Jeff-C175 7,207 #101 Posted April 16, 2021 1 hour ago, bc.gold said: operating at 28 MHz Ohhhh, so THAT'S what I hear wiping out the 10 meter amateur radio band! I thought it was the neighbor's 'grow lights' all this time! 1 Share this post Link to post Share on other sites
bc.gold 3,406 #102 Posted April 16, 2021 17 minutes ago, Jeff-C175 said: Ohhhh, so THAT'S what I hear wiping out the 10 meter amateur radio band! I thought it was the neighbor's 'grow lights' all this time! VA7ELM with honors. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #103 Posted May 7, 2021 (edited) DPF filter from a 2017 Duramax in he sonic tank, that's platinum float. Edited May 7, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #104 Posted May 8, 2021 12 hours ago, bc.gold said: DPF filter from a 2017 Duramax in he sonic tank, that's platinum float. In the tube video above we see the platinum liberating oxygen from water,. Last week I made some activated carbon and decided to use it to scavenge any platinum that passed through the filter paper. The carbon did a fantastic job,the very small bits unseen to the human eye have attacked to the carbon, the reaction is instantaneous. Now i have platinum activated carbon as it reacts with the water once again we have oxygen. The oxygenated carbon floats making recovery easy. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #105 Posted May 21, 2021 (edited) With the $105.00 penny find I purchased a one inch portable gas water pump, river water with dissolved gold will get passed through this filter packed with activated carbon. A buddy from Vancouver island sent me two liters of river water from Sooke not to far from Leachtown a well known gold producing area who's watercourse feeds into the Sooke River/ but after evaporating one liter down his water does not look near as promising as the location I discovered further north. I made a mistake using a metal pan to evaporate the water, any gold that may have been there has certainly reacted with the metal which caused it to be cemented out. The pan had a nice shiny bottom when it first started out now it's showing some black. Fortunately I have saved a sample for assay which will be mailed out tomorrow to a lab is Saskatchewan. Leechtown is a ghost town on the Southern end of Vancouver Island in British Columbia, Canada. On 18 July 1864 the Leech River was named and 'payable' gold was discovered by members of the Vancouver Island Exploring Expedition (VIEE), which led to a gold rush and the establishment of Leechtown. Edited May 21, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #106 Posted May 21, 2021 (edited) The residue line looks metallic. Edited May 21, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #107 Posted May 21, 2021 (edited) Going camping bring your own water you never know what is that fresh looking stream or brook water. Elements below iron will react with cookware containing iron and discolor your cookware with its precipitate. Aluminum cookware will react with elements below itself to precipitate those out of solution, fortunately aluminum being very reactive forms a passive layer but acidic foods easily break through this layer. When the results of the water assay have been returned we'll know all the elements in our river water and wither its safe for domestic use. As a youngster my father once told me to be careful in the woods what I used to wipe my butt with. Edited May 21, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #108 Posted May 21, 2021 Interesting accumulation. Sample is in the mail. Share this post Link to post Share on other sites
bc.gold 3,406 #109 Posted June 10, 2021 (edited) On 5/21/2021 at 4:45 PM, bc.gold said: Interesting accumulation. Sample is in the mail. Assay report arrived, this river water is better to drink than most brands of bottled water. Gold is present but at 2 parts per billion, sea water probably contains higher levels. Edited June 10, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #110 Posted June 10, 2021 Silver soldered joints being prepared, burn off any oil and anneal the copper making it easier to compress into bricks. Share this post Link to post Share on other sites
bc.gold 3,406 #111 Posted June 13, 2021 (edited) Using an un-glazed flower pot the copper ions pass freely, within a couple of hours the copper has begun to plate over to the stainless steel cathode the silver will be left as sludge in the flower pot. The DC power supply is running at 6 volts and the copper parting cell is pulling 10 amps, once the accumulated copper has thickened on the stainless plate it's easily peeled away as a single sheet. Edited June 13, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #112 Posted June 14, 2021 Copper deposit is fluffy because I'm running the cell at high voltage. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #113 Posted June 15, 2021 (edited) Day two the copper peeled away nicely from the stainless steel sheet and we have some sludge already forming in the cell this will be the silver I'm after. The blue crystals in the large pan will be taken up with hot water then returned the cell, the blue is home made copper sulfate. Edited June 15, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #114 Posted June 15, 2021 Platinum sister mud, this would make a nice black hood paint. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #115 Posted June 16, 2021 (edited) This mornings copper harvest, I'm using copper sulfate in my electrolyte could have demonstrated the same procedure copper plating via immersion but have instead borrowed a tube video from another tuber. For successful plating the manufactures oil must be washed then rinsed before submersing. Using this process is how they plate screws and clamps on cheap battery chargers into making the consumer think they're buying copper. Put a magnet to this cheap crap and the truth shall be revealed. Edited June 16, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #116 Posted June 20, 2021 Sold my Petter 15kw generator and the Allis 720 along with related attachments, time to move along into the next chapter, prospecting and essential oils which have no place on this forum it's time to say adios. Share this post Link to post Share on other sites
bc.gold 3,406 #117 Posted September 6, 2021 (edited) Working with a larger parting cell/ Edited September 6, 2021 by bc.gold Share this post Link to post Share on other sites
bc.gold 3,406 #118 Posted September 6, 2021 First copper harvest, one side of the stainless steel cathode had a nice sheet that peeled off while the side facing the anode was fluffy. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #119 Posted March 27, 2022 Looks like I have a promising summer ahead of me. Share this post Link to post Share on other sites
Jeff-C175 7,207 #120 Posted March 27, 2022 1 hour ago, bc.gold said: Looks like I have a promising summer ahead of me Not if you eat that! What are we looking at? Share this post Link to post Share on other sites
bc.gold 3,406 #121 Posted March 28, 2022 4 hours ago, Jeff-C175 said: Not if you eat that! What are we looking at? When ya have the fever, everything looks like gold. 1 Share this post Link to post Share on other sites
bc.gold 3,406 #122 Posted March 28, 2022 (edited) 7 hours ago, bc.gold said: Looks like I have a promising summer ahead of me. Tablespoon full of black sand mixed with flux, there was no visible gold to begin with. Had I added a collector metal the gold would have been scavenged by the collector. As it is I'm impressed with the results, I have 1kg of this sample to smelt, the other sample I had received from Rod tested barren for au. The flux I'm using is a home made recipe, Borax, Silica with some Fluorspar to make the flux more fluid. Edited March 28, 2022 by bc.gold 1 Share this post Link to post Share on other sites
