Mows4three 833 #276 Posted May 8, 2019 Gunstock gravers for checkering. Share this post Link to post Share on other sites
formariz 12,356 #277 Posted May 8, 2019 You are joining me in the cigar room. Share this post Link to post Share on other sites
Mows4three 833 #278 Posted May 8, 2019 (edited) Found this one a few days ago. Was waiting for a chance to post it. Dave Edited May 8, 2019 by Mows4three 1 Share this post Link to post Share on other sites
formariz 12,356 #279 Posted May 8, 2019 It looks like some type of bender. Wire? Share this post Link to post Share on other sites
Mows4three 833 #280 Posted May 8, 2019 Nope. Not a bender of any sort. Share this post Link to post Share on other sites
formariz 12,356 #281 Posted May 8, 2019 What trade is it used in? Share this post Link to post Share on other sites
Mows4three 833 #282 Posted May 8, 2019 Not used in a trade. Share this post Link to post Share on other sites
formariz 12,356 #283 Posted May 8, 2019 (edited) Used in prying or applying leverage? Looks like a fencing tool. Edited May 8, 2019 by formariz Share this post Link to post Share on other sites
Mows4three 833 #284 Posted May 8, 2019 Definitely used to apply leverage but nothing to do with fencing. Share this post Link to post Share on other sites
SylvanLakeWH 30,683 #285 Posted May 8, 2019 Tire tool / bead setter? Share this post Link to post Share on other sites
Stormin 9,987 #287 Posted May 8, 2019 Undoing caps on 45 gallon drums? Share this post Link to post Share on other sites
Mows4three 833 #288 Posted May 8, 2019 Not a tire tool or bead setter and not an opener. Share this post Link to post Share on other sites
Mows4three 833 #289 Posted May 8, 2019 Nothing to do with 55 gallon or other sized drums. Share this post Link to post Share on other sites
formariz 12,356 #290 Posted May 8, 2019 Lets just analyze it a bit. It looks like it will hold on to one part with bent rod, which also looks like it could be driven into what ever material is used, and then one applies leverage with the other part puling them both together. Same principle as some flooring gadgets I know. Is my thinking correct? Share this post Link to post Share on other sites
Mows4three 833 #291 Posted May 8, 2019 Your thinking is correct as applied to leverage, but nothing to do with flooring. Hint: It is adjustable to give better leverage on the different sized objects it is meant to be used on and the bent rod is key to its operation. Dave Share this post Link to post Share on other sites
formariz 12,356 #292 Posted May 8, 2019 (edited) I only mentioned flooring as an example. If not used in any trade is it farm or agricultural use? Is it intended for wood or other material? You state objects, so not necessarily materials but individual objects? I fully understand how it works just a little stumped by not being used on any trade. Perhaps a profession hint. It pulls two objects together in preparation for next step? looking at bearing surfaces areas material must be metal. Edited May 8, 2019 by formariz Share this post Link to post Share on other sites
posifour11 723 #293 Posted May 8, 2019 12 hours ago, Mows4three said: Found this one a few days ago. Was waiting for a chance to post it. Dave I know, but I kinda cheated. So, I'll stay out of it. 😨 Share this post Link to post Share on other sites
Mows4three 833 #294 Posted May 8, 2019 (edited) Not a trade. Used in a profession. The adjustability allows it to be used on different sizes of the same kind of object. Although rusty, this tool is used in a generally clean environment. The tool is made of steel or iron, but the objects it is used on are not metal or wood. Dave Edited May 8, 2019 by Mows4three Share this post Link to post Share on other sites
formariz 12,356 #295 Posted May 8, 2019 Can you give us a bit of perspective as to the size of this tool? Share this post Link to post Share on other sites
ebinmaine 77,585 #296 Posted May 8, 2019 Might this be used in the medical field? Share this post Link to post Share on other sites
LengerichKA88 1,885 #297 Posted May 8, 2019 (edited) Is it used for upholstery? To pull fabrics tight to be tacked 🤷🏻♂️ Or dentistry? Can’t find an exact match, but it looks similar to a few tools I’ve seen. Edited May 8, 2019 by LengerichKA88 Share this post Link to post Share on other sites
Mows4three 833 #298 Posted May 8, 2019 Approximately 8-9" OAL. Not used to stretch fabrics but if it was put into use, you would potentially suck several inches of seat fabric off of a chair. Used in vintage orthodontics. Share this post Link to post Share on other sites
ebinmaine 77,585 #299 Posted May 8, 2019 7 minutes ago, Mows4three said: Used in vintage orthodontics I had a feeling this was used in some sort of ancient torture or body mechanical disassembly procedure. Dave I don't suppose you would be so kind as to make a short video of you using that tool on something like a mountain lion or a neighbor you don't like very much? It would assist us in our mission to identify above pictured torture device. Share this post Link to post Share on other sites
LengerichKA88 1,885 #300 Posted May 8, 2019 (edited) Extractor? flat side against the gums, hook under tooth, push and pull, tooth out. Unless its some kind of painful retainer adjuster thats about all I got Edited May 8, 2019 by LengerichKA88 Share this post Link to post Share on other sites
