Ed Kennell 47,403 #76 Posted September 24, 2019 Cleaning off some shelves and found this. Any ideas? Share this post Link to post Share on other sites
SylvanLakeWH 32,616 #77 Posted September 24, 2019 (edited) Some kind of directional river flow gauge...? Kind of looks like the device in this picture... Edited September 25, 2019 by SylvanLakeWH 1 Share this post Link to post Share on other sites
CasualObserver 3,416 #78 Posted September 24, 2019 Appears all stainless... going to guess some sort of food/dairy/beer or chemical tank mixer? 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #79 Posted September 24, 2019 Looks like apart off a wind mill. Being stainless it shouldnt rust. 1 Share this post Link to post Share on other sites
formariz 12,381 #80 Posted September 30, 2019 @Ed KennellIts a water current meter. What kind of need did you have for it Ed? Share this post Link to post Share on other sites
oliver2-44 11,758 #81 Posted October 1, 2019 I suspect Ed tested Hydro Turbines with it Share this post Link to post Share on other sites
Ed Kennell 47,403 #82 Posted October 1, 2019 On 9/24/2019 at 4:58 PM, SylvanLakeWH said: Some kind of directional river flow gauge...? Kind of looks like the device in this picture... That's it Jim. 14 hours ago, formariz said: @Ed KennellIts a water current meter. What kind of need did you have for it Ed? 10 hours ago, oliver2-44 said: I suspect Ed tested Hydro Turbines with it Yep, I used it to measuring water velocity in open flume model hydro turbine test stand in the 1960s. It is a really fine instrument that I didn't have the heart to scrap when we went to closed loop test stands with venturi type flow meters. The impeller has one of the most friction free bearings I have ever seen. With the flick of a finger, the impeller will spin forever. The venturi meters were eventually replaced with magnetic flowmeters. This flow meter was also used to measure flow during hydro turbine index testing by dropping the meter in front of turbine intake as shown in Jim's photo. The tail fins aligned the meter with the flow direction and the voltage produced by spinning impelled was calibrated for velocity. Other devices used to measure flow were pitot tubes and the salt velocity method. 4 Share this post Link to post Share on other sites
Ed Kennell 47,403 #83 Posted October 8, 2019 This should be easy as the modern day version are pretty common. But this is an earlier version that I have never seen before. Share this post Link to post Share on other sites
bc.gold 3,406 #84 Posted October 8, 2019 36 minutes ago, Ed Kennell said: This should be easy as the modern day version are pretty common. But this is an earlier version that I have never seen before. Belongs in the kitchen. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #85 Posted October 8, 2019 On 10/1/2019 at 9:02 AM, Ed Kennell said: The impeller has one of the most friction free bearings I have ever seen. With the flick of a finger, the impeller will spin forever. https://en.wikipedia.org/wiki/Air_bearing Air bearings (also known as aerostatic or aerodynamic bearings) are bearings that use a thin film of pressurized gas to provide a low friction load-bearing interface between surfaces. The two surfaces do not touch, thus avoiding the traditional bearing-related problems of friction, wear, particulates, and lubricant handling, and offer distinct advantages in precision positioning, such as lacking backlash and static friction, as well as in high-speed applications.[1] A differentiation is made between aerodynamic bearings, which establish the air cushion through the relative motion between static and moving parts, and aerostatic bearings, in which the pressure is being externally inserted. Gas bearings are being mainly used in precision machinery tools (measuring and processing machines) and high-speed machines (spindle, small-scale turbomachinery, precision gyroscopes). 1 Share this post Link to post Share on other sites
JoeM 10,311 #86 Posted October 8, 2019 (edited) Ed is that a cheese cutter? oh maybe I just cut the cheese! detachable pot handle? Edited October 8, 2019 by OILUJ52 1 Share this post Link to post Share on other sites
Ed Kennell 47,403 #87 Posted October 9, 2019 It is an early version of a Pyrex pot handle with a glass handle circa 1940-45. This is the modern version. 2 Share this post Link to post Share on other sites
Ed Kennell 47,403 #88 Posted October 9, 2019 2 hours ago, bcgold said: https://en.wikipedia.org/wiki/Air_bearing Air bearings (also known as aerostatic or aerodynamic bearings) are bearings that use a thin film of pressurized gas to provide a low friction load-bearing interface between surfaces. The two surfaces do not touch, thus avoiding the traditional bearing-related problems of friction, wear, particulates, and lubricant handling, and offer distinct advantages in precision positioning, such as lacking backlash and static friction, as well as in high-speed applications.[1] A differentiation is made between aerodynamic bearings, which establish the air cushion through the relative motion between static and moving parts, and aerostatic bearings, in which the pressure is being externally inserted. Gas bearings are being mainly used in precision machinery tools (measuring and processing machines) and high-speed machines (spindle, small-scale turbomachinery, precision gyroscopes). Obviously this would have to be an aerodynamic bearing as there is no external pressure source. This instrument is used in dirty unfiltered water so it must have some type of seal that is also near zero friction. More research needed. Share this post Link to post Share on other sites
JoeM 10,311 #89 Posted October 9, 2019 what so you suppose this is? Share this post Link to post Share on other sites
Pullstart 71,332 #90 Posted October 9, 2019 Walnut on a stick? 1 Share this post Link to post Share on other sites
JoeM 10,311 #91 Posted October 9, 2019 Just now, pullstart said: Walnut on a stick? very good, yes, what is it used for? Share this post Link to post Share on other sites
ebinmaine 80,772 #93 Posted October 9, 2019 I don't know but it's driving me nuts....... 3 Share this post Link to post Share on other sites
Pullstart 71,332 #94 Posted October 9, 2019 No idea... I’m surprised I could tell what it actually is! I can see it being used to keep kids in line Share this post Link to post Share on other sites
Pullstart 71,332 #95 Posted October 9, 2019 Just now, ebinmaine said: I don't know but it's driving me nuts....... Heh. Heh. Heh. EB made a joke. Heh. 3 Share this post Link to post Share on other sites
Darb1964 1,174 #96 Posted October 9, 2019 So you can chuck it at your advisories, we did that with Apple's when I was a kid. Stuck them on a long flexible stick. Got my A in some trouble. Share this post Link to post Share on other sites
Super-C 4 me 612 #97 Posted October 9, 2019 back scratcher? Share this post Link to post Share on other sites
Ed Kennell 47,403 #98 Posted October 9, 2019 My first thought was a honey dispenser. Then I saw the long stick. Now I'm thinking squirrel toy. Share this post Link to post Share on other sites
JoeM 10,311 #99 Posted October 9, 2019 Super c got it hillbilly back scratcher 1 1 3 Share this post Link to post Share on other sites
Super-C 4 me 612 #100 Posted October 9, 2019 🤔🤔 I guess that shows my ancestry. 1 1 2 Share this post Link to post Share on other sites
