Rob R
Kohler 321 Engine Pan
Rob R
 I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
Here's my questions:
> Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
> Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
> If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
> any recommendations here would be appreciated don't want to go down to many blind holes here...….
Thanks much!
daveoman1966
What is the pan-to-engine bolt pattern?  How deep do you need the pan to be?  I have several pans here from 12-14 Kohler engines,but need to know a little more.  Canm we do this in emails...outside of RS?  My email is:
daveoman@windstream.net...
WHX??
I would not use the Ford pan. It was for a tube frame and I think it would not be worth the effort to modify it.  It may have some value to the Ford collectors. Should be able to just put a standard K series deep pan on it. Those should be easy to find. The dipper clearance should be check and trimmed if required. I don't see the use of a short pan with the tractor you are putting it in. You probably have seen this Rob but just for reference here.
https://www.wheelhorseforum.com/topic/44945-identifying-big-block-kohler-block-styles/
Are you going to leave the balance gears in?
Edited by WHX22
82Caddy
Easiest option would be a pan like this:
With that said, none of your belts, guards or the like would line up.  The pan is about an inch shorter then what a wheel horse pan is so the engine will sit closer to the frame.
WHX??
After further review scratch that idea... won't fit that block. Caddy's got a good plan tho. Maybe space it up on channels for better fit with the guards? May have to notch the frame for clearance on the deep sump. Or go with the shallow pan without the sump,  snip the dipper and space it up? Just thinkin out loud here.
Edited by WHX22
Rob R
Thanks for the response Jim what you are saying makes perfect sense I definitely need a small K series deep pan (at least 2 inches) and probably need to trim the dipper as I have the long one and the current Ford pan has a deeper valley on one side.....  The balance gears are good and very tight so I planned on leaving them in.... plus I don't know how to take them out...…  Anyone out there have one of these at a decent $?
Edited by Rob R
Eric Friedrichsen
Rob,
I have a spare Magnum 321 pan in good condition that you can have. I live in Wilton CT which is only 30 min. from Brewster.
If you want it call me at 203-752-0043. The depth of the pan from the base to the gasket edge is 2 and 3/8 inches. It should fit
your engine fine.
Eric Friedrichsen
  • Sad 1
82Caddy
That’s the wrong kind of oil pan for a small base engine (more square). That will only work with a big base engine block (long rectangle).
Shynon
:text-yeahthat:
953 nut
Check out this post and see how Jay @JPWH tackled this issue. Start with Post # 78.
  • Similar Content
    • Rob R
      By Rob R
      I finally broke something serious on my GT14 the Lift arm that is attach (by chain) to the plow snapped off at the receiver arm top which is attached to the Hydro cylinder on the bottom. It appears the broken arm was welded there (see pics) my big question is how do get the "H" arm which is mounted on each side of the tractor by the steel plates the go up from the tractor frame out. I took off the four mounting bolts for it but it is tightly fit in aforementioned side plates I can move it up and down but cannot get it out. Is it relatively easy to remove one of the side plates and if yes which side is the easiest the pedal side left side (from the back) or the right side (from the back). Has anyone from the square experienced this problem, does anyone have this lift assembly. Any and all comments welcomed. p.s. I have used this beast for 10 years with zero major issues guess the stress of the lifting finally got to the arm which obviously is under tremendous pressure......Rob
    • Rob R
      By Rob R
      Hi Guys, got a K321 14HP Kohler in house with all the electrical components removed. I cleaned and aligned the points, added a 12v (resistor coil) positive 12V battery feed to positive terminal, ran a line from the negative side of the coil to the points. I know I have to add a condenser also to the negative side. My question is does location of the condenser matter i.e. next to the coil or is closer to the points better. Thanks Rob
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
