ZXT 2,402 #751 Posted May 29, 2019 Is there a piece of it missing? Looking at the threaded section down by the drill bit.. Thinking maybe you put the threads of whatever it is in there, and maybe another piece goes on to complete the claim shell, and then the bit center drills it.. Wild guess, but maybe something for drilling out the electrode in a spark plug? Not sure if that's even a thing, but I figured it was better than no guess at all. Share this post Link to post Share on other sites
Ed Kennell 47,689 #752 Posted May 29, 2019 2 minutes ago, ZXT said: Is there a piece of it missing? Looking at the threaded section down by the drill bit.. Thinking maybe you put the threads of whatever it is in there, and maybe another piece goes on to complete the claim shell, and then the bit center drills it.. Wild guess, but maybe something for drilling out the electrode in a spark plug? Not sure if that's even a thing, but I figured it was better than no guess at all. No, nothing missing. I like the center drill idea. No spark plugs involved. Give me 3-4 more good guesses and I'll drop a clue. Share this post Link to post Share on other sites
Ed Kennell 47,689 #753 Posted May 30, 2019 Tap..Tap….Tap Did you give up? 1 Share this post Link to post Share on other sites
ebinmaine 81,001 #754 Posted May 30, 2019 I'm still here at but I don't have any good guesses. Been meaning to find something at home to post. Eventually I'll remember.... 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #755 Posted May 30, 2019 Dental drill? 1 Share this post Link to post Share on other sites
formariz 12,381 #756 Posted May 30, 2019 I can see fully how this works. Essentially it is designed to slip what ever is worked on on the bottom. Then the second adjustment threads down into that precising centering it with the bit. There seems to be also some sort of "key" aligning method. Then third step seems to be bringing down bit close to it, then finally turning lever to drill out what ever it is. Looks like what ever it is it removes is small.Just cant think what. 1 Share this post Link to post Share on other sites
Ed Kennell 47,689 #757 Posted May 30, 2019 Great, you guys are thinking again. There were some clues above. This should help. Share this post Link to post Share on other sites
formariz 12,381 #758 Posted May 30, 2019 Some type of water valve or fitting? 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #759 Posted May 30, 2019 What’s the overall length? Share this post Link to post Share on other sites
Ed Kennell 47,689 #760 Posted May 30, 2019 Just now, LengerichKA88 said: What’s the overall length? 5" Share this post Link to post Share on other sites
Ed Kennell 47,689 #762 Posted May 30, 2019 Did that help? Share this post Link to post Share on other sites
formariz 12,381 #763 Posted May 30, 2019 Valve core removal tool?? Share this post Link to post Share on other sites
formariz 12,381 #764 Posted May 30, 2019 To drill out stripped screw when changing fawcett seal? 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,689 #765 Posted May 30, 2019 This tool may have been obsolete before you youngens had an opportunity to use it. Before all faucets came with replaceable cartridges, the faucet body contained a cup that centered a rubber washer that was held in place by a slotted brass screw. When the washers wore out and needed replaced, the brass screws either broke off or the heads were corroded away. So this tool was used exactly as Cas described above to drill out the old screw. 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #766 Posted May 30, 2019 1 minute ago, Ed Kennell said: This tool may have been obsolete before you youngens had an opportunity to use it. Before all faucets came with replaceable cartridges, the faucet body contained a cup that centered a rubber washer that was held in place by a slotted brass screw. When the washers wore out and needed replaced, the brass screws either broke off or the heads were corroded away. So this tool was used exactly as Cas described above to drill out the old screw. Before my time, that’s for sure 😂 I doubt I’d have gotten it alone Share this post Link to post Share on other sites
formariz 12,381 #767 Posted May 30, 2019 (edited) I want one! Just recently that happened to me on one that had not been operated in perhaps over 20 years. Still available? Edited May 30, 2019 by formariz Share this post Link to post Share on other sites
Ed Kennell 47,689 #768 Posted May 30, 2019 Crest Mfg. Co. made this one. They may now be Crest Good Mfg. 1 Share this post Link to post Share on other sites
formariz 12,381 #769 Posted May 30, 2019 Here we go. Most likely unknown by most. 1 Share this post Link to post Share on other sites
ebinmaine 81,001 #770 Posted May 30, 2019 39 minutes ago, formariz said: Here Interesting lookin mode of torture... Seems as though the round handle would go through the hole on the curved piece. Producing leverage? ...or perhaps locking it into a given position? I'll be looking forward to seeing what the hints are on this one. 1 Share this post Link to post Share on other sites
formariz 12,381 #771 Posted May 30, 2019 (edited) Good thinking. its a pretty simple device. Hand forged by a blacksmith. This one is probably 40 years old but they been around for hundreds of years. Edited May 30, 2019 by formariz 1 Share this post Link to post Share on other sites
stevasaurus 23,859 #772 Posted May 30, 2019 Looks like a tent steak and the handle for removing. 1 Share this post Link to post Share on other sites
formariz 12,381 #773 Posted May 30, 2019 2 minutes ago, stevasaurus said: Looks like a tent steak and the handle for removing. Not even close but I really like your answer. Very imaginative thinking. 1 Share this post Link to post Share on other sites
stevasaurus 23,859 #774 Posted May 30, 2019 Would it be used to lock down a piece of wood that you are working on... on a carpenters bench. Share this post Link to post Share on other sites
formariz 12,381 #775 Posted May 30, 2019 How would it do that? Share this post Link to post Share on other sites
