Bill D 2,584 #1 Posted May 13, 2019 I was wondering if anyone had converted their Kohler over to a vacuum impulse pump using one of Brian Miller's blank off plates? I noticed that all of my neighbors tractors that have them, including my neighbors GT1100, start much easier than my Kohlers with the mechanical pumps. My GT1642 has a vacuum impulse pump built into the carb and it starts great, especially after sitting all winter. Bill Share this post Link to post Share on other sites
ebinmaine 77,079 #2 Posted May 13, 2019 @squonk @953 nut I know it isn't exactly what you're looking for but I'm thinking the guys mentioned above have switched over to electronic pumps. Share this post Link to post Share on other sites
pfrederi 19,794 #3 Posted May 13, 2019 Go electric. If the pulse pumps fail they can leak gas into the crank case and damage the engine. Get a Facet pump. 3 1 Share this post Link to post Share on other sites
kwalshy 242 #4 Posted May 14, 2019 Went to the electric Facet pump & I’m very happy Share this post Link to post Share on other sites
953 nut 63,974 #5 Posted May 14, 2019 There are two check valves in the mechanical fuel pumps om Kohler engines. After several years they begin to leak by and allow the fuel to flow back to the tank. I have gone to electric pumps on several of mine with good results. A rebuild kit is another good option. http://www.then-now-auto.com/kohler-fuel-pumps-2/ Share this post Link to post Share on other sites
Bill D 2,584 #6 Posted May 15, 2019 Has anyone had a mechanical fuel pump fail and leak gas into the engine? I have seen this on a car before. Bill Share this post Link to post Share on other sites
squonk 45,377 #7 Posted May 15, 2019 5 hours ago, Bill D said: Has anyone had a mechanical fuel pump fail and leak gas into the engine? I have seen this on a car before. Bill Many times Share this post Link to post Share on other sites
JimmyJam 542 #8 Posted May 15, 2019 On 5/13/2019 at 1:13 PM, pfrederi said: Go electric. If the pulse pumps fail they can leak gas into the crank case and damage the engine. Get a Facet pump. How do you know what Facet pump to get? ...and where did you get them? Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #9 Posted May 16, 2019 (edited) 13 hours ago, JimmyJam said: How do you know what Facet pump to get? ...and where did you get them? Try to stay in the 1-3psi Max range and you should be OK... eBay Amazon NAPA ect Edited May 16, 2019 by WVHillbilly520H Share this post Link to post Share on other sites
buckrancher 2,695 #10 Posted May 16, 2019 On 5/14/2019 at 11:20 PM, Bill D said: Has anyone had a mechanical fuel pump fail and leak gas into the engine? I have seen this on a car before. Bill I have never seen this on the single cylinder engines 1 Share this post Link to post Share on other sites
oneroadkingman 53 #11 Posted May 17, 2019 does anyone know if you can take the pulse pump off a p220 and change it to an electric pump? thanks, in advance Rick Share this post Link to post Share on other sites
953 nut 63,974 #12 Posted May 17, 2019 On 5/16/2019 at 9:10 AM, buckrancher said: I have never seen this on the single cylinder engines I just had one fail and was leaking gas out of the housing inside and out. Rebuilt the pump and changed the oil. Not much gas in the oil, but wouldn't take much to ruin a perfectly good engine. 1 Share this post Link to post Share on other sites
953 nut 63,974 #13 Posted May 17, 2019 17 hours ago, oneroadkingman said: does anyone know if you can take the pulse pump off a p220 and change it to an electric pump? thanks, in advance Rick Yes, an electric pump will work well. Be sure to mount the pump low on the frame and take power from the "A" terminal of your ignition switch and install a fuse ( 5 or 10 amps) in the line. Share this post Link to post Share on other sites
oneroadkingman 53 #14 Posted May 17, 2019 thanks very much 953 nut. guess I will need to plug the vacuum hose that was connected to the pulse pump correct? Share this post Link to post Share on other sites
953 nut 63,974 #15 Posted May 17, 2019 3 minutes ago, oneroadkingman said: I will need to plug the vacuum hose that was connected to the pulse pump Yes. 1 Share this post Link to post Share on other sites
oneroadkingman 53 #16 Posted May 17, 2019 I'm enjoying my freedom so id like to thank u for your service !! 1 Share this post Link to post Share on other sites
