ebinmaine 77,585 #1 Posted March 26, 2019 (edited) I know the title of this thread is "non tractor related discussion" and by definition this is actually a tractor but it isn't exactly a big tractor so I'm thinking this is probably where this should go. Trina wants to try to stand this tractor up over by the stairway wall to use it as a decoration. It's obviously missing quite a fair amount of stuff. I don't necessarily want to spend a bunch of money finding more parts or get it moving on its own power. What can we do to make it so that it will stand by itself? Edited March 26, 2019 by ebinmaine Added actual pictures so you don't have to just use your imagination 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #2 Posted March 26, 2019 @ebinmaine, might be able to help if we had something to look at 😂 1 Share this post Link to post Share on other sites
ebinmaine 77,585 #3 Posted March 26, 2019 1 minute ago, LengerichKA88 said: @ebinmaine, might be able to help if we had something to look at 😂 I'm going to go ahead and blame the camera even though we all know full well it was the operator 2 Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted March 26, 2019 If you can't fix it with duct tape, it's beyond repair. 1 1 3 Share this post Link to post Share on other sites
Stormin 9,987 #5 Posted March 26, 2019 (edited) How about a piece of wood turned down to fit the hole, with a hole through the size of the axle then split. Pushed through the holes in the chainguard then screwed to gether. Can't do that unless you cut the sprocket off. Edited March 26, 2019 by Stormin Share this post Link to post Share on other sites
Pullstart 69,011 #6 Posted March 26, 2019 Conduit clamps adhered to the axle and rear frame? Share this post Link to post Share on other sites
roadapples 6,987 #7 Posted March 26, 2019 1 hour ago, oldredrider said: If you can't fix it with duct tape, it's beyond repair. you can even get it in red.... 1 2 Share this post Link to post Share on other sites
oliver2-44 11,273 #8 Posted March 27, 2019 If I'm see how it assembles correctly would this work... cut 2 pieces of plywood sort of the size of the chain guard. Put a notch in the rounded end of them so they can side over the axle and sandwich around the axle gear. screw them together around that axle gear. Then screw the chain guard together and fastened to the tractor. Hopefully the plywood will "fill" the chain guard and hold everything together. 1 Share this post Link to post Share on other sites
Lee1977 7,578 #9 Posted March 27, 2019 (edited) It's not Rocket Science. There are around a third of the pieces missing that you will have to make to get it to stand up. Main piece is a rear axle support that goes out to the wheels it holds up the chain guard and the the the strap from the main frame below the seat bolts to it. 3/4 plywood would work attach the rear axle with some metal straps if it's just for show. I don't see any peddles and can't see what holds up the chain guard in the front. Edited March 27, 2019 by Lee1977 1 Share this post Link to post Share on other sites
ebinmaine 77,585 #10 Posted March 27, 2019 Good ideas guys. Thanks. I'll share them with Trina and see what she does. 1 Share this post Link to post Share on other sites
Pullstart 69,011 #11 Posted March 27, 2019 47 minutes ago, ebinmaine said: Good ideas guys. Thanks. I'll share them with Trina and see what she does. “See what she does.” I can imagine this conversation going well! EB. Well Honey, the guys said you can do it this way, this way, or this way. What are you going to chose? BBT (Black Belt Trina) Thank you for your phone a friend, Bear! I will chose option number 2. Will that be ok? EB. I’m sure they will be ok with that choice. I’ll let them know how it works out 💪 4 Share this post Link to post Share on other sites
ebinmaine 77,585 #12 Posted March 27, 2019 5 minutes ago, pullstart said: “See what she does.” I can imagine this conversation going well! EB. Well Honey, the guys said you can do it this way, this way, or this way. What are you going to chose? BBT (Black Belt Trina) Thank you for your phone a friend, Bear! I will chose option number 2. Will that be ok? EB. I’m sure they will be ok with that choice. I’ll let them know how it works out 💪 HAHAHAHAHAHHA !!!!! Laughing. Out. Loud. LOL. Literally. Yeah man. You totally nailed it. Word for word. That's what will happen. 1 2 Share this post Link to post Share on other sites
JoeM 9,650 #13 Posted March 27, 2019 EB that answer might be right in front of you, (Not BBT), but the zip ties. Might want to zip that guard in place with some spacers inside to hold it firm to the axle sprocket. That thing is to cool to alter or destroy. Just a thought. 1 Share this post Link to post Share on other sites
WHX?? 55,346 #14 Posted March 27, 2019 34 minutes ago, OILUJ52 said: to cool to alter or destroy. Agreed... you offering to resto it for him Julio? 1 Share this post Link to post Share on other sites
ebinmaine 77,585 #15 Posted March 27, 2019 46 minutes ago, OILUJ52 said: That thing is to cool to alter or destroy 11 minutes ago, WHX22 said: Agreed Us too. We'd love to use it as is without modification to it. You all would be proud of her. She sanded and brushed it carefully so as to clean it up while maintaining original patina. 1 1 Share this post Link to post Share on other sites
roadapples 6,987 #16 Posted March 27, 2019 You only need something simple to hold it up since there are no little kids around, because the first thing they would do is hop on... Share this post Link to post Share on other sites
JoeM 9,650 #17 Posted March 27, 2019 1 hour ago, WHX22 said: Agreed... you offering to resto it for him Julio? If I was closer, would take a shot at it! A few pics and a old bicycle chain and peds might be the ticket. Share this post Link to post Share on other sites
Herder 2,355 #18 Posted March 27, 2019 16 hours ago, roadapples said: you can even get it in red.... Red duct tape is for high speeds applications. 1 Share this post Link to post Share on other sites
ebinmaine 77,585 #19 Posted March 27, 2019 1 hour ago, Herder said: Red duct tape is for high speeds applications. That's understandable but I wasn't aware.... Any other color coding I need to know??? Share this post Link to post Share on other sites
