raywilson12 8 #1 Posted April 4, 2019 Im making a belt guard for my 604. I need all the refrences i can get! If its 60s with a techy i wanna see it! Please help! Share this post Link to post Share on other sites
wallfish 19,698 #2 Posted April 4, 2019 I have a 654 and will get you pics and measurements of the belt guard later today if no else posts it before that 1 Share this post Link to post Share on other sites
raywilson12 8 #3 Posted April 4, 2019 Thanks @wallfish Share this post Link to post Share on other sites
raywilson12 8 #4 Posted April 4, 2019 Id like to see the factory mounts too if anyone can... mine has just threaded rod Share this post Link to post Share on other sites
The Tuul Crib 7,353 #5 Posted April 4, 2019 Hey ray check in the picture gallery. That might help some. Share this post Link to post Share on other sites
raywilson12 8 #6 Posted April 4, 2019 @The Tool Crib I looked. There were a few but it seems you guys dont like the techys lol Mostly kohler Share this post Link to post Share on other sites
Pullstart 69,601 #7 Posted April 4, 2019 A Kohler can be adapted quite easily to a Tecky equipped tractor. I imagine a Kohler equipped guard could be modified for usage the other way also.. 1 Share this post Link to post Share on other sites
raywilson12 8 #8 Posted April 4, 2019 1 hour ago, pullstart said: A Kohler can be adapted quite easily to a Tecky equipped tractor. I imagine a Kohler equipped guard could be modified for usage the other way also.. Ill Keep that in mind. Thanks! Share this post Link to post Share on other sites
wallfish 19,698 #9 Posted April 4, 2019 The Kohler and Tecumseh belt guards are basically the same thing except the location of the mounting tab at the engine are in slightly different locations, because of the bolt pattern difference around the crank shaft of each type of engine. I have an 8hp Kohler mounted in my 654. Here's some pics The factory mounting tabs are commonly broken. They're just steel bent to a Z shape with a threaded 14-20 hole and welded to the frame 2 Share this post Link to post Share on other sites
953 nut 65,103 #10 Posted April 5, 2019 Have you checked with A-Z Tractor to see if he has one? https://a-ztractor.com/ Share this post Link to post Share on other sites
raywilson12 8 #11 Posted April 5, 2019 Would lawn ranger be the same too? Share this post Link to post Share on other sites
raywilson12 8 #12 Posted April 5, 2019 14 hours ago, 953 nut said: Have you checked with A-Z Tractor to see if he has one? https://a-ztractor.com/ They have a lawn ranger one Will it match up? Share this post Link to post Share on other sites
WHGuy413 2,851 #13 Posted April 21, 2019 You may be able to see what you need in this pic. I thought I had a better one but nope not on this phone I can get more if you need them. Share this post Link to post Share on other sites
WHX?? 55,993 #14 Posted April 22, 2019 Here's a 604 and was missing the guard when it joined my herd. Found this one at he BS. Fit perfect and as luck would have it a matching patina. Didn't have the heart to change the 502 decal. 1 Share this post Link to post Share on other sites
raywilson12 8 #15 Posted May 14, 2019 Sweet guys! this is awsome! Thanks so much! Share this post Link to post Share on other sites
71_Bronco 1,072 #17 Posted May 14, 2019 33 minutes ago, Retierd Wrencher said: That last picture with the patina red and the hub caps looks really sharp. I have a set I am thinking about putting on my worker Commando 8 for a similar look. Share this post Link to post Share on other sites
Retired Wrencher 6,566 #18 Posted May 15, 2019 (edited) 71 B. Thanks for the reply. They do dress the tractor up. I had all of these at one time. I only have one now. At my age that is enough. Edited May 15, 2019 by Retierd Wrencher Share this post Link to post Share on other sites
