The Tuul Crib 7,354 #1 Posted April 28, 2019 Been trying to get my K321 running. I can get a fairly smooth idle but when I throttle up I sputters like crazy. I’ve tried setting the float several times and still the same thing. Its puffing out black smoke and the plug is black as well. It’s definitely on the rich side. Any ideas? Share this post Link to post Share on other sites
ebinmaine 78,263 #2 Posted April 28, 2019 What have you done to the carb so far? Disassemble. Clean. Reassembly.? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted April 28, 2019 It’s a new Chinese one and I’ve adjusted the float three times. Share this post Link to post Share on other sites
ebinmaine 78,263 #4 Posted April 28, 2019 I took my new Chinese one apart three times. Basically rebuilt it each time. Double triple check all your settings according to the Kohler manual. After the third disassembly I got sick of it and ordered the correct one from Lincoln. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted April 28, 2019 New plug black as coal. Share this post Link to post Share on other sites
wallfish 19,733 #6 Posted April 28, 2019 It doesn't lean out at all when you tighten the high speed screw? 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #7 Posted April 28, 2019 1 hour ago, wallfish said: It doesn't lean out at all when you tighten the high speed screw? No its not helping at all . Im going to try new points and condenser and see if that helps. Share this post Link to post Share on other sites
ebinmaine 78,263 #8 Posted April 28, 2019 Have you taken apart that new carb and checked it? Mine had metal shavings in the bowl. Share this post Link to post Share on other sites
wallfish 19,733 #9 Posted April 28, 2019 53 minutes ago, The Tool Crib said: No its not helping at all If the engine will run with the top high speed needle closed all the way, there is a problem with that carb. It may idle but it should not run at high speed because it should be starving for fuel. I've had problems with some of those carbs flooding for some reason. Never did figure out exactly what was going on. 1 Share this post Link to post Share on other sites
ebinmaine 78,263 #10 Posted April 28, 2019 2 minutes ago, wallfish said: I've had problems with some of those carbs flooding for some reason 6 hours ago, ebinmaine said: took my new Chinese one apart three times. Basically rebuilt it each time Apparently an issue with the clearances and tolerances being a little too generous in those cheap carbs. I called it a learning experience and bought a Kohler carburetor. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #11 Posted April 28, 2019 Well i went and got new points and condenser and im going from there. When i got this motor i left the old ones in it . They looked ok but maybe they weren’t. 1 Share this post Link to post Share on other sites
Herder 2,355 #12 Posted April 28, 2019 1 hour ago, The Tool Crib said: Well i went and got new points and condenser and im going from there. When i got this motor i left the old ones in it . They looked ok but maybe they weren’t. Any luck with the points? 953nut posted a guide for static timing. Very helpful! Share this post Link to post Share on other sites
The Tuul Crib 7,354 #13 Posted April 28, 2019 30 minutes ago, Herder said: Any luck with the points? 953nut posted a guide for static timing. Very helpful! No i have to wait on our postal service now. Just ordered off of fleabay. Good luck there! 1 Share this post Link to post Share on other sites
Oldschool64 1 #14 Posted April 29, 2019 Disassembly the carb completely and use compressed air to blow through ever port. Something has to be stopped up inside the carb. Or its not been machined correctly. Share this post Link to post Share on other sites
formariz 12,359 #15 Posted April 29, 2019 I don't know what exactly may be the cause of your problem, however related to the Chinese carburetors and to me having a bit of an obsessive nature and spending a lot of time researching carburetors and their respective Kohler engines in Brian Miller's site, I found that none of them have the right tolerances for a particular engine the way they should such as venturi dimensions, needle holes positions and locations.I always duplicated his recommendations and specs when replacing a carburetor for a specific engine and I solved numerous carburetor issues that way. Many times an engine came to me that I just could not make right regardless of how much and how many times I cleaned a carb or bought a cheap Chinese one. However when I followed his specs and got exactly the right carb everything worked fine. 1 Share this post Link to post Share on other sites
ebinmaine 78,263 #16 Posted April 29, 2019 Not sure if it has anything to do with Randy's issue or not but just as a point of information I took a Chinese carburetor off and put on a Kohler today as stated above. The Chinese carburetor inside throat size was nearly 1/16" smaller then the Kohler # 30 carburetor. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #17 Posted April 29, 2019 28 minutes ago, ebinmaine said: Not sure if it has anything to do with Randy's issue or not but just as a point of information I took a Chinese carburetor off and put on a Kohler today as stated above. The Chinese carburetor inside throat size was nearly 1/16" smaller then the Kohler # 30 carburetor. Is the #30 the same throat size as a walbro? Thats what was on this k321 when i got it. I would put it back on if it wasn’t for the choke orientation . Share this post Link to post Share on other sites
formariz 12,359 #18 Posted April 29, 2019 #30 carburetors can be different internally depending what engine they were used on. Some earlier K321s had 1-1/8" exhaust valves compared to later ones that hove 1-3/8" exhaust valves. Corresponding #30s also had different venturi and throttle bore dimensions. It is also important to have the right high speed needle adjuster in it. Most of the times carburetors and their parts have been changed several times over the years without paying attention to what is actually correct. To start with if you know the valve size in your engine or at least the size on the intake port? I am not saying that this is your problem, however if you carburetor is undersized for your engine it is possible that engine creates too much suction therefor flooding engine . 1 Share this post Link to post Share on other sites
ebinmaine 78,263 #19 Posted April 29, 2019 @formariz Good info there Cas. Thanks. I wasn't aware of that size difference. Share this post Link to post Share on other sites
wallfish 19,733 #20 Posted April 29, 2019 A bad condenser will cause the throttle up sputtering issue. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #21 Posted April 29, 2019 I took the plug and I do have spark but it seems weak. I’m hoping the points and condenser help! Share this post Link to post Share on other sites
