oldredrider 2,553 #1 Posted May 18, 2019 Normally I mow with a C-160 auto with a 48" deck. Love it! This year though (so far) I've been using a 1993 Cub 1330. Don't hate me...there's a reason! Put in a "new" lawn last fall with shade grass. Heavily fertilized it then and again in the early spring. We've had very good wet weather that is conducive to a prime crop of grass. The Cub (which I'm not really fond of, is my wife's) has a bagger. With the grass growing at the rate of 4" per week, the bagger has been a blessing. As summer gets closer and the grass growth slows, I'll be back on the Horse. So what do you use and why? Share this post Link to post Share on other sites
Sparky-(Admin) 25,562 #2 Posted May 18, 2019 I alternate between my C-105 with a 42” side discharge deck and my Craftsman GT3000 with a 46” deck and a triple bagger setup. I also need to bag often. The Craftsman is comfy, powerful (20hp Kohler) and a hydro. So it’s a great mowing machine. 4 Share this post Link to post Share on other sites
prondzy 3,889 #3 Posted May 18, 2019 Mow 3/4 acre with my trusty 856 with 36in gear drive deck. Why, because this thing cuts the best ! 6 Share this post Link to post Share on other sites
JAinVA 4,638 #4 Posted May 18, 2019 (edited) I mow using the 416-8 with a 42"SD in the garden area due to space restraints.I used to use the same setup to mow the rest but finally mounted a 48" on the 416H to speed up the process.It is the first time I have had a deck on H in 2years.I know most of you enjoy mowing but I honestly think it is the least productive thing I do all year. Edited May 18, 2019 by JAinVA 3 Share this post Link to post Share on other sites
Razorback 1,347 #5 Posted May 18, 2019 I usually use a 2008 Craftsman PGT9000, 28hp (so it says) 2-cyl, 54” deck, triple bagger. Our lot is mostly Bermuda, almost an acre. I bag the clippings and use them for mulch/compost in the garden to keep the weeds down. 2 Share this post Link to post Share on other sites
Kurt-NEPA 756 #6 Posted May 18, 2019 I usually mow with my 522xi. The m ain reason is that I like the 52" deck and the power steering. I mowed with 3 520H's for years and still like them. 3 Share this post Link to post Share on other sites
Stormin 9,988 #7 Posted May 18, 2019 I use my C-125 with 43" rear discharge. I also have a 36" RD as a stand by. I mow the green and roadside verges plus a neighbours frontage. On the green I use a Wheel Horse lawn sweeper to collect the cuttings. I don't bother with the verges as they are far from flat. I also have a 43" SD but that has a twisted shell. 2 Share this post Link to post Share on other sites
SALTYWRIGHT 861 #8 Posted May 18, 2019 I USE A TORO ZERO TURN ON MY LAWN. IT IS VERY HARD FOR ME TO GET ON AND OFF A 8 SPEED WHEEL HORSE TRACTOR. 5 1 Share this post Link to post Share on other sites
jonw440 226 #9 Posted May 18, 2019 2006 JD 145 with bags. I only have a 36 RD for the 314-8. 1 Share this post Link to post Share on other sites
bigcreek 205 #10 Posted May 18, 2019 For now have parked the 314-h it has 42 RD, using the 417-8 with 42 in SD, she cuts great, burns little oil but this old tractor has 1690 hour of had use. I got her last year for 700 bucks. Scott 2 Share this post Link to post Share on other sites
lynnmor 8,845 #11 Posted May 18, 2019 I mowed for years with a 520H and 60" deck. In an effort relieve my Wheel Horses of this hard duty and cut mowing time, I bought a 60" zero-turn this spring. After 3 mowings, I have reduced the time, but I am not impressed with the results. Sure it will turn short while digging up the grass and soft soil, so that must be avoided. Side hills and less than perfect grading has the front wheels wandering like they aren't controlled..... wait, they have no control and straight lines are impossible. If you have a good tractor and wondered what you are missing, my opinion is; not much. 2 1 1 Share this post Link to post Share on other sites
squonk 46,852 #12 Posted May 18, 2019 76 C-160 Hydro with 42" RD Recycler deck. Used to have to sweep the back yard after mowing but I only have to do it maybe once now that I have the mulcher. If I want to do some "old school" mowing I get out " HHHOOOWWWAAARRRDDD!!! " 8 5 Share this post Link to post Share on other sites
