drewd
Model # =???
drewd
Hi All,
I have what I believe is a Commando 800 but would like to confirm model and year.  Tag reads Model # 1 0100 6; Serial # 790336. Have had it for years (bought from original owner) and want to clean it up some.
Thanks!
pfrederi
1-0100 would make it a 1971 Workhorse 800  Does your s have an HH80 8hp Techumseh??
oliver2-44
:wwp:of the whole tractor
ZXT
:text-yeahthat:
drewd
Yes, it had a 8hp Tecumseh but I repowered it with a  10hp Tecumseh.  I have the original pamphlet for the 8hp and it is coded 181-72 so maybe it's a 72?  Also, did Workhorse come in all red?  This was always red and they always referred to it as Wheelhorse. Here are a few pics.  What do you think?
I am converting a 36" deck to work with on this machine and in late Winter will clean up the tractor.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
