Share this post Link to post Share on other sites
pacer 3,180 #9 Posted August 12, 2019 1 hour ago, squonk said: t talking about the engine oil drain The OP wasnt asking a dumb question -- but some of us were answering it rather dumbly without REALLY reading it!! 2 Share this post Link to post Share on other sites
pacer 3,180 #10 Posted August 12, 2019 1 hour ago, squonk said: t talking about the engine oil drain The OP wasnt asking a dumb question -- but some of us were answering it rather dumbly without REALLY reading it!! Share this post Link to post Share on other sites
RickyMayhew 37 #11 Posted August 12, 2019 (edited) yes engine oil plug Thank you somuch Edited August 12, 2019 by RickyMayhew Share this post Link to post Share on other sites
squonk 47,423 #12 Posted August 12, 2019 Funny engine drain story. I replaced the engine in my 1267. I wanted to change the oil before the Steam Pageant. I looked and no drain pipe out the left side. Hmmm I can't believe I didn't put a pipe on it Oh Well ordered a 3/8" brass street elbow a pipe and cap. Go to put it in and it has an old oil level sensor in the block. Take it out and it's 1/2 " pipe. Go back to the store and get a bushing and finish up. Sitting at the show I look over at the tractor and there is a 3/8 square head plug on the right side of the engine already! 4 Share this post Link to post Share on other sites
RickyMayhew 37 #13 Posted August 12, 2019 (edited) the engine just turned over, got compression? but do not see piston moving.? is that possible I am new at this. shoots out of the carb. and muffler Edited August 12, 2019 by RickyMayhew 1 Share this post Link to post Share on other sites
RickyMayhew 37 #14 Posted August 12, 2019 This is the oil drain Share this post Link to post Share on other sites
RickyMayhew 37 #15 Posted August 12, 2019 I believe its stripped someone trued to take it off with a punch looks like. Share this post Link to post Share on other sites
WHNJ701 4,173 #16 Posted August 12, 2019 just use a vise grip to get it out and get s new replacement plug 1 Share this post Link to post Share on other sites
lynnmor 8,915 #17 Posted August 12, 2019 If the vice grip doesn't work, you can make a tool from an allen wrench one size larger, just grind it so that the tip tapers down to the original size. Cut off the other leg and then use it like a punch, hammering it in the knackered hole, then turn out the plug with it. Share this post Link to post Share on other sites
rjg854 13,200 #18 Posted August 12, 2019 I just had that same problem, and @squonk let me borrow his socket easy outs. Easy peasy !! 1 Share this post Link to post Share on other sites
pacer 3,180 #19 Posted August 13, 2019 1 hour ago, squonk said: t talking about the engine oil drain The OP wasnt asking a dumb question -- but some of us were answering it rather dumbly without REALLY reading it!! Share this post Link to post Share on other sites
953 nut 67,500 #20 Posted August 13, 2019 12 hours ago, RickyMayhew said: the engine just turned over, got compression? but do not see piston moving.? is that possible I am new at this. shoots out of the carb. and muffler The spark plug is not directly under the spark plug hole so you wouldn't see the piston move with the head on the engine. If you have compression indication coming out of the carburetor the intake valve may be stuck open. Share this post Link to post Share on other sites
Pullstart 70,767 #21 Posted August 13, 2019 but the good news is that a head gasket is cheap and it might be all the parts you need to unstick the valve! That, and some elbow grease, and patience! Share this post Link to post Share on other sites
peter lena 9,952 #22 Posted August 13, 2019 now that i know what you are trying to do, get a 6" PIPE WRENCH ,solidly secure the tightening ring, maybe with channel lock pliers so that the bite or grip on the plug is solid, NO BOUNCE OR MOVEMENT, now use a 3 lb hammer to drive against the back of the wrench. making the wrench bite and the solid drive against it , will make that plug move. when you get it out , go to the hardware store and get the same size plug, with EXTERNAL DRIVE, so you don,t repeat the problem , pete Share this post Link to post Share on other sites
WHX?? 57,470 #23 Posted August 13, 2019 Or if you get the plug out re-pipe with nipples and a cap as Steve suggested. Another suggestion might be to drill the plug through and use standard easy outs. Might get a little messy but?? Sorry about the transmission confusion Ricky I just naturally thought that as you should be checking that too on this girl. I have never seen a engine with a hex drain plug like you or Mike has had. 1 Share this post Link to post Share on other sites
