Jordanhorse96 92 #1 Posted June 11, 2019 You can't imagine how many times I've had to take the carburetor on and off due to s*** in the float Bowl new fuel filters Jets getting clogged or the gasket on the bottom of carburetors don't seat right this tractor never ever does wht I want it to do omg it is haunted I swear 4 Share this post Link to post Share on other sites
19richie66 17,892 #2 Posted June 11, 2019 Fuel tank full of goo? Nice looking tractor. Share this post Link to post Share on other sites
Sparky-(Admin) 25,561 #3 Posted June 11, 2019 Got an in-line fuel filter on it? I hear those fuel tanks are a pain to get to but maybe it’s worth it to give it a proper cleaning or replace it. Member @19richie66 made a tank that fits in that “trunk” behind the seat. 3 1 Share this post Link to post Share on other sites
Jordanhorse96 92 #4 Posted June 12, 2019 Yes something I took carb off now it is spot less and the gas tank is clean thanks this tractor is really nice just needs to stop leaking gas on the carb or fuel pump always something on this one 1 Share this post Link to post Share on other sites
19richie66 17,892 #5 Posted June 12, 2019 Actually it’s for my wife’s 1054 but I plan on putting one in Hank, my 953. 4 6 Share this post Link to post Share on other sites
19richie66 17,892 #6 Posted June 12, 2019 Don’t give up. Wish I lived close.....we would figure it out. These have become my favorite wheelhorse tractors. 2 1 Share this post Link to post Share on other sites
953 nut 66,572 #7 Posted June 12, 2019 19 minutes ago, Jordanhorse96 said: take the carburetor on and off due to s*** in the float Bowl If you are using gas with ethanol STOP! Use this site to find the good stuff. https://www.pure-gas.org/ 9 minutes ago, Sparky said: those fuel tanks are a pain to get to Not too bad, all you have to do is remove the transaxle and then hope the 1/4-20 screws to the tank straps will come out! 4 Share this post Link to post Share on other sites
AMC RULES 37,259 #8 Posted June 12, 2019 Can't tell... do I see clamps on that fuel line? Share this post Link to post Share on other sites
19richie66 17,892 #9 Posted June 12, 2019 Noticed it but didn’t think nothing about it. Possible it could be seeping around the fuel lines under pressure when the float closes and the pump is still pumping. Share this post Link to post Share on other sites
Mike'sHorseBarn 3,560 #10 Posted June 12, 2019 12 hours ago, 953 nut said: If you are using gas with ethanol STOP! Use this site to find the good stuff. https://www.pure-gas.org/ I want to touch on this subject a little bit. Recently my father in law got a 250 gallon tank of ethanol free gas to use in his tractors on the farm and so that means I get to take a $20 bill down and fill my 5 gallon can. It was $3.83 a gallon when he filled the tank. I started using that in all my machines now. Small briggs engines, garden tractors, push mowers etc. You would not BELIEVE the difference that has made in my machines, they even run better! No more sand in the carb, just turn the key and go! Ok I'll stop now lol 6 1 Share this post Link to post Share on other sites
Jordanhorse96 92 #11 Posted June 12, 2019 The felines I use are pretty tight fit you want to slide them onto the fitting of the carburetor or the fuel pump they get stuck on so they don't leak also carb was off.it was clean the bowl gasket keeps leaking and I do not use ethanol gas I ant dumb tht stuff eats carb up belive me ik Share this post Link to post Share on other sites
adsm08 4,552 #12 Posted June 12, 2019 14 hours ago, 953 nut said: If you are using gas with ethanol STOP! Use this site to find the good stuff. https://www.pure-gas.org/ Not too bad, all you have to do is remove the transaxle and then hope the 1/4-20 screws to the tank straps will come out! If I was working on a car and "Remove transaxle" was anywhere in the instructions for getting the fuel tank out I would drive to Detroit, Tokyo, where ever, hunt down the guy that designed it, and shoot him myself. 1 4 Share this post Link to post Share on other sites
squonk 46,846 #13 Posted June 12, 2019 6 hours ago, adsm08 said: If I was working on a car and "Remove transaxle" was anywhere in the instructions for getting the fuel tank out I would drive to Detroit, Tokyo, where ever, hunt down the guy that designed it, and shoot him myself. Try getting a gas tank out of a 90's Ford Ranger PU 1 Share this post Link to post Share on other sites
adsm08 4,552 #14 Posted June 12, 2019 (edited) 31 minutes ago, squonk said: Try getting a gas tank out of a 90's Ford Ranger PU My DD is an 87 Ranger. One of my clients has a 99. Been there, done that, it isn't that bad. Certainly you don't have to remove the transmission, or rear axle. The tank is actually much harder to remove from my Bronco II. Edited June 12, 2019 by adsm08 Share this post Link to post Share on other sites