gsummers 236 #13 Posted May 18, 2019 Either the 312-8 w 36" sd, 312-H W 42" sd OR THE 417-a W 42" sd, I also have a 42" rear discharge deck in the shed just in case something happens to any of the other decks. They all cut nice. 2 Share this post Link to post Share on other sites
71_Bronco 1,072 #14 Posted May 18, 2019 I've been using a 21" push mower for my 3/4 acre, but recently picked up a Commando 8 with a 36" gear drive rear-discharge deck. Super excited to use it once I finish going through it. 2 Share this post Link to post Share on other sites
953 nut 66,586 #15 Posted May 18, 2019 A couple years back I picked up a nice low hours 310-8 with a 42" RD deck and for me it is the go-to mower. I also have a 42" RD deck on the 418-C but don't mow with is as often because the 310-8 uses half as much gas. 8 Share this post Link to post Share on other sites
JAinVA 4,638 #16 Posted May 18, 2019 If you use ethanol free fuel that can mean money saved! 2 Share this post Link to post Share on other sites
953 nut 66,586 #17 Posted May 18, 2019 7 minutes ago, JAinVA said: use ethanol free fuel 2 Share this post Link to post Share on other sites
JoeM 10,035 #18 Posted May 18, 2019 First 20 years on a B100 Automatic, 36" RD, Then a JD X324, 48" SD, The last 5 on a Kubota GR2010 48" SD, I like the 4WD and Power Steering. I have a lot of slopes and arthritis. I do cut in the spring and fall with a 520 48" Mulch Deck, (home made). My buddy talked me into selling the deck so I am working on another. I missed it last fall especially. 1 Share this post Link to post Share on other sites
Herder 2,356 #19 Posted May 18, 2019 1968 Charger 12 with a 48" deck. 1976 C-160 H with a 48" deck is on standby. 2 Share this post Link to post Share on other sites
WHNJ701 4,172 #20 Posted May 18, 2019 must of the time it's the 854 with a 36 rd. I did use the 211-4 a few times 4 1 Share this post Link to post Share on other sites
jkosackuk 9 #21 Posted May 18, 2019 Last year I used a John Deere L123 cause that's all I had, now I'm restoring a Raider 10 and hope to mow with that though I'll have to find a deck somewhere. 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,542 #22 Posted May 18, 2019 C105. Why? Only one I’ve got...! 2 1 1 Share this post Link to post Share on other sites
PeacemakerJack 11,008 #23 Posted May 19, 2019 Great thread @oldredrider! It’s fun to see what everybody uses and why... Our primary mower is Kelli’s RED (523Dxi) with a 60” deck. The power steering, large mowing swath, foot controlled hydro, and it sips fuel for being a 1400# machine make it one of our regulars. Plus momma likes to use her tractor while getting some sun! I often use my 1772 Cub Diesel. I have a 50” deck for it. It’s a fun tractor, gives a sharp cut, uses very little fuel, and is a pretty fast machine. Caleb’s JackRabbit (418-C) is quickly becoming a regular use mower as well. It has a 42” SD but also has the full bagger system which is excellent for those many moments when the lawn is unruly. It has fast gearing and convenient tight steering ratio... There is several other machines that we occasionally use because we have them but the above are our primary mowers... 8 1 Share this post Link to post Share on other sites
ebinmaine 79,136 #24 Posted May 19, 2019 2 hours ago, 71_Bronco said: 21" push mower That's what we use in combination with a string trimmer. We have a decent amount of land and it's almost all forest. Very little grass. Also VERY rough terrain being half way up the side of the ancient Appalachian Mountains. Extremely Rocky. 1 Share this post Link to post Share on other sites
chip61 666 #25 Posted May 19, 2019 C160 at home and son's house. 416H and 314-8 down in Mathews where I cut close to 6 acres between my place, my fil's and my 2 neighbor's. I know a zero turn would be faster, but I like tractors. I have considered finding a swept axle and 60" deck for the 416. I think it could handle it except for my neighbor's field that I only cut every 4-5 weeks. A small diesel would be nice if a good deal came along. 2 Share this post Link to post Share on other sites
